Guest - Try our new boardview, Bios, & schematic search. Over 1.1 million files for download!
elitebook 850 G7 password
  • Sebastian Thomas
    • Oct 2024
    • 6
    Originally posted by Stefan Steff
    There are cases when both BIOS chips must be patched...
    Write this main BIOS
    Hi Stefan, I was finally succesfull yesterday and experienced something weird but maybe normal. I disassembled the Laptop to reach the 16MB IC on the backside, flashed the unlocked BIOS that I had already and dumped again. However the dumped file still had a password in spite of the unlocked version I had flashed before. Maybe it was my mistake because I didn't blank the IC before I flashed, so I tried that and after everything was blank I could finally flash the unlocked File and double check that it worked. So I learned that its mandatory to wipe the old version at first. Anyways. I also flashed your File to the main IC and now there is no password anymore but a Warning. "There is a problem with the Endpoint Security Controller on this device. Please ask HP for maintenance" Do you have any idea what I can do here? Is it possible to install a new HP Bios in the official way? Thank you until here
    • Stefan Steff
      • Mar 2024
      • 479
      #62
      Weird...if you remove only the password from EC the Endpoint Security Controller error must not pop up because the DMI data in both chips are the same...
      Write this main BIOS and enter this DMI information:
      Description: HP EliteBook 850 G7 Notebook
      Serial Number: 5CG12213X2
      Product Number: 1J6F3EA#ABD
      Board CT Number: PJRZD00WBF81WE
      BuildId(BID): 20WWCMDT601#SABD#DABD
      Feature Byte: 3X476J6S6b7B7H7M7Q7W7m7saBaEapaqauawbUbhcAdUdpdqfAfPfXguhKhkj4jhk8mEnV.dr
      MAC Address: 3C-18-A0-C2-F5-9E​
      • djimy
        • Sep 2019
        • 8
        • dzdz
        #63
        Originally posted by bbanana
        Serial Number: 5CG11827RS
        Product Number: 8TP60AV
        CT Number: PJSAR00WBF42IQ
        Description: HP EliteBook 850 G7 Notebook PC
        build_id: 20WWCMCT601#SABD#DABD
        Feature Byte: 3X476J6S6b7B7H7M7Q7W7m7saBaEapaqauawbUbhcAdUdpdqfPfXguhKhkjhk8mE.Df
        MAC Address: 14-CB-19-C5-05-9C​
        thank you very much worked perfectly without any issues
        • CornholioGSM
          • Feb 2014
          • 266
          • CZECH
          #64
          Hello, please help me with unlock 850 g7. I have tried RCunlocker on 16mb and 32mb but it is still locked
          HP 850 g7
          SN# 5CG0444B5X
          ProID 1J5U6EA#BCM
          • Blaze Tech
            Learner
            • 307
            • Ghana
            #65
            HP 850 g7
            SN# 5CG0444B5X
            ProID 1J5U6EA#BCM
            try
            • minhdigital
              • Nov 2022
              • 768
              • Vietnam
              #66
              HP 850 g7
              SN# 5CG0444B5X
              ProID 1J5U6EA#BCM
              Send to you
              • CornholioGSM
                • Feb 2014
                • 266
                • CZECH
                #67
                Originally posted by minhdigital
                Send to you
                Tested.
                First boot message with corrupted IME firmware - continue to recovery.
                After second boot still bios lock
                • CornholioGSM
                  • Feb 2014
                  • 266
                  • CZECH
                  #68
                  Originally posted by Blaze Tech
                  try
                  ...and with this file from you still locked too
                  • hoaca388
                    Badcaps
                    • Jan 2022
                    • 12664
                    #69
                    CTNumber_6JKLF519XE118P
                    Serial_5CG0444B5X
                    Sku_1J5U6EA#BCM
                    Fearture byte_3X476J6S6b7B7H7M7Q7W7m7saBaEapaqauawbUcAdUdpdqeMfAfPguhKhkjhk8mEmV.QA
                    BuildId_20WWCMBT601#SBCM#DBCM
                    • shiyab
                      • Sep 2023
                      • 2099
                      • india
                      #70
                      HP 850 g7
                      SN# 5CG0444B5X
                      ProID 1J5U6EA#BCM
                      try
                      • CornholioGSM
                        • Feb 2014
                        • 266
                        • CZECH
                        #71
                        Serial_5CG0444B5X
                        Sku_1J5U6EA#BCM
                        Your version is working
                        ...only fill serial etc.
