Dell E5470 custom bios issue
  • Calgacus
    • Aug 2022
    • 82
    • Scotland
    Hi
    I have a Dell E5470. I am trying to re install windows 10. I have wiped the partitions on hard drive and ran the setup. When i get to the network selection screen there is no option bypass where you normally see it down in bottom left of screen.
    When you connect to wifi it goes to a custom screen that requests logging into a specific user account on a server.
    It's not getting this info from the hard drive as it's wiped. I have read the bios file and attached.
    Searching the bios file in hex editor results in showing a reference to the company website in the bios bin file.
    I was hoping someone with the correct knowledge can remoce what ever it is thats causing it to force windows install down this path instead of a normal install.
    Please advise if you need further details.
    Any information on this would be appreciated
    Thanks in advance
  • hoaca388
    Badcaps
    • Jan 2022
    • 11640
    Re: Dell E5470 custom bios issue
    Backup fault. Your bios region's empty.
    • Calgacus
      • Aug 2022
      • 82
      • Scotland
      Ok... i will try re read the bios
      Update: i am using the RT809F programmer, but its displaying message that the chip ID does not match
      the bios chips is Winbond 25Q128FVSQ But this is not in the list of known chips. Autodetech sees it as a cypruss
      Not sure what all this means
      Any help appreciated
      028: Chip pins contact is detected OK.
      029: Chip ID verification OK.
      030: UniqueID:0x341C2ADF623C66D2
      031: Start reading chip......
      032: Status register1 values: 0x0, Status register2 values: 0x2 .
      033: Read successful£¬Elapsed time£º25.85 seconds¡£
      034: Auto verifying...
      035: Chip verification error, start position: 0x19E38.
      036: Verification failure£¬Elapsed time£º0.213 seconds¡£
      037: Read error, operation aborted.
      038: Chip pins contact is detected OK.
      039: Chip ID selected does not match the current ID, operation has been terminated.
      040: ID verification error.
      Maybe this time after playing with different version pf software
      see attached
      • hoaca388
        Badcaps
        • Jan 2022
        • 11640
        see attached
        No, fault again.
        • Calgacus
          • Aug 2022
          • 82
          • Scotland
          the re-read and verify went without any errors but i will try again, I did notice the size of the bin file at 16mb but the zipped file was only 52kb which seemed a bit low...is there a option to upload the full bin file ?
          • hoaca388
            Badcaps
            • Jan 2022
            • 11640
            Try manual chip selection. Do not select auto-detection.
            • Calgacus
              • Aug 2022
              • 82
              • Scotland
              Appreciate your help hoaca, i am using the software that came with the programmer its not very good to be honest. I cant see the actual chip listed from the available chip options.
              Can you recommend a good programming software alternative
              I am using a version of ifix RT809 even the latest version of tis software does not have my chip listed, it autodetects as a cypruss 25Q128BVSQ
              the actual print on the bios chip is 25Q128FVSQ
              • Calgacus
                • Aug 2022
                • 82
                • Scotland
                I have re read the chip 3 times and its verified fine each time
                I have renamed the bin file to zip instead of compressing it as it seems to be very small when compressed
                Hope its intact this time
                Thanks again
                • RethoricalCheese
                  • Mar 2013
                  • 1517
                  • Estonia
                  Read about Windows autopilot.
                  And then install either Windows home or Linux
                  Your bios is not custom, don't waste time on that
                  • Calgacus
                    • Aug 2022
                    • 82
                    • Scotland
                    Hi Rethorical
                    Never used Autopilot, but have installed windows on lots of systems and never seen this issue before. So it's stumped me. See attached screen shots showing the windows installer screen that it lands on during install after i select keyboard layout etc...
                    There is no option to create a local account and the "I dont have internet" option is also missing from the account screen.
                    It cant be getting the company name from the hard drive because it's been cleaned with diskpart prior to install.
                    That led me to suspect the bios. So i dumped the bios file and searched for the same company name inside the bin file and found the company name located in the bin file.
                    I can't find anything online about this so was hoping it could simply be cleaned from the bios file to allow me to do a standard windows install
                    Thanks again for your reply, and further advice welcome
                      • 20674
                      Thanks again
                      Are you using a sop8 clip to make your backups because they`re all corrupt ? .Post the service tag please
                      • Calgacus
                        • Aug 2022
                        • 82
                        • Scotland
                        Hi M8
                        yes, i have been using the clip. not had any issues with it before, but obviously its not working if even the latest read is corrupt. It verified 3 times though.
                        I will now de solder the chip and read it that way
                        Thanks for your input
                        appreciated.
                        Any thoughts on the bios containing this company name which is the same name as th login its trying to use at first log in on clean install ?
                          • 20674
                          Hi M8
                          appreciated.
