Need UEFI Password Removed from my Surface Pro 5 BIOS DUMP
Hello Help Me Pls,,
Surface Pro 1796 8/256gb
SN 048033372753
M1007506-015
After Password Clean My Touch Not Working (In UEFI n Windows)
Thank YouāAttached Filesif you find these attachements useful please consider making a small donation to the site
Every donation made will go towards server fees and maintenance costs.Comment
I have tried, but it still doesn't work, maybe there is an error, because this is my first job in bios, can you help me?
Hi!
Can somebody help me with the BIOS / UEFI password?
Surface Pro 1807, S/N 008908382253, original BIOS dump attached.
Thanks!āComment
all donations are welcome,
>>>>> click on this link to donate via PayPal. <<<<<
************************************************** ***********************************Comment
Can someone unlock this Surface pro 5 BIOS password pls
Thanks in advanceAttached Filesif you find these attachements useful please consider making a small donation to the site
tryu..Attached Filesif you find these attachements useful please consider making a small donation to the site
Hi Could some please help remove password. Surface pro 1796 s/n:023074581253.thanksAttached Filesif you find these attachements useful please consider making a small donation to the site
try..Attached Filesif you find these attachements useful please consider making a small donation to the site
tryAttached Filesif you find these attachements useful please consider making a small donation to the site
----------------------------------------------------------------------------------------------------------------------------------------------------------------------Comment
please clear uefi lock.
Surface Pro 1796. SN:022480581053āAttached Filesif you find these attachements useful please consider making a small donation to the site
Good day!
I have MS Surface Pro 5 LTE i5 8/256 (s/n: 008996380153)
Yesterday, touch has gone after windows (firmware) update. (Neither win nor UEFI).
I already try it with other display (i have one), but result is the same.
There is some disclaimer In link you provided:
Always check a working dump from the same model using FIT.If the working dump default setting for "Integrated Sensor Hub Supported" is set to "NO" then do not change any settings,clean the ME as normal.
If your working dump models default setting for "Integrated Sensor Hub Supported" is set to "NO" and cleaning the ME firmware does not make the touchscreen work it could be a fault with the screen.ā
So, I need working dump.
And if you know topic about "how to dump UEFI from your Surface Pro device" - please provide link.
Please help.
Regards!Comment
by ArkzGHey guys, I have an "ASUS TUF Gaming A15 FA506NF (2021)" that's locked with a UEFI password, I need to reprogram the BIOS chip but can't find a clean ".bin" file for this specific model, I've tried the official BIOS updates from ASUS support page, but they're 32MB updaters that don't extract to a usable 2MB .bin file for direct chip programming.
What I currently have available:
- Model: FA506NF (2021)
- BIOS chip: GD25LQ16 (16Mbit/2MB)
- Tools: CH341A programmer ready to use
Does anyone have either a clean 2MB .bin dump of this model,...-
Channel: BIOS Requests ONLY!
by Buzzfuzz2kHi Everyone,
I'm facing a problem with a locked bios with a password and i can't find how to remove it...
The small computer is only booting on a M2 ssd Windows partition and i get a "signed partition error" if i try to boot on the same SSD with another Os (linux for example).
the Computer is a Unowhy small pc
N° UYM6524702229
After failling trying to boot on other "none Windows" partition, i wanted to try to remove the bios password.
My first attempt was to get the bios dump from windows...-
by dell_biosHi everyone,
I'm working on removing an administrative BIOS lock (Supervisor/Admin Password) on a laptop.
The board has three SPI flash chips:
- W25Q64FV (main BIOS)
- W25Q32FV (EC/TPM)
- W25X10CL (configuration)
I was able to read the dump from the W25Q64FV chip, CRC32 = 0x3DE23E27.
The dump contains protection that needs to be removed.
If anyone has a clean or unlocked BIOS dump for W25Q64FV, Iād really appreciate it!
Iām also happy to share my dump for comparison if needed.
Laptop model: [please specify, e.g....-
by AhariHi all,
I...-
by traxformaniaHello,
I'm using TONGFANG "GM7TG7P" model laptop for over 3 years and i'm entering the same bios administrator password everyday. My laptop has Aptio BIOS (American Megatrends, AMI).
But today it's not accepting my password. I'm %100 sure i'm entering the correct password.
I'm trying to reset my bios without success.
I tried :
-I removed the BIOS battery and main battery. Waited for a long time but it didn't work. They already stated in the user manual that the password will not be reset even if the batteries... - Loading...
