Dell XPS 9310 GDA30 LA-J143P bios repair please
    Re: Dell XPS 9310 GDA30 LA-J143P bios repair please
    Originally posted by zzzac View Post
    file attached
    thanks
    xps 13 9310
    Become a Badcaps supporter
    Thanks to all supporters.
      Originally posted by hoaca388 View Post
      xps 13 9310
      Thanks, unfortunately with Moderna TGL file i get 3,6 error
        What error code is 3.6 ?
          Front light flashes 3 amber 6 white is the dell error for corrupt bios
          I also have the same issue with the TGL R file
            Change a blank bios chip and try again.
              Has anyone solved the 2 amber, 4 white blink code (memory failure) via a bios flash? Reading through the posts, it seems a lot of people tried in this thread, but no conclusive results.
              Thank you!
                Hi guys!
                My laptop also gets stuck on the startup logo, but none of the USB ports work either, and it doesn't want to charge the battery through either of the two ports. Maybe my bios is corrupted?
                Motherboard model: GDA30 LA-J143P
                RegModel: P117G
                Service Tag: FT53DB3
                Thanks!
                  Originally posted by Rockman1987 View Post
                  Hi guys!
                  RegModel: P117G
                  Thanks!
                  XPS 13 9310
                    XPS 13 9310
                    XPS 13 9310_ModenaTgl_ v3.1.0.rar
                    XPS 13 9310_ModenaTgl_R v3.1.0.rar
                    What is the difference between the two? And which one do you recommend I try first?
                    Using MEAnalizer, I only see differences in the USB Type C Physical parameters.
                    Thanks hoaca388!
                      Thanks hoaca388!
                      One version is Modena, one version is Modena R
                        Hello Guys,
                        Please can you help me with a new clean bios dump for my laptop? I will 100% be donating to help keep a great site like this going.
                        My laptop has the 3 Amber/ 6 White flashes. What had previously happened when it was working was both USB ports stopped detecting any devices in Windows with unknown device after plugging in a Wacom dongle. So I reflashed a new bios from Dell as there was a newer one in support assist and then that was that, bricked! The Dell logo comes up, laptop charges but none of the many recovery options work.
                        I got a WSON8 Pogo pin line probe from Amazon and was luckily able to read and dump the dead bios with Neo programmer first try luckily.
                        Here are some of the details.
                        Intel i7-1185G7 11th Gen UHD+ 16GB Ram 1TB HD, 2020/12/16 Model Made in Taiwan
                        NOT a 2in1 just the normal touchscreen one.
                        Service Tag: CHHM7C3
                        Bios Chip XMC QH256BXiQ
                        Please let me know if you need any other numbers needed as I’m a complete novice at this. Noticed a whole bunch of numbers on the inside of the aluminum back cover next to a QR code if needed?
                        Many thanks all.
                          Originally posted by himmon View Post
                          Hello Guys,
                          Please let me know if you need any other numbers needed as I'm a complete novice at this. Noticed a whole bunch of numbers on the inside of the aluminum back cover next to a QR code if needed?
                          Many thanks all.
                          Hello try this file ...
                            Thank you very much Markus, I will give it a try.
                              Hello Markus, unfortunately, didn't work.
                              I detected IC with NeoProgrammer, successful.
                              Erased IC, success.
                              Write IC with your new bios, success,
                              Verified IC, success.
                              Disconnected NeoProg,
                              Reconnected the battery, won't turn on, and nothing is on display now.
                              Held the power button for 12 seconds, but nothing. Tried the CTRL and ESC and plugin power, but nothing.
                              All that happens if I press the power button, the orange LED on the front illuminates. If I let go of the power button, the orange LED goes off. If I tap power a few times, it flashes the orange LED a few times at the same time as pressing power.
                                Erased IC, success.
                                Hello, try these...
                                You can also try these from hoaca388, they are ME Clean, good luck...
                                https://www.badcaps.net/forum/showpo...0&postcount=68
                                  Tried the other bios you attached, exact same result, won't turn on, orange LED when the power is pressed. With my original broken bios, the screen was on with the Dell logo with 3 and 6 flashes.
                                  Do I need to give any more info than just other than the service tag, not sure where to find the motherboard model number etc if that helps? With neoprogrammer, takes about 5 mins to flash and 5 mins to verify using black CH314A. Detects the IC chip exactly. When reading the IC again, it has definitely written a lot of data instead of just all FF FF FF, etc.
                                  Thank you very much for your help so far.
                                    XPS 13 9310_ModenaTgl_ v3.1.0.rar Tiger lake
                                    XPS 13 9310_ModenaTgl_R v3.1.0.rar Tiger lake refresh
                                      Hello SMDFlea,
                                      Thanks for confirming they're for Tigerlake which I have as its an 11th Gen i7,
                                      So I could just try flash either of those? My Service Tag: CHHM7C3
                                      But I assume you don't need that when I flash either one of those bios that may work as it'll ask me to confirm the service tag if it boots?
                                      Cheers
                                        Hello Guys,
                                        Many thanks all.
                                        Try version 1.0.3
                                          Hello hoaca388,
                                          Thank you for this new bios, so far this is looking way more positive but still some problems.
                                          After erasing and flashing this bios, the laptop now switches on and goes through the red green blue screen test for about 3 cycles, then switches off, reboots, comes back on, and shows the Dell screen but is stuck. Left it for 5 minutes.
                                          So I tried holding power to force turn off. Then pressing F12 or F2 repeatedly and immediately when pressing the power button turns the dell screen logo and keyboard backlight on and off every time I press either F12 or F2. The front LED is constantly flashing white on and off during all of this.
                                          Should I try disconnecting and reconnect the battery or maybe bios problem still?
                                          Really appreciate all your time with this.
