elitebook 850 G7 password
Thanks, but that did not work either. I wrote that to the chip and then read it back and compared them - they match. I turned on the machine and got a solid caps lock for maybe 45 seconds. It then turned off. I turned it on again and got the same 7 flashes of capslock & numlock.Comment
Thanks, but that did not work either. I wrote that to the chip and then read it back and compared them - they match. I turned on the machine and got a solid caps lock for maybe 45 seconds. It then turned off. I turned it on again and got the same 7 flashes of capslock & numlock.↵
​https://www.badcaps.net/donateComment
Ok - Here it is. I read it three times and did comparison.Attached FilesComment
The old file you uploaded before this one is corrupted!
Now try this patch, good luck broAttached FilesComment
Thank you. Okay, you are saying that the very first file I uploaded (8MB) was corrupted. I can accept that, but the system was working with it. It just had a BIOS password.
My question now is what 8MB file should I use in conjunction with this 16MB file that you just gave me?Comment
Any update? Should I try the file you provided? If so, which 8MB should I use in conjunction with it?
I am tempted to just put it back the way it was and use the machine with a locked BIOS. I was able to install windows if I start the installation in another computer.Comment
I wanted to try the 16MB BIOS that you kindly provided me with, but you would not tell what to do with the "corrupted" 8MB BIOS.Comment
Okay - I just flashed that file back and the machine is working ... again. It still has a BIOS password of course. Windows still works. I will just leave it like that. Life is too short for this!
Flash both.Attached FilesComment
Well, that worked perfectly. Password is gone and there were no security errors. Also, I was able to do a BIOS Update. Any chance you could give a brief explanation of your magic? Maybe I can learn something for the next time. Thanks again for all your help.Comment
Channel: BIOS Requests ONLY!
by marc_ytosGreetings, please request help to unlock 640 G11 password bios DA0X8VMB8G0 serial number 5CD4392RDF thank you very much in advance...
by NopslideHello everyone, I come here to tell you my problem regarding the power-on password. It is not a bios reset demand, and i can't have any access to windows. This is the bios and power-on password that is blocking all other things.
Having decided to sell it in order to get something more powerful, I reset all BIOS settings and set a blank administrator password. But the power-on password cannot be changed to a blank one so I let the actual password set....-
by WutruHi guys,
If someone would be able to provide some expertise, I'd be very grateful.
BIOS Corruption - Cause
So I managed to corrupt my machine by installing linux and enrolling custom secure boot keys. I did choose to enroll the Microsoft keys as well, to prevent any potential bricking due to 3rd party drivers from HP being signed with those keys.
After doing that, and rebooting(it did boot, powerLED, fanspin etc.), the laptop did not give any video output on the LCD or video connectors. I think I was able to get in BIOS and trigger the beeper by pressing ESC....-
by outsiderHello
I removed the BIOS password thanks to the help of one of the friends of this forum.
https://www.badcaps.net/forum/troubl...61#post3637661
The batch from which the password was removed works correctly but... after some time, the BIOS password is set again, I reprogrammed the batch with the removed password, it's ok, there is no password, I set my password, ok, I can enter the BIOS with my password but...-
- Loading...
