elitebook 850 G7 password
  • ERRA
    • Sep 2025
    • 44
    • Morocco
    #121
    Originally posted by duder
    OK - I double checked again and I did not see any resistors missing. So, I erased the chip and programmed my original backup. Now the machine is back to normal operation with a BIOS password. So, obviously nothing wrong with my soldering. Also, I did a read on the "unlocked BIOS" before erasing it and compared it to the read that I had taken just after writing the "unlocked BIOS" and found they are now different. Powering it up must have changed the contents.
    Do I need to do something with the main BIOS as well to remove the BIOS password?
    TRY THIS
    • duder
      • Oct 2013
      • 37
      • canada
      #122
      Thanks, but that did not work either. I wrote that to the chip and then read it back and compared them - they match. I turned on the machine and got a solid caps lock for maybe 45 seconds. It then turned off. I turned it on again and got the same 7 flashes of capslock & numlock.
      • hoaca388
        Badcaps
        • Jan 2022
        • 12272
        #123
        Post main bios file.
        ​https://www.badcaps.net/donate
        • duder
          • Oct 2013
          • 37
          • canada
          #124
          Ok - Here it is. I read it three times and did comparison.
          • ERRA
            • Sep 2025
            • 44
            • Morocco
            #125
            The old file you uploaded before this one is corrupted!
            Now try this patch, good luck bro
            • duder
              • Oct 2013
              • 37
              • canada
              #126
              Thank you. Okay, you are saying that the very first file I uploaded (8MB) was corrupted. I can accept that, but the system was working with it. It just had a BIOS password.
              My question now is what 8MB file should I use in conjunction with this 16MB file that you just gave me?
              • ERRA
                • Sep 2025
                • 44
                • Morocco
                #127
                The system was working with it, i can accept that! But have you flashed that file back to the chip and pc worked ??
                • duder
                  • Oct 2013
                  • 37
                  • canada
                  #128
                  Yes, I did flash it back and it worked. But it still had the password, of course. I believe I mentioned all that in my previous posts.
                  • duder
                    • Oct 2013
                    • 37
                    • canada
                    #129
                    Any update? Should I try the file you provided? If so, which 8MB should I use in conjunction with it?
                    I am tempted to just put it back the way it was and use the machine with a locked BIOS. I was able to install windows if I start the installation in another computer.
                    • duder
                      • Oct 2013
                      • 37
                      • canada
                      #130
                      Okay - I just flashed that file back and the machine is working ... again. It still has a BIOS password of course. Windows still works. I will just leave it like that. Life is too short for this!
                      I wanted to try the 16MB BIOS that you kindly provided me with, but you would not tell what to do with the "corrupted" 8MB BIOS.
                      • Stefan Steff
                        • Mar 2024
                        • 345
                        • Romania
                        #131
                        Please try this combo.
                        Flash both.
                        • duder
                          • Oct 2013
                          • 37
                          • canada
                          #132
                          Flash both.
                          Well, that worked perfectly. Password is gone and there were no security errors. Also, I was able to do a BIOS Update. Any chance you could give a brief explanation of your magic? Maybe I can learn something for the next time. Thanks again for all your help.
                          • zenius
                            by zenius
                            12-08-2024, 06:13 AM
                          • marc_ytos
                            request unlock HP EliteBook 640 G11 password bios
                            by marc_ytos
                            Greetings, please request help to unlock 640 G11 password bios DA0X8VMB8G0 serial number 5CD4392RDF thank you very much in advance...
                            01-11-2025, 06:20 PM
                          • Nopslide
                            by Nopslide
                            04-01-2024, 04:27 PM
                          • Wutru
                            HP Elitebook 820 G4 BIOS repair assistance required
                            by Wutru
                            Hi guys,
                            If someone would be able to provide some expertise, I'd be very grateful.
                            BIOS Corruption - Cause
                            So I managed to corrupt my machine by installing linux and enrolling custom secure boot keys. I did choose to enroll the Microsoft keys as well, to prevent any potential bricking due to 3rd party drivers from HP being signed with those keys.
                            After doing that, and rebooting(it did boot, powerLED, fanspin etc.), the laptop did not give any video output on the LCD or video connectors. I think I was able to get in BIOS and trigger the beeper by pressing ESC....
                            09-06-2025, 10:32 AM
                          • outsider
                            Panasonic FZ-G1 MK5 - BIOS password returning
                            by outsider
                            Hello
                            I removed the BIOS password thanks to the help of one of the friends of this forum.
                            https://www.badcaps.net/forum/troubl...61#post3637661
                            The batch from which the password was removed works correctly but... after some time, the BIOS password is set again, I reprogrammed the batch with the removed password, it's ok, there is no password, I set my password, ok, I can enter the BIOS with my password but...
                            06-17-2025, 12:51 AM
