Need unlocked BIOS dump for W25Q64FV (Admin Password removal)
  • dell_bios
    • Oct 2025
    • belgium
    I'm working on removing an administrative BIOS lock (Supervisor/Admin Password) on a laptop.
    The board has three SPI flash chips:
    - W25Q64FV (main BIOS)
    - W25Q32FV (EC/TPM)
    - W25X10CL (configuration)
    I was able to read the dump from the W25Q64FV chip, CRC32 = 0x3DE23E27.
    The dump contains protection that needs to be removed.
    If anyone has a clean or unlocked BIOS dump for W25Q64FV, I’d really appreciate it!
    I’m also happy to share my dump for comparison if needed.
    Laptop model: [please specify, e.g. HP EliteBook 830 G5]
    Programmer: CH341A
    Flashing via clip, with board power disconnected.
    Thanks in advance!
    • 25731
    Type the laptop serial number, full name and model, motherboard model, etc.
    read the forum rules..https://www.badcaps.net/forum/troubl...before-posting
    • makxzx
      HP x360 Convertible-Need Bios Password Removal-Unlocked Dump Attatched
      by makxzx
      I purchased an HP x360 Convertible laptop from eBay, but it arrives locked with a BIOS administrator password.
      I have attached my original .bin backup file to this post. I successfully used a CH341A programmer combined with a 1.8V logic level adapter and NeoProgrammer to read it. The software successfully queried the chip and identified it as a 1.8V Macronix MX25U12873F.
      Could someone please clear the password container blocks from my attached dump file so I can flash it back to the motherboard?
      Thank you!...
      10-03-2026, 11:53 PM
    • BigPete
      Panasonic LED TV Dead after EMMC dump
      by BigPete
      I recently took a dump of the 4GB EMMC dump of a new and working Panasonic main board and now the TV won't turn on.
      The dump was successful and the program finished without errors.
      I used a XGecu T48 to do the dump.
      I actually had a few issues getting it to go and I might write up something as a bit of a guide as I couldn't find much in English to go from.
      One thing I did do was connect a 1kohm resistor from the 1.2v line to the RSTN pin as per the instructions, could this have caused issues?
      I also shorted out the crystal of the adjoining ECU together and at one...
      03-15-2026, 03:08 AM
    • Buzzfuzz2k
      Bios password removal on a Unowhy dump
      by Buzzfuzz2k
      Hi Everyone,
      I'm facing a problem with a locked bios with a password and i can't find how to remove it...
      The small computer is only booting on a M2 ssd Windows partition and i get a "signed partition error" if i try to boot on the same SSD with another Os (linux for example).
      the Computer is a Unowhy small pc
      N° UYM6524702229
      After failling trying to boot on other "none Windows" partition, i wanted to try to remove the bios password.
      My first attempt was to get the bios dump from windows...
      11-13-2023, 07:37 AM
    • Darksands
      Need clean BIOS dump: Dell Pro 14 Plus PB14250 (CMF34 Rev: A00) - Freezes on Dell logo
      by Darksands
      [SOLVED]
      Laptop: Dell Pro 14 Plus, PB14250
      Motherboard: PWB CMF34, Rev (A00).
      Service Tag: 3YLQ8F4.
      CPU: Intel® Core™ Ultra 5 processor 238V (8M Cache, up to 4.70 GHz) FCBGAEXX, Tray. Ordering Code: QQ8076606106. Spec Code: SRPN5.
      BIOS Flash Chip: Winbond 25R512NWEQ.
      BIOS version (via ME Analyzer by TechNoDev): 20.0.11.1815_COR, FITC 20.0.0.1329, SKU Corporate.
      Symptoms & History: Initially, a black screen appeared, then the laptop rebooted, entered BIOS Recovery, and the flashing process started. After the flash and a reboot, it freezes...
      09-13-2026, 03:15 AM
    • s.izadbakhsh
      Monster Abra A5 V19.3 - Tongfang GM5AGFO MB V1.1 - BIOS Dump Clean ME Request
      by s.izadbakhsh
      I need a working BIOS dump for a Monster Abra A5 V19.3 laptop.
      Here are the motherboard details:
      • Model: Tongfang GM5AGFO MB V1.1
      • CPU: Intel 12th Gen (Alder Lake)
      The laptop is currently in a boot loop (turns on and off immediately). I have desoldered the SPI Flash IC (GigaDevice GD25R256DYIG) and read the original 32MB dump.
      Note: I have already tried testing another BIOS dump found online, but the laptop behaves exactly the same (on/off boot loop) with both the original dump and the other file.
      Could someone please provide...
      06-24-2026, 09:10 AM
