Dell G3 17 3779 Weird power cycling and shutdown/restart issue
  • SuperJames
    • Jul 2017
    • Electronics, Comics, Technology, Cosplay
    This one's a weird one, and still unsolved despite it having gone back to Dell once.
    Specs
    i7-8750H, GTX 1060 Max Q, 500GB SSD & Seagate 7mm 1TB HDD. 17.3 IPS screen. This has the fingerprint reader in the power button.
    Backstory
    I bought this from eBay, from a wallpapering shop. £650 in 2020 which was a good price considering it's a gaming laptop. Physically it's in perfect shape, apart from the hinge mounts on the palmrest failing in the time I've had it (I have a new palmrest for it). The usual thin plastic crap modern build quality!
    Issue 1
    Anyhow, the issue is it power cycles three times on a cold start, before it finally starts and runs perfect as long as you want it to. It has done this since Day 1. It doesn't seem normal. I even transferred the remainder of the warranty from the old owner, with Dell, and sent it back to them. They sent it back as No Fault Found, even though my 30 years of IT experience tell me something isn't right.
    Once it's running, it runs perfect. I've always used it on a cooling pad, and even undervolted the CPU as these are known to hit 100c under load, the cooling system is inadequate. Changed thermal pads and paste when I got it as I do this with every used system.
    Issue 2
    Over time it developed another issue where it won't shut down or restart, the screen goes off as it should just after the "Shutting down" or "Restarting" windows screen.
    The HDD parks itself normally too, but then it just sits there, still powered. Keyboard lights up, mouse is still powered. You have to hold the power button to turn it off. It then does the power cycling thing again the next time it is turned on.
    I thought it might have been a Windows corruption issue, but a full wipe and reinstall didn't fix it. It still won't shutdown/restart without help.
    Several BIOS updates have done nothing, either. Dell's forums were absolutely useless. The warranty has now expired. I want rid of it so wanna try fixing it as well as rebuilding it with a new palm rest so the hinges are supported as the screw bosses have failed, the plastic round the metal thread bosses has collapsed. Something I've seen hundreds of times in my career.
    I notice the spacebar seems squishy like something has been spilt, but there's no intrusion onto the board, no evidence of ingress even under the keyboard. Voltages I can see are all present. I have a hunch it might be the power board as it has a chip between it (on the CMOS battery PCB) and the mainboard but this is a guess until I study the schematic. It's like the Power Good signal is being asserted and pulled!
    I've had Dells throughout my life and they are solid. These modern ultra thin ones are garbage though, not just Dell, either. They're all copying Apple's crap "thin light and overpowerful" designs. Like car manufacturers are pushing small turbo engines too hard.
    Before I get into a deep dive, has anyone encountered this with these?
  • Okan123465676
    HP G62-A10ER (PM_I_HPC_S MV_MB_V3) Random Shutdown Issue – Powers Off Immediately or After 20–30 Minutes
    by Okan123465676
    I have an HP G62-A10ER laptop with a PM_I_HPC_S MV_MB_V3 motherboard.
    The laptop has an unusual shutdown problem. Sometimes it powers off immediately after pressing the power button. Other times, it works normally for about 20–30 minutes and then suddenly shuts down by itself.
    So far, I have performed the following:
    • Reprogrammed both the Main BIOS and EC BIOS.
    • Left pin 4 of the UH1 IC disconnected as required.
    • Converted the board to UMA mode and disabled the dedicated GPU. However, the problem remains exactly the same.
    What could...
    07-20-2026, 06:08 AM
  • hashwood
    Seasonic Platinum Fanless 520W (SS-520FL2) intermittent shutdown / restart
    by hashwood
    I am troubleshooting a Seasonic Platinum Fanless 520W, model SS-520FL2.
    Symptoms:
    • In a PC, it initially worked for a few minutes, then the system restarted.
    • On a later test, it ran a few more minutes under load and then shut down completely.
    • Outside the PC, it powers up, relay clicks, then it shuts down almost immediately.
    • 5VSB is always present and stable, even when the PSU does not start properly.
    • PWR_OK goes high (~5V) briefly before shutdown.
    • Main bulk capacitor charges normally
    03-23-2026, 05:04 PM
  • kalilinux25
    Power Issue, if shutdown it wont power on again.FH5AT LA-K092P REV 2.0
    by kalilinux25
    Hi good day I have a issue of this motherboard laptop, if doing a cmos reset the the motherboard ( discharge the current inside the board) it will power on and if you shutdown
    the laptop it wont power , it will shows led light for a second then shutdown.
    Tried clean Me bios smae issue
    tried to bypass thermal protection ( remove RB7 and RB1 and jumper each pad of the DB1 )
    ive check the motherboard for corrion but no avail
    Hope someone can guide which part of the board should I focus to narrow down the issue
    FH5AT LA-K092P REV 2...
    10-06-2023, 12:49 AM
  • Nairolf
    Lenovo ThinkPad L480 – Instant Shutdown, BIOS or Power Rail Issue?
    by Nairolf
    I am experiencing a problem with my Lenovo ThinkPad L480.
    Symptoms: When I press the power button, the computer turns on briefly (with no display on the screen). The LED turns on once and then turns off, the fan spins for a short moment, and then everything shuts down completely.
    Measurements and tests performed:
    • The +1VALW, +3VALW, +1.8VALW, +5VALW power rails are present. I tested the secondary rails by trying to turn the PC on several times, and it remains powered on for 2 or 3 seconds. Below are the values I found:
    09-13-2026, 01:00 PM
  • Caimano
    Asus PU551LA cannot restart after shutdown
    by Caimano
    Motherboard PU551LA Ver 2 with Intel i5 4210U
    I bought the motherboard as faulty to replace a similar one not repairable because it was completely shorted.
    3V EC was shorted to ground because of EC chip. IT8585E FXA replaced with IT8585E FXS. Motherboard now works and I am able to recharge the battery, install Windows and update BIOS from Ver 207 to 210 with EZ Flash, but it has the following problem: Every time I power off the laptop with power switch or with Windows shutdown the laptop apparently turns off, but the power LED remains on and it's not possible to restart the laptop....
    05-13-2023, 03:38 PM
