elitebook 850 G7 password
  • ERRA
    • Sep 2025
    • 44
    • Morocco
    #121
    Originally posted by duder
    OK - I double checked again and I did not see any resistors missing. So, I erased the chip and programmed my original backup. Now the machine is back to normal operation with a BIOS password. So, obviously nothing wrong with my soldering. Also, I did a read on the "unlocked BIOS" before erasing it and compared it to the read that I had taken just after writing the "unlocked BIOS" and found they are now different. Powering it up must have changed the contents.
    Do I need to do something with the main BIOS as well to remove the BIOS password?
    TRY THIS
    • duder
      • Oct 2013
      • 41
      • canada
      #122
      Thanks, but that did not work either. I wrote that to the chip and then read it back and compared them - they match. I turned on the machine and got a solid caps lock for maybe 45 seconds. It then turned off. I turned it on again and got the same 7 flashes of capslock & numlock.
      • hoaca388
        Badcaps
        • Jan 2022
        • 12316
        #123
        Post main bios file.
        ​https://www.badcaps.net/donate
        • duder
          • Oct 2013
          • 41
          • canada
          #124
          Ok - Here it is. I read it three times and did comparison.
          • ERRA
            • Sep 2025
            • 44
            • Morocco
            #125
            The old file you uploaded before this one is corrupted!
            Now try this patch, good luck bro
            • duder
              • Oct 2013
              • 41
              • canada
              #126
              Thank you. Okay, you are saying that the very first file I uploaded (8MB) was corrupted. I can accept that, but the system was working with it. It just had a BIOS password.
              My question now is what 8MB file should I use in conjunction with this 16MB file that you just gave me?
              • ERRA
                • Sep 2025
                • 44
                • Morocco
                #127
                The system was working with it, i can accept that! But have you flashed that file back to the chip and pc worked ??
                • duder
                  • Oct 2013
                  • 41
                  • canada
                  #128
                  Yes, I did flash it back and it worked. But it still had the password, of course. I believe I mentioned all that in my previous posts.
                  • duder
                    • Oct 2013
                    • 41
                    • canada
                    #129
                    Any update? Should I try the file you provided? If so, which 8MB should I use in conjunction with it?
                    I am tempted to just put it back the way it was and use the machine with a locked BIOS. I was able to install windows if I start the installation in another computer.
                    • duder
                      • Oct 2013
                      • 41
                      • canada
                      #130
                      Okay - I just flashed that file back and the machine is working ... again. It still has a BIOS password of course. Windows still works. I will just leave it like that. Life is too short for this!
                      I wanted to try the 16MB BIOS that you kindly provided me with, but you would not tell what to do with the "corrupted" 8MB BIOS.
                      • Stefan Steff
                        • Mar 2024
                        • 357
                        • Romania
                        #131
                        Please try this combo.
                        Flash both.
                        • duder
                          • Oct 2013
                          • 41
                          • canada
                          #132
                          Flash both.
                          Well, that worked perfectly. Password is gone and there were no security errors. Also, I was able to do a BIOS Update. Any chance you could give a brief explanation of your magic? Maybe I can learn something for the next time. Thanks again for all your help.
                          • ByteNest
                            • Sep 2025
                            • 4
                            • India
                            #133
                            hi,
                            i have a laptop hp elitebook 850 g7
                            it was no display
                            while checking the bios i find out the problem that's ME was corrupted and error shows like
                            " Error: Detected MFS Low Level File 12 which has not been parsed! " in ME analyser
                            to clear this issue i tried a my best but unfortunatly i failed
                            i don't have the same repository file .
                            Can anyone help me to fix this issue ,
                            ===== ME Details ===
                            Family :CSE ME
                            Version :14.1.70.2228
                            Chipset :CNP/CMP-LP B,A
                            SKU :Corporate LP
                            FW Update Support :Impossible
                            Flash Image Tool :14.0.47.1500
                            Production :Release
                            Release :Production
                            State :Initialized
                            CSME REV: 14.1.70.2228
                            SerialNumber:5CG1116BKG
                            ProductConfigurationID:8TP60AV
                            Board CT Number:PJSAR00WBEY0XZ
                            ProductName:HP EliteBook 850 G7 Notebook PC
                            UUID:E00176A7FE32B643BFD3D5147CF70B84
                            BuildID:20WWCMBT601#SABA#DABA
                            FeatureByte:3X476J6S6b7B7H7M7Q7W7m7saBaEapaqauawbUbhcAdUdpdqfPguhKhkjhk8mE.ye
                            MAC Address:14CB196DA47D
                            Thanks in Advance.
                            • DanielDacko
                              • Mar 2015
                              • 328
                              • Macedonia
                              #134
                              Originally posted by ByteNest
                              hi,
                              it was no display
                              Family :CSE ME
                              SKU :Corporate LP
                              Production :Release
                              Release :Production
                              State :Initialized
                              Thanks in Advance.
                              Good luck.
                              I don't provide help for people using CH341A and a clip.
                              • zenius
                                by zenius
                                12-08-2024, 06:13 AM
                              • to5it0
                                Need Clean BIOS/EC Bin File for Lenovo ThinkPad Yoga 11e 2H1703-27220F Rev. A Marked as U2501 on the motherboard.
                                by to5it0
                                Need Clean BIOS/EC Bin File for Lenovo ThinkPad Yoga 11e - Stuck with 0275 Error CMS
                                I am attempting a repair on a Lenovo ThinkPad Yoga 11e that is currently stuck at boot with the error: "0275 error CMS" even after setup new bios battery and will not allow me to enter the BIOS/Setup.
                                This is a critical issue that I believe requires flashing the BIOS chip directly using a programmer (e.g., CH341A/RT809H), as standard software updates or resets are not possible.
                                I have opened the laptop and identified the main BIOS chip...
                                Yesterday, 01:35 AM
                              • marc_ytos
                                request unlock HP EliteBook 640 G11 password bios
                                by marc_ytos
                                Greetings, please request help to unlock 640 G11 password bios DA0X8VMB8G0 serial number 5CD4392RDF thank you very much in advance...
                                01-11-2025, 06:20 PM
                              • Nopslide
                                by Nopslide
                                04-01-2024, 04:27 PM
                              • Wutru
                                HP Elitebook 820 G4 BIOS repair assistance required
                                by Wutru
                                Hi guys,
                                If someone would be able to provide some expertise, I'd be very grateful.
                                BIOS Corruption - Cause
                                So I managed to corrupt my machine by installing linux and enrolling custom secure boot keys. I did choose to enroll the Microsoft keys as well, to prevent any potential bricking due to 3rd party drivers from HP being signed with those keys.
                                After doing that, and rebooting(it did boot, powerLED, fanspin etc.), the laptop did not give any video output on the LCD or video connectors. I think I was able to get in BIOS and trigger the beeper by pressing ESC....
                                09-06-2025, 10:32 AM