                          As far as i can tell its just part of a domain ,AMT settings are where its stored. I asked you for your service tag, with that we can look at your laptop configuration. Depending on the configuration you can use another dump with clean ME firmware
                          • Calgacus
                            • Aug 2022
                            • 82
                            • Scotland
                            Hi
                            sorry mist the request for the service tag m8
                            here you go
                            33579617150
                            in bios setting it reads FFCFQF2
                            thanks
                              • 20674
                              Hi
                              here you go
                              33579617150
                              thanks
                              Ok try and make another backup .The chip might be bad,lets see what the backup is like when its desoldered .
                              • Calgacus
                                • Aug 2022
                                • 82
                                • Scotland
                                My rework station is at home so i will do this task this eve
                                Thanks for your time
                                • DanielDacko
                                  • Mar 2015
                                  • 325
                                  • Macedonia
                                  I would erase the code from the bios dump and see what happens, just out of curiosity
                                  I don't provide help for people using CH341A and a clip.
                                  • RethoricalCheese
                                    • Mar 2013
                                    • 1517
                                    • Estonia
                                    Things I have done to try to remove autopilot, the exact same thing you have right now (on lenovo).
                                    New me + main bios, new SN and motherboard SN, new network mac, new windows installer and maybe something else. Nothing helped. Only thing I did not do, which might help, was to replace TPM chip.
                                    As I said, install windows HOME not PRO. In that case, windows will not check if autopilot is installed because autopilot is not a part of windows home.
                                    But if you do find a solution for this, I am all ears. Keeping clear from PRO is just a workaround sadly.
                                    Autopilot is quite a recent thing. It was first implemented last year I think. And first autopilot laptops ended up in my hand at the end of last year I think. And some companies do unenroll from autopilot but others either forget or are too lazy to do it. Sadly microsoft has not implemented any way to unenroll for 3rd party users.
                                    • Calgacus
                                      • Aug 2022
                                      • 82
                                      • Scotland
                                      It's around 3/4 years old so i don't think its autopilot.
                                      It does allow booting into the AMT setting menu, by pressing CTRL P at first boot...but thats password protected also, so cant change or even browse anythng in there.
                                      See attached fresh bios dump with the chip desoldered.
                                      compressed zip file
                                      Thanks again for advice on this
                                        • 20674
                                        compressed zip file
                                        try this bios
                                        • NotEnough
                                          Dell G15 5515 RGB Keyboard Not Detected (Compatible Keyboard, Possible BIOS/EC Issue?)
                                          by NotEnough
                                          I'm working on a Dell G15 5515 (Ryzen 7 5800H, RTX 3050 Ti) and recently installed a compatible 4-zone RGB keyboard and controller (for Dell G15 5510/5511/5515 models). While the keyboard functions for typing, the RGB lighting is not detected by Alienware Command Center (AWCC), which displays “No AlienFX devices found.”
                                          What I've Tried So Far:
                                          • Reseated the cables.
                                          • Reinstalled AWCC and AlienFX services.
                                          • Attempted BIOS downgrade but no improvement.
                                          • Inspected ribbon cables for damage.
                                          • Explored the possibility of BIOS or
                                          10-19-2024, 01:34 AM
                                        • mikeybass
                                          by mikeybass
                                          04-23-2025, 04:30 PM
                                        • computerbacon79
                                          Dell Inspiron 3480 All in One corrupt Bios issue: reaches Dell logo and stops
                                          by computerbacon79
                                          The Dell Inspiron 3480 I own (the all in one, not the laptop) is not wanting to turn on at all. It goes right to a dell logo, but it stays there forever with no other information on the screen. Holding the automatic Bios repair key combo (ctrl+esc) that should let it read a recovery file off a USB drive gets stuck on a black screen and does nothing. No amount of resetting anything so far has worked, and Dell's own support downloads have not really helped. Ive tried another BIN file I found online using my CH341A, and this got me slightly more, that time it displayed a loading bar that never moved...
                                          05-06-2025, 06:43 PM
                                        • gizaha
                                          by gizaha
                                          02-13-2024, 07:18 AM
                                        • Eradicatus
                                          Dell Latitude E5550 - Strange Internal LCD (BIOS?) Issue
                                          by Eradicatus
                                          I have a problem with my Dell Latitude E5550 laptop, in particular with its display.
                                          This laptop has been sat under my desk (unused) for quite a while and I wanted to reinstall Windows and use it for some ad-hoc testing.
                                          However, I am struggling with the display, which is playing up.
                                          1) When the laptop is left switched off, after switching it back on the internal LCD does not work. No images are displayed at all - no DELL logo on POST, no messages, no Windows desktop. But I can hear that Windows starts up correctly, so no issues with the rest of the system - must be...
                                          04-20-2022, 02:40 AM
