HP BIOS unlock tool
  • xerano
    • May 2019
    • 10
    • Deutschland
    #41
    Re: HP BIOS unlock tool
    All Done i love U everything works Like a Charm ♥️
    • Kamvret
      • Nov 2019
      • 6
      • Indonesia
      #42
      Originally posted by zmedia
      no i dont have spaces or other characters
      you don't need to install this tool. just drag your file on this tool. its working on windows 10. or simple way:
      1. put your locked bin file in HPunlocker folder.
      2. open the folder (U will see 2 file, 1. your locked bin file 2. the tool it self)
      3. drag your locked bin file on the tool
      4. done u will get unlocked file
      *I hope U understand how to drag file
      • new
        • Oct 2014
        • 165
        • canada
        #43
        Originally posted by RethoricalCheese
        Do you have spaces or other odd characters in file name or directory?
        HPUnlocker tool detected as Trojan.Win32.Blocker.tq1S mean it has a virus on it !! anyone can confirm ?
        • RethoricalCheese
          • Mar 2013
          • 1519
          • Estonia
          #44
          Well yes, that is a problem I don't know how to fix. I am not a software engineer so I just used the easiest methods I know by just turning a python file into an exe using auto-py-to-exe. There is no trojan involved. I have the same problem, bypassed it by adding that exe to exceptions in my anti-virus.
          The problem is known and brought up here: https://nitratine.net/blog/post/issu...exe-as-a-virus
          I might need to find another way to make executable files which have less problems.
          • chilugsm
            • Togo
            #45
            i have the same problem Failed to execute script HPUnlocker
            • 530v8
              • May 2019
              • 42
              Just drop you bin file to the exe file and it automatically creates another bin file on the folder where the bin file located
              • zmedia
                • May 2018
                • 63
                • Algerie
                #47
                I tryed to unlock this dump its not work someone can help thanks
                Last edited by SMDFlea; 12-28-2019, 07:08 AM. Reason: Already asked in another thread
                • Maxpower3
                  Bad Veteran
                  • Feb 2018
                  • 1358
                  • France
                  #48
                  try
                    • 22216
                    Originally posted by Maxpower3
                    try
                    Thanks for trying to help @zmedia ,he made a thread 5 minutes before posting in this one for the same bios unlocking.If members can`t have any patience and keep double posting their threads will be removed.
                    • Maxpower3
                      Bad Veteran
                      • Feb 2018
                      • 1358
                      • France
                      #50
                      Ok I understand, I did not pay attention to that, best regards
                      • zmedia
                        • May 2018
                        • 63
                        • Algerie
                        #51
                        SORRY AND THANK U Maxpower3 MERCI
                        • e900
                          • 26
                          Hi First time doing this, I have a x360 Elitebook, I have a SOIC8 clip (purchased a kit from Ebay). I am trying to connect the SOIC 8 to the bios chip but the clips do not connect / reach to the flat gold plated / pins on the board.
                          Can anyone help how i can connect to the chip using the soic8? or is it a case for soldering to the board / remove the chip?
                          Edit - Just realished the bios type on the board is wson8..
                          • Zaraki7777
                            • Sep 2017
                            • 174
                            Thank you.
                            • RethoricalCheese
                              • Mar 2013
                              • 1519
                              • Estonia
                              #54
                              For wson8 you either need to unsolder chip and use the clip on chip only. Or solder wires to the gold pads.
                              • max67
                                • Jan 2020
                                • 5
                                • France
                                #55
                                I have a HP Elitebook 830 G5 and I don't have any access on :
                                1/ Windows 10
                                2/ Bios (locked with a password)
                                3/ Can't boot on USB
                                I just have the possibility to open cmd and have an access to my USB key. I downloaded the HPUnlocker program from Mazzif but I need the cmd one (not the windows one) Someone can upload it again for me ?
                                Regards and thxs u,
                                Max
                                • dammysholove
                                  • Jun 2017
                                  • 59
                                  • nigeria
                                  #56
                                  1/ Windows 10
                                  Regards and thxs u,
                                  Max
                                  Mazzif tool cant unlock your system, u will need to remove the bios chip and program it with a new dump.. hope it helps
                                  • max67
                                    • Jan 2020
                                    • 5
                                    • France
                                    #57
                                    Thks for reply. Just need some help (if possible) with a good "how to". do you know a good one with a raspberry pi (using the gpio + a Test Clip SOIC8) ?
                                    • max67
                                      • Jan 2020
                                      • 5
                                      • France
                                      #58
                                      or there is an easier way to dump it with Test Clip SOIC8 ?
                                      • RethoricalCheese
                                        • Mar 2013
                                        • 1519
                                        • Estonia
                                        #59
                                        At home I use a raspberry + soic8 clip.
                                        Just install raspbian on raspberry. Enable SPI in settings. Install newest flashrom. Most of the information you need is here: https://www.flashrom.org/RaspberryPi
                                        • max67
                                          • Jan 2020
                                          • 5
                                          • France
                                          #60
                                          ok, i just did it with a ch341a with the last version of flashrom, someone can unlock my .bin ? thks in advance
                                          • salim5566
                                            loking for bio tool that hve all feature like ps5 bios and laptop bios unlock and repair 1 tool can do all please good tool?
                                            by salim5566
                                            Hi guys i like to buy tool that automatic unlock bios or find password also can flash and repair bios ic, looking for good tool have good software that have 1 click and unlock bios any recommend good tool? looking for sony ps5 and and laptop bios
                                            06-26-2025, 03:25 PM
                                          • to5it0
                                            by to5it0
                                            10-24-2025, 01:35 AM
                                          • zenius
                                            by zenius
                                            12-08-2024, 06:13 AM
                                          • Citymin
                                            by Citymin
                                            S/N : 5RNK9FFT70...
                                            08-05-2025, 05:12 AM
                                          • m1ch43lzm
                                            by m1ch43lzm
                                            Hi everyone
                                            09-06-2025, 05:47 PM
