Dell G3 15 3500 bios help
  • mmccomputer
    • 71
    • France
    #141
    Originally posted by mmccomputer
    I am looking for a working bios for this model, I tried several without results (just the fans running at maximum and no display )​
    Dell G3 15 3500
    MB : G3 MLK N18P 19795-1 403YF$JA
    Service Tag : CM191B3
    this is my original bios
    • qayyum786
      • Aug 2018
      • 1959
      • INDIA
      #142
      Service Tag: CM191B3
      Try with new build
      Flash both
      Wait few minute after program file
      Must check with heatsink
      • mmccomputer
        • 71
        • France
        #143
        Try with new build
        Flash both
        thanks my freind but is not working
        • DOCTORNOTEBOOKS
          • Sep 2023
          • 3
          • brasil
          #144
          desculpe pela falha,
          nΓ£o consigo adicionar service tag
          Funciona mas o cooler estΓ‘ acelerado e dΓ‘ erro de tag, nΓ£o consigo adicionar pela bios
          Minha Tag HJQ9M83
          obrigado
          placa dell 3500 pcb selek g3 mlk n18p 19795-1
          • Vesko356
            VIP Moderator
            • Aug 2018
            • 4386
            • Bulgaria πŸ‡§πŸ‡¬
            #145
            Originally posted by DOCTORNOTEBOOKS
            I NEED TO ADD SARVICE TAG
            What does it mean? What exactly is the issue? Where's your bios backup?
            Do NOT post in all caps!
            Read the rules before posting
            You MUST:
            • Provide a BIOS/EC dump if possible
            • Attach files directly to your post instead of linking to external websites
            • Post what the problem is, be specific - black screen, no boot, running slow, password. Do NOT post "clean me", "clear bios", "clean bios", "fix bios", "bios need" or other such terms
            Become a Badcaps supporter
            Thanks to all supporters.​
            • BenCesur
              • Jun 2011
              • 35
              #146
              Originally posted by RJ_TECH
              Service tag. DZHT663
              Build New try and report
              add new service tag in bios
              Thank you very much. It works smoothly. Perfect working.
              • DOCTORNOTEBOOKS
                • Sep 2023
                • 3
                • brasil
                #147
                sorry for the mistake,
                I can't add service tag
                It works but the cooler is accelerated and gives a tag error, I can't add it through the bios
                My Tag HJQ9M83
                thanks
                dell board 3500 pcb selek g3 mlk n18p 19795-1​
                • RJ_TECH
                  • Jan 2022
                  • 20
                  • India
                  #148
                  My Tag HJQ9M83
                  thanks
                  Try a new bios from post #131
                  • DOCTORNOTEBOOKS
                    • Sep 2023
                    • 3
                    • brasil
                    #149
                    gratitude worked, being able to add the normal tag thank you al l​
                    • kostukas1985
                      • 15
                      • lithuania
                      #150
                      He you go. 100 % working bios with service tag add and manufactoring mode disable
                      Badcaps Electronics Repair Forum & Schematic Search
                      Last edited by Vesko356; 02-25-2024, 04:08 AM. Reason: External url removed. File attached to post from external link.
                      • qayyum786
                        • Aug 2018
                        • 1959
                        • INDIA
                        #151
                        Originally posted by kostukas1985
                        He you go. 100 % working bios with service tag add and manufactoring mode disable.
                        ❀️Extarnal link not allow❀️
                        https://www.badcaps.net/forum/showthread.php?t=103570​
                        • augustocs
                          • Jul 2019
                          • 8
                          • sΓ£o paulo
                          #152
                          post #131... Working perfectly. After recording, it did not include the service tag. It required a restart once to allow this.
                          Thank you, bios working, only one of several tested that worked.​
                          • wilsonjfj
                            • Feb 2020
                            • mina gerais
                            #153
                            Hello. Can you help me? I have the Dell G3 3500 P89F002 notebook. It only shows video the first few times after resetting the bios. But it turns on and the video appears the same as the attached image, the fans are at maximum and when you click to enter the setup it restarts without video and the orange and 7 white LEDs (LCD) blink twice. I switched to the 8mb and 16mb bios from the last post by member "kostukas1985" and it worked but it keeps giving the Service Tag message.
                            My Service Tag is 3JWR8G3
                            Thanks.​
                            • qayyum786
                              • Aug 2018
                              • 1959
                              • INDIA
                              #154
                              Thanks.
                              did you try to add service tag manually from bios setup ? if not than add your service tag in the bios setup problem should resolved
                              if yes and problome remain same than
                              Flash 8MB only from #131​ and use your 16mb old
                              • wilsonjfj
                                • Feb 2020
                                • mina gerais
                                #155
                                Flash 8MB only from #131 and use your 16mb old
                                Hello. I added the service tag yes. But the following is happening, when I restart or turn it off and on again, it doesn't show video. 2 orange and 7 white flashes (LCD display). But I already got a new screen and it's still the same thing. To show video again, just reset the bios or force it to turn on and off about 5 or 7 times until it shows video. But if you turn it off or restart it, it has no image and the LEDs blink like I said.
                                Can you tell me what it could be?
                                Thanks​
                                • frattainfo
                                  • Jun 2017
                                  • 15
                                  • Brazil
                                  #156
                                  Great! Working Perfectly! Thank you
                                  • lalodbs
                                    • Oct 2017
                                    • 16
                                    • mexico
                                    #157
                                    Hello, help motherboard: selek g3 mlk n18p 19795-1 when connecting, only the keyboard backlight turns on and it restarts. That's all it does without an image, without fans, it just cycles through the reboot, turning only the keyboard backlight on and off.
                                    CPQK463 service tag​
                                    • Markus1741
                                      • Sep 2020
                                      • 925
                                      • N/A
                                      #158
                                      Hello try this new file ...
                                      • lalodbs
                                        • Oct 2017
                                        • 16
                                        • mexico
                                        #159
                                        thank you so much. but it didn't work for me, it has the same error
                                        • Arsalan455
                                          • Oct 2019
                                          • 57
                                          • Pakistan
                                          #160
                                          100% ok thnak you
                                          • zenius
                                            by zenius
                                            12-08-2024, 06:13 AM
                                          • mikeybass
                                            by mikeybass
                                            04-23-2025, 04:30 PM
                                          • Akhlz001
                                            by Akhlz001
                                            09-20-2025, 07:15 PM
                                          • jhanra
                                            by jhanra
                                            in windows 11 sound driver compatibility, but overall its ok, for me i can deal with it, πŸ˜…πŸ˜…πŸ˜…...
                                            11-02-2024, 04:19 AM
                                          • gizaha
                                            by gizaha
                                            02-13-2024, 07:18 AM
