elitebook 850 G7 password
  • bilen
    • Aug 2014
    • 637
    • istanbul
    Re: Hp 850 G7
    Originally posted by hoaca388
    Try and report :
    thanks this worked. I just had to write the bios.
    Can you teach how to do this?
    • hoaca388
      Badcaps
      • Jan 2022
      • 12421
      Re: elitebook 850 G7 password
      Your Me region has problem.
      Clear vss2 store of bios file.
      Change serial number by bites 00.00 in ec file.
      • bilen
        • Aug 2014
        • 637
        • istanbul
        I have the same problem with the same model device. but i can't fix it, can you help me? white screen after windows opens and updates
        device freeze
        how to remove swat device freeze.
        I think the windows key number registered in the bios becomes active when connected to the internet.
        • hoaca388
          Badcaps
          • Jan 2022
          • 12421
          device freeze
          Post more EC file.
          • hoaca388
            Badcaps
            • Jan 2022
            • 12421
            Originally posted by mah3r0
            I need bios dump file bin for hp 15-fa0031dx
            • FrankTJ
              • Jan 2023
              Dear all,
              Which chip should be read to remove the BIOS password?
              On my HP 850 G7 I have :
              - 1 Winbound W25Q80DV at the back of the motherboard
              - 1 MXIC MX25L12872F at the back of the motherboard
              - 1 Winbound W25Q256JV at the front of the motherboard
              Thanks for your help.
              • volinakis
                • Jan 2021
                • 2875
                • N/A
                #27
                Originally posted by FrankTJ
                Dear all,
                MX25L12872F and use RCUnlocker
                • FrankTJ
                  • Jan 2023
                  Thanks a lot,
                  I will give it a try and let you know.
                  • FrankTJ
                    • Jan 2023
                    I read the chip and used RCUnlocker.
                    It wiped out an 'NvramActiveRegn' section of about 2075 bytes in the bin file at offset 0x37000.
                    However, it was not able to detect the device type/name/serial...
                    Is that still OK? Should I resolder the chip back?
                    Regards,
                    • FrankTJ
                      • Jan 2023
                      I soldered the chip back and the laptop cannot boot.
                      The CapsLock key flashes 7 times then nothing.
                      Any hint?
                      Regards,
                      • AndrewL
                        • Sep 2022
                        I have one HP 850 G7 laptop, whick locked by BIOS paswword after upgraded Windows 11 pro. I tried RCUnlocker_v_1.0 and not work. Can you help me?
                        • farouk_1994
                          • Mar 2021
                          • 399
                          • algeria
                          #32
                          Originally posted by andrewl
                          i have one hp 850 g7 laptop, whick locked by bios paswword after upgraded windows 11 pro. I tried rcunlocker_v_1.0 and not work.
                          Can hoaca388 help me?
                          flash only 16mb
                          • AndrewL
                            • Sep 2022
                            Originally posted by farouk_1994
                            flash only 16mb
                            Thank you. I will try it and report the result.
                            • Hachem25
                              • Aug 2021
                              • 54
                              • algeria
                              #34
                              i have a laptop elitebook 850 G7 bios without passwod but when i install w10 i stucked in wifi configuration (company e mail)
                              • farouk_1994
                                • Mar 2021
                                • 399
                                • algeria
                                #35
                                Post your dump here
                                • AndrewL
                                  • Sep 2022
                                  flash only 16mb
                                  I flashed the BIOS chip and not connected the CMOS battery and laptop battery back.
                                  1. connected ac adapter
                                  2. keyboard board light on after 20 seconds
                                  3. screen flashed, cpu fan run fast about 20 seconds
                                  4. power shutdown (auto), about 30 seconds
                                  5. power on and cpu fan run fast about 40 seconds
                                  6. restart, HP logo appear
                                  7. screes show BIOS password required. same before.
                                  any more help? I guess EC need some modified.
                                  • alfredposadas09
                                    • Aug 2020
                                    • 342
                                    • Philippines
                                    #37
                                    flash this
                                    • PARTH
                                      • Dec 2022
                                      • 6
                                      • usa
                                      #38
                                      Try this bios i have flash mine work fine make sure you flash 16mb bios chip will work
                                      • bilen
                                        • Aug 2014
                                        • 637
                                        • istanbul
                                        #39
                                        hp 850 g7 device freeze eror. please help me...
                                        • caprigtx
                                          • Mar 2022
                                          • 63
                                          • Netherlands
                                          #40
                                          Hello i have the same problem , bios pass . HP elitebook 850 G7 Sn5C116722N
                                          i have tryed to unlock these file,s , with hp unlocker and Rc unlocker , but no luck , pass is stil there.
                                          can you Clear the files for me .​
                                          • zenius
                                            by zenius
                                            12-08-2024, 06:13 AM
                                          • to5it0
                                            by to5it0
                                            10-24-2025, 01:35 AM
                                          • marc_ytos
                                            request unlock HP EliteBook 640 G11 password bios
                                            by marc_ytos
                                            Greetings, please request help to unlock 640 G11 password bios DA0X8VMB8G0 serial number 5CD4392RDF thank you very much in advance...
                                            01-11-2025, 06:20 PM
                                          • Nopslide
                                            HP Omen 15-dh0052nf power-on & bios password
                                            by Nopslide
                                            Hello everyone, I come here to tell you my problem regarding the power-on password. It is not a bios reset demand, and i can't have any access to windows. This is the bios and power-on password that is blocking all other things.
                                            My Omen 15-dh0052nf purchased second-hand was configured with the bios password upon purchase (very simple password :P ).
                                            Having decided to sell it in order to get something more powerful, I reset all BIOS settings and set a blank administrator password. But the power-on password cannot be changed to a blank one so I let the actual password set....
                                            04-01-2024, 04:27 PM
                                          • Wutru
                                            HP Elitebook 820 G4 BIOS repair assistance required
                                            by Wutru
                                            Hi guys,
                                            If someone would be able to provide some expertise, I'd be very grateful.
                                            BIOS Corruption - Cause
                                            So I managed to corrupt my machine by installing linux and enrolling custom secure boot keys. I did choose to enroll the Microsoft keys as well, to prevent any potential bricking due to 3rd party drivers from HP being signed with those keys.
                                            After doing that, and rebooting(it did boot, powerLED, fanspin etc.), the laptop did not give any video output on the LCD or video connectors. I think I was able to get in BIOS and trigger the beeper by pressing ESC....
                                            09-06-2025, 10:32 AM
