Dell Microsoft autopilot issue
Re: Dell Microsoft autopilot issue
Mọi khoản quyên góp cho badcaps đều được hoan nghênh, hãy nhấp vào liên kết này để quyên góp. Cảm ơn tất cả những người ủng hộ----------------------------------------------------------------------------------------------------------------------------------------------------------------Comment
Can you enter the bios settings when the computer boots? Security options need to be reset to factory settings ( disable ), if necessary you should still reinstall the operating system.
Yes, I disabled absolute then erase ssd and install windows but still get this popupComment
Please help me with this Latitude 5420 BIOS file. I tried to change win10 Home but still got popup for some reason. Maybe I did something wrong.Attached FilesComment
Hello Badcaps friends,
I have an Dell Latitude 3340 2-in-1 here with Windows autopilot. Is there yet a way to get rid of this? It's quite a recent model and I can't find any dump.
s/n: 3FMNN54
----------------------------------------------------------------------------------------------------------------------------------------------------------------------Comment
This removed the autopilot from my Surface 3, which has given me trouble all week. I thought I needed the EC cleaned.
This solved the issue.
The touchscreen still works, same serial number. Windows activates, everything works as it should!
I can't tell you how relieved I am. I had 3 of these to deal with.
Many Thanks!
by SuperJamesThis one's a weird one, and still unsolved despite it having gone back to Dell once.
Specs
i7-8750H, GTX 1060 Max Q, 500GB SSD & Seagate 7mm 1TB HDD. 17.3 IPS screen. This has the fingerprint reader in the power button.
Backstory
I bought this from eBay, from a wallpapering shop. £650 in 2020 which was a good price considering it's a gaming laptop. Physically it's in perfect shape, apart from the hinge mounts on the palmrest failing in the time I've had it (I have a new palmrest for it). The usual thin plastic crap modern build quality!...10-23-2023, 04:09 PM -
by hazem3636hi everyone
i need dump file for dell server r220
i have download Flash BIOS executable file but i dont know how to conver it to Bin file
i have check on youtube there is some programs are doing this method of creating Bin file from ExE file .
if anyone has this method please need his supporting .
all the best
EXE file is attched and Original Bin file from the Bios Chip is attached also
and dell website "https://www.dell.com/support/home/en-us/drivers/driversdetails?driverid=mrxv...-
by BowlineMy question pertains to understanding the control circuity inside a Dell PT434 type battery used in Dell E6400, E6410 and other Dell notebooks?
I have tried multiple different Dell power adapters. My Dell... -
by VenDell Latitude 3510 (Intel Core i7-10510U) CPU Overheating
Issue Description:- CPU Overheating to 100°C
- When I start the laptop from a cold state, it takes about a minute to reach temps around 80-90-100°C, and CPU thermal throttling triggers.
- When the CPU fan is running at full speed (by disconnecting PWM and TACH cables), CPU temperature stays around 50-60°C.
- However, when the fan is connected normally to the motherboard, it does not kick in at high temperatures.
- I also noticed a few times that the fan kicked in for a very short time, but it does not stay on consistently.
- Thermal
2 Photos - CPU Overheating to 100°C
by Tech FoxHello community,
I'm repairing a Dell Latitude 7490 with a LA-F321P Rev 1.0 motherboard. The computer booted up without video, and I detected that the contents of UT6 were corrupted (mostly FFFF). The UT6 chip is 1MB and was almost empty.
I'm looking for a working BIOS file for the UT6 chip corresponding to this motherboard (not UC5 or UT2, just UT6). I've tried several incomplete dumps, but the system doesn't provide video; with some, it at least stays on.
I would greatly appreciate it if someone with a working backup could share the file or point me to...-
Channel: BIOS Requests ONLY!
- Loading...