                        Thank You
                        • Christian Seitz
                          • Dec 2024
                          • 13
                          • Deutschland
                          #72
                          Hello, I hope someone can help me with my password on an HP Elitebook 850 G7
                          System S73 Ver. 1.15
                          SN:
                          5CG10293PM
                          SKU: 1J6F5EA#ABD
                          I have attached all the information and added an image file with all the system information
                          Thank you
                          • hoaca388
                            Badcaps
                            • Jan 2022
                            • 12664
                            #73
                            SN:
                            5CG10293PM
                            SKU: 1J6F5EA#ABD
                            Thank you
                            Unlocked
                            • Christian Seitz
                              • Dec 2024
                              • 13
                              • Deutschland
                              #74
                              Unlocked
                              Thank you so much, it's perfect, you're the best Thanks alot
                              • bert-bert
                                • Oct 2024
                                • 30
                                • Austria
                                #75
                                I have an EliteBook 850 G7 with password lock.
                                Unfortunately I currently only have an adapter for the WSON 8x6 W25Q256JVEN 32MB chip, but not for the WSON 6x5 W25Q128JVPQ 16MB chip.
                                Is it possible to remove the password by only programming the 32MB chip like it was possible on an EliteBook 850 G8 with the instructions from the "840-G8-Patch.txt" somewhere else in this forum? The instructions from that file does not work in the G7.
                                I'd prefer instructions how to patch the BIOS file myself, but can also upload this 32MB file.
                                Thank you in advance!
                                • moshu
                                  • Oct 2024
                                  • 66
                                  • Ireand
                                  #76
                                  I have a HP EliteBook G7 with Bios locked.
                                  I've used the RCUnlocker ​on the 16MB chip, but the password is still there.
                                  I've read the 32MB chip as well, but the RCUnlocker is not recognizing as being the right chip.
                                  Please help to unlock
                                  RMN:HSN-I36C-5
                                  SN 5CG0505B82
                                  PRODID 26D03EC#ABU
                                  • Stefan Steff
                                    • Mar 2024
                                    • 479
                                    #77
                                    RMN:HSN-I36C-5
                                    SN 5CG0505B82
                                    PRODID 26D03EC#ABU
                                    Here you are mate.
                                    Program only this attached dump, the other (32Mb) leave it as is.
                                    • moshu
                                      • Oct 2024
                                      • 66
                                      • Ireand
                                      #78
                                      Here you are mate.
                                      Thanks Stefan, it worked eventually, but after writing the chip the verify step was failing "STATUS REG ERROR at 0001 Buffer Value : 0x02 --- IC value : 0x3F" using T48 programmer. The CH341 didn't highlighted any error so I've put the chip back to MB and seems no issues.
                                      In the end, the RCUnlocker is not supporting this model? What is the workaround?
                                      • Stefan Steff
                                        • Mar 2024
                                        • 479
                                        #79
                                        I don't use RCUnlocker just edit the bin file manually with HxD hexeditor.
                                        • Chalaka
                                          • Aug 2020
                                          • 14
                                          • Sri Lanka
                                          #80
                                          No Display Please fix
                                          HP Elitebook 850 G7
                                          SN = 5CG044702S
                                          • zenius
                                            by zenius
                                            12-08-2024, 06:13 AM
                                          • to5it0
                                            by to5it0
                                            10-24-2025, 01:35 AM
                                          • marc_ytos
                                            request unlock HP EliteBook 640 G11 password bios
                                            by marc_ytos
                                            Greetings, please request help to unlock 640 G11 password bios DA0X8VMB8G0 serial number 5CD4392RDF thank you very much in advance...
                                            01-11-2025, 06:20 PM
                                          • Nopslide
                                            HP Omen 15-dh0052nf power-on & bios password
                                            by Nopslide
                                            Hello everyone, I come here to tell you my problem regarding the power-on password. It is not a bios reset demand, and i can't have any access to windows. This is the bios and power-on password that is blocking all other things.
                                            My Omen 15-dh0052nf purchased second-hand was configured with the bios password upon purchase (very simple password :P ).
                                            Having decided to sell it in order to get something more powerful, I reset all BIOS settings and set a blank administrator password. But the power-on password cannot be changed to a blank one so I let the actual password set....
                                            04-01-2024, 04:27 PM
                                          • Wutru
                                            HP Elitebook 820 G4 BIOS repair assistance required
                                            by Wutru
                                            Hi guys,
                                            If someone would be able to provide some expertise, I'd be very grateful.
                                            BIOS Corruption - Cause
                                            So I managed to corrupt my machine by installing linux and enrolling custom secure boot keys. I did choose to enroll the Microsoft keys as well, to prevent any potential bricking due to 3rd party drivers from HP being signed with those keys.
                                            After doing that, and rebooting(it did boot, powerLED, fanspin etc.), the laptop did not give any video output on the LCD or video connectors. I think I was able to get in BIOS and trigger the beeper by pressing ESC....
                                            09-06-2025, 10:32 AM
