Dell XPS 9310 GDA30 LA-J143P bios repair please
  • Lovro25
    • Jan 2023
    • 11
    • Croatia
    #181
    Can someone fix this bios. Laptop turns on and only shows Dell logo.
    ST: FKH7793
    • richardsmr
      • Aug 2021
      • 25
      • england
      #182
      hi can someone help please fix bios stuck on logo
      dell xps p103g
      s/n 65vw2f3
      • hoaca388
        Badcaps
        • Jan 2022
        • 11700
        #183
        dell xps p103g
        s/n 65vw2f3
        XPS 13 9310 2-in-1
        Service Tag: 65VW2F3
        • hoaca388
          Badcaps
          • Jan 2022
          • 11700
          #184
          ST: FKH7793
          Why do you have to lie like that ?
          XPS 13 9310
          Service Tag: FKH7793
          • richardsmr
            • Aug 2021
            • 25
            • england
            #185
            Originally posted by hoaca388
            XPS 13 9310 2-in-1
            thankyou but still have same fault turns on stuck on dell logo and caps lock stays lit
            • alihomee
              • Dec 2012
              • 1574
              • malaysia
              #186
              dell xps 13 9310 service tag is:3P2G7D3 ...tried some files from this thread but no luck it hangs on dell logo and with some other files it restarts 3 times and then a dim display with dell logo anf fan full speed i attached orignal file ...motherboard code is :GDa30 LA-J143p
              • lapfix
                • Mar 2020
                • 2719
                • my workshop
                #187
                Try this clean me of your bios
                Bios version : 3.30.0
                Me version : 15.0.50.2633
                • alihomee
                  • Dec 2012
                  • 1574
                  • malaysia
                  #188
                  thanks for responce...tried this file after first restarts screen is blank with 8 white and 2 orange blinks......now orignal condition changed no more hang but after restarts no display and fans are loud
                  • lapfix
                    • Mar 2020
                    • 2719
                    • my workshop
                    #189
                    Try :
                    The blinking pattern you’re observing (2 amber, 8 white) points to an LCD failure. Here are some steps to consider:
                      • Check the Screen: Even if the screen appears to be working fine, there might be underlying issues with the LCD panel itself. Sometimes, subtle problems can cause this error code.
                      • Reseat the LCD Cable: Open up your laptop (if you’re comfortable doing so) and reseat the LCD cable. Sometimes, loose connections can trigger false error codes.
                      • Hold the Power Button: Try holding down the power button for about 30 seconds while the laptop is in Windows. This action can sometimes reset certain components and resolve the issue.
                      • CMOS Battery: If the problem persists, check the CMOS battery. A dead CMOS battery can sometimes cause unexpected errors. If you need to replace it, ensure you have your Bitlocker key handy if you’re using Bitlocker authentication.
                      • Motherboard: If none of the above steps work, it’s possible that the issue lies with the motherboard. You might need to consider replacing it.
                    • Bios White
                      Learn
                      • Dec 2024
                      • 69
                      • East Laos
                      #190
                      The device does not receive wifi, has replaced another wifi, please build Bios XPS 13 9310
                      TAG : GDN4DB3
                      • Bios White
                        Learn
                        • Dec 2024
                        • 69
                        • East Laos
                        #191
                        Someone help me
                        • hoaca388
                          Badcaps
                          • Jan 2022
                          • 11700
                          #192
                          TAG : GDN4DB3
                          XPS 13 9310
                          Service Tag: GDN4DB3
                          • Bios White
                            Learn
                            • Dec 2024
                            • 69
                            • East Laos
                            #193
                            XPS 13 9310
                            thank you,
                            Dell logo hanging machine
                            please help me
                            • zenius
                              by zenius
                              12-08-2024, 06:13 AM
                            • mikeybass
                              by mikeybass
                              04-23-2025, 04:30 PM
                            • jhanra
                              by jhanra
                              in windows 11 sound driver compatibility, but overall its ok, for me i can deal with it, 😅😅😅...
                              11-02-2024, 04:19 AM
                            • gizaha
                              by gizaha
                              02-13-2024, 07:18 AM
                            • mrrubik
                              Dell Optiplex 7010 micro bad BIOS flash?
                              by mrrubik
                              Hi folks,
                              I got a Dell Optiplex 7010 micro PC (Exact Model) with 8FC8 BIOS and locked out admin password. I attempted to remove the password by patching the BIOS via info from this thread: https://www.badcaps.net/forum/troubl...ssword-patcher
                              After flashing the patched the BIOS, the PC is unresponsive with a solid AMBER power LED (not documented in manual anywhere)
                              Steps I took:
                              1. Read BIOS with CH341a, verified hash twice
                              2. Patched
                              12-23-2024, 04:11 PM
