Extract bios password from EliteBook 840 G8 Bios dump, possible?
    Re: Extract bios password from EliteBook 840 G8 Bios dump, possible?
    Originally posted by saman mawlod View Post
    can u help to remove passwword hp 830 g8
    G8 6050a3217501-mb-a01.
    Read the rules before posting:
    This thread is about EliteBook 840 G8, do NOT hijack threads.
    Become a Badcaps supporter
    Thanks to all supporters.​
      Originally posted by SMDFlea View Post
      Use a hex editor and you will.
      i did not find that kind of pattern . i upload my bios og 840g8
          Originally posted by mandrake87 View Post
          Let me know if it worked for you.-
          If the password came out, what is still maintained is absolute persistence module current state. it stays on and there is no way to disable it. can you disable that I would really appreciate it... thanks
            i also so another bios chip in my motherboard mxic chip, is it posibble that the swat lock is program there?
              Originally posted by vesko356 View Post
              i have onther case plase unlock
                  HP 840 G8 Bios Unlock
                  Can anyone help me to unlock it?
                  11th gen
                    https://www.badcaps.net/forum/showth...ghlight=840+G8
                    I removed the bios password with the method here. Thank you
                      unlock plz
                        Originally posted by alilaptops View Post
                        unlock plz
                        Try it than replay replay and replay
                          can someone help me clean my dump, customer switched off laptop while on bios update... now its stuck on boot-loop writing "FINAL STEP OF BIOS UPDATE IS IN PROGRESS"
                          EliteBook 840 G8 (6050A3426501-MB-A02 (1086) L2)
                            Here is your New BIOS, try this file with the Main chip and put your EC chip back.
                            Serial Number: 5CG2160B3X.
                            all donations are welcome,
                              [QUOTE=hardware1;1260073]Here is your New BIOS, try this file with the Main chip and put your EC chip back.
                              Serial Number: 5CG2160B3X.[/Q
                              Tried as you said but still stuck on the same bios update screen.. then restart itself again and again... i thing the issue is corrupted EC
                                Use the EC file from post #403, I have checked it and I can say it's suitable for your device.
                                It's a working locked EC and @Vesko356 already removed the Password from it, so give it a try.
                                  Hi i have Hp probook 840 g8 i damage EC chip desoldering. Possible to use other EC DUMP? Device have in EC chip gigadevice 25b256dyig, possible to use Mx25L25673G or need to use windbond or gigadevice that have QE. If any one can help. Thanks
                                    hello friends. I have this elitebook 840 g8, 11th gen.
                                    I need to remove bios password!
                                      hello guys .. i have a administrator password on my HP elitebook 840 G8
                                      this is the bios dump from the backside chip near the EC .
                                      thanks in advance
                                        thanks in advance
                                        Here is your unlocked bios without bios password. After desoldering, press F10 directly, go into the Bios, reset the security settings to factory defaults, reboot, go back into the Bios and restore the Bios factory defaults.
                                        Let me know if it worked.
