HP BIOS unlock tool
Become a Badcaps supporter
Thanks to all supporters.​
----------------------------------------------------------------------------------------------------------------------------------------------------------Doctrina est fructus dulcis, radicis amarae.. -
Re: HP BIOS unlock tool
The tool is doing the job nicely, but not always. Improved version is in development but because I will integrate it into a more automated tool, it will take more time to release the public version.
Also I am trying to use pogo-pins and 3D printed fixture to read and program wson8 chips. If anybody has a nice design for that, please do let me know.Comment
No need to be humble
, the tool is good enough
, with pretty good success rate. I can't wait to test Unlock Tool 2.0
----------------------------------------------------------------------------------------------------------------------------------------------------------Doctrina est fructus dulcis, radicis amarae..Comment
Hi. I have tried your tool with my HP Elitebook 8570p to unlock my bios admin password but I got 'Fatal Error Detected' error message. Will you please help me get rid of this bios password? Thank you very much.First check this site to see if your HP is supported for the great tool Mazzif has made.
http://mazzifsoftware.blogspot.com/p...os-unlock.html
If your model is newer and not in that list, you need to dump your bios, remove password from dump and reprogram bios with modified dump.
For that you need an SPI programmer like CH341A or Raspberry Pi with Flashrom or any other similar programmer. A soic8 clip is also useful so there wouldn't be a need to unsolder bios IC.
When you have your dump, just drag and drop your file on my HPUnlocker tool and it will create a new file. It will add "_unlocked" to the name of your locked file.
Just program the new file on your bios IC.
This unlocker should work on all Elite, EliteBook, ProBook and maybe some other series HP laptops.
For those of you who need to unlock large amounts of laptops, I recommend adding a registry entry:
Then modify that string addingCode:Computer\HKEY_CLASSES_ROOT\*\shell\HPUnlocker\command
This way you just need to right click your locked file and select HPUnlocker.Code:"C:\*location-of-exe*\HPUnlocker.exe" "%1"
If there are any issues, please do let me know so I can improve this tool.Comment
Last edited by Vesko356; 02-08-2020, 01:11 PM.----------------------------------------------------------------------------------------------------------------------------------------------------------
Reporting great success on my EliteBook 840 G1!
Desoldered the BIOS chip (with a help of a friend) and modified the bios dump using the unlocker tool.
Anyone worried that HP Unlocker is a virus I can confirm it is not the case. The application is a packaged Python script of circa 60 lines of elegant code! I have reverse enginered the .exe to confirm this. Some antiviruses can get a bit trigger happy because the .exe includes the whole Python runtime which includes libraries to work with sockets and other stuff that can be found in a trojan horse (or any other application).Comment
Well, yes and no. Right now, there aren't any such tools. If somebody finds a way to bypass the lock to write bios region using software, then yes, it would be possible. Mazzif tool for older HP-s is possible because of this. For newer HP-s thing are different.
Other way would be to brute-force the password but that will take an unknown amount of time.
So you are stuck with soic8 clip and/or soldering. It really isn't anything difficult. The problem is that you would need to invest in a few cheap tools. Tho it might be easier/cheaper to just find somebody who has these tools.Comment
Re: HP BIOS unlock tool --- 3d printed fixture idea
https://hackaday.com/2019/11/15/need...cture-needles/
if the link gets mangled, here's the end of it, just visit hackaday site and tack that on the end.
/2019/11/15/needling-your-projects-3d-printed-pcb-probing-jig-uses-accupuncture-needles/
It's an interesting 3d print using needles instead of pogo pins, it almost looks like a commercial product it's so nice. some good comments on that page too.
Originally posted by 829a98b998874d855ec2ae1c2637fbfaregarding this threads topic, I've been working on a HP EliteBook 840 G2, but still need to assimilate or osmosis all the knowledge before trying any efforts.
thanks in general to everyone providing tools, and confirming their success!Originally posted by hackadayLast edited by Stbhfhu6Xs; 02-19-2020, 01:43 AM. Reason: mistakenly stated g4 instead of g2, and comment formatting experimentation.Comment
There is nothing to install here - read the thread carefully, especially post #1:
by salim5566Hi guys i like to buy tool that automatic unlock bios or find password also can flash and repair bios ic, looking for good tool have good software that have 1 click and unlock bios any recommend good tool? looking for sony ps5 and and laptop bios
Thanks-
Channel: BIOS Requests ONLY!
by CityminHi all,
S/N : 5RNK9FFT70...-
by m1ch43lzmHi everyone
I noticed on the Xgpro software the BIOS backup files have extra bytes at the end when reading some chips, this is because the Xgpro software also reads the OTP region of those flash chips, and by default will append that region to the saved file
Programmer models: XGecu TL866II Plus / T48 / T56 / T76
Example: GD25LQ128D (1.8V), IC size is listed as 0x1000000 Bytes (16777216 bytes) + 0xC00 bytes, those extra 0xC00 bytes will be appended to the end of the saved file by default, resulting in a file size of 16780288 bytes
There's also an extra OTP Secu.R...-
by Forest79Hello,
However, the chip (a Macronix MX25L25673GMI-08G) has a size of 32 MB, and the BIOS file from the Lenovo website (extracted with UEFITool) has a little more than 16 MB. Thus, the software my acquaintance used (SiberiaProg v1.45, with a CH341A Programmer)...-
- Loading...
