elitebook 850 G7 password
  • Jari Oostvogels
    • Apr 2024
    • 8
    • Nederland
    #101
    Can someone help me to remove a bios password?
    HP Elitebook 850 G7
    Board number: CAMELLIA-6050A3140901-MB-A01
    SN: 5CG1129VTY
      SMDFlea commented
      Editing a comment
      Thread merged.
  • hoaca388
    Badcaps
    • Jan 2022
    • 12427
    #102
    HP Elitebook 850 G7
    SN: 5CG1129VTY
    Post bios backup.
    • Jari Oostvogels
      • Apr 2024
      • 8
      • Nederland
      #103
      Sorry that I've forgotten to add the file.
      • Jari Oostvogels
        • Apr 2024
        • 8
        • Nederland
        #104
        I have 3 chips on the board
        On back: MX25V8035F - This one has 1MB
        On Back: 25Q128JV - This one Looks empty
        On Front: 25q256JVEN - This one has 32MB
        I have added the 1MB file
        • volinakis
          • Jan 2021
          • 2875
          • N/A
          #105
          read 25Q128JV and use RCUnlocker on it
          • Jari Oostvogels
            • Apr 2024
            • 8
            • Nederland
            #106
            Thanks, but now the laptop is not starting up. Capslock and numlock are flashing. What can i try next?
            • johnnypicnic
              • Jul 2025
              • 9
              Need some help getting passed Endpoint Security Controller problem. I think I lost the original bios or mislabelled it. Been trying to use some other saved bios with the 18EA048-190FFFF-25FB8.mps script to clean the ME but I get 5 caps lock.
              SN: 5CG1205FT8
              • Jari Oostvogels
                • Apr 2024
                • 8
                • Nederland
                #108
                HP Elitebook 850 G7
                SN: 5CG1129VTY
                Bios Password unlock. Already tried RCU, but not working.
                On Front: 25q256JVEN - This one has 32MB​
                • josebml
                  • Nov 2015
                  • 40
                  • spain
                  #109
                  Hello, I received an 850 G7 computer that looked like a prototype, it had no serial number or any information in the BIOS. I tried multiple BIOSes from the forum and with these BIOSes I attached, the computer boots, but it takes a very long time and runs very slowly, just at startup it takes almost 1 minute and 40 seconds. Can this be fixed? As I mentioned, there is no DMI data for the computer because the BIOSes were empty. Thank you very much.
                    • 22215
                    It isn`t empty, use RCUnlocker on that backup
                    BIOS guides, methods, resources and tools
                    https://www.badcaps.net/forum/troubl...rces-and-tools
                    • Jari Oostvogels
                      • Apr 2024
                      • 8
                      • Nederland
                      #111
                      SMDFleaI did it and it worked — the password is removed.
                      But after that I get the Endpoint Security Controller problem. I tried to fix that as well, but every time the BIOS doesn’t work.
                      I followed the other post, but I didn’t get the last step.
                        • 22215
                        Do you mean you used the endpoint script ? ,if you did then cleaning the ME firmware would be the next thing to try
                        • Jari Oostvogels
                          • Apr 2024
                          • 8
                          • Nederland
                          #113
                          No, when I turn on the laptop, I get the message: HP Endpoint Security Controller problem.
                          After pressing Enter, the laptop just starts up without problems. I have zero experience cleaning the ME firmware. Is there a place that can help me with that?
                            • 22215
                            Use the endpoint patcher script with the main bios https://www.badcaps.net/forum/troubl...security-error post #4 .Read the README.txt file for step by step instructions
                            Get the DMI from your main bios with Rex98`s tool - https://www.badcaps.net/forum/troubl...57-hp-dmi-tool
                            • duder
                              • Oct 2013
                              • 41
                              • canada
                              #115
                              HP Elitebook 850 G7
                              ProdID 230X8UP#ABA
                              SN# 5CG105709Y
                              I used RCUnlocker on the 16MB chip. It did not report any errors. I program the IC and now it won't boot. 7 Flashes Capslock & Numlock. Any help would be greatly appreciated.
                              • duder
                                • Oct 2013
                                • 41
                                • canada
                                #116
                                Do I need to do this?
                                1) open Original File with HP DMI Editor to GET DMI Data
                                2) Press OK to patch your dump
                                3) flash patched File
                                4) first boot will delay few Minutes
                                5) Very Important Step go to Bios and reset to factory default
                                (FIRST MAIN PAGE TAB)
                                6) restart and eneter bios
                                7)password cleared successfully
                                8) Write Original DMI DATA Back
                                • hoaca388
                                  Badcaps
                                  • Jan 2022
                                  • 12427
                                  #117
                                  Check the solder
                                  • duder
                                    • Oct 2013
                                    • 41
                                    • canada
                                    #118
                                    Originally posted by hoaca388
                                    Check the solder
                                    Thank you for that. I did check my solder and it is fine. I did not even remove the chip as there are solder pads all around it. I don't see any bridges or missing connections. The resistors all seem to be intact. I even did a read after the write and compared them with no issues. Are there any other suggestions?
                                    • hoaca388
                                      Badcaps
                                      • Jan 2022
                                      • 12427
                                      #119
                                      Be careful, you may have lost a resistor or capacitor near the bios chip.
                                      • duder
                                        • Oct 2013
                                        • 41
                                        • canada
                                        #120
                                        OK - I double checked again and I did not see any resistors missing. So, I erased the chip and programmed my original backup. Now the machine is back to normal operation with a BIOS password. So, obviously nothing wrong with my soldering. Also, I did a read on the "unlocked BIOS" before erasing it and compared it to the read that I had taken just after writing the "unlocked BIOS" and found they are now different. Powering it up must have changed the contents.
                                        Do I need to do something with the main BIOS as well to remove the BIOS password?
                                        • zenius
                                          by zenius
                                          12-08-2024, 06:13 AM
                                        • to5it0
                                          by to5it0
                                          10-24-2025, 01:35 AM
                                        • marc_ytos
                                          request unlock HP EliteBook 640 G11 password bios
                                          by marc_ytos
                                          Greetings, please request help to unlock 640 G11 password bios DA0X8VMB8G0 serial number 5CD4392RDF thank you very much in advance...
                                          01-11-2025, 06:20 PM
                                        • Nopslide
                                          HP Omen 15-dh0052nf power-on & bios password
                                          by Nopslide
                                          Hello everyone, I come here to tell you my problem regarding the power-on password. It is not a bios reset demand, and i can't have any access to windows. This is the bios and power-on password that is blocking all other things.
                                          My Omen 15-dh0052nf purchased second-hand was configured with the bios password upon purchase (very simple password :P ).
                                          Having decided to sell it in order to get something more powerful, I reset all BIOS settings and set a blank administrator password. But the power-on password cannot be changed to a blank one so I let the actual password set....
                                          04-01-2024, 04:27 PM
                                        • Wutru
                                          HP Elitebook 820 G4 BIOS repair assistance required
                                          by Wutru
                                          Hi guys,
                                          If someone would be able to provide some expertise, I'd be very grateful.
                                          BIOS Corruption - Cause
                                          So I managed to corrupt my machine by installing linux and enrolling custom secure boot keys. I did choose to enroll the Microsoft keys as well, to prevent any potential bricking due to 3rd party drivers from HP being signed with those keys.
                                          After doing that, and rebooting(it did boot, powerLED, fanspin etc.), the laptop did not give any video output on the LCD or video connectors. I think I was able to get in BIOS and trigger the beeper by pressing ESC....
                                          09-06-2025, 10:32 AM
