LENOVO BIOS AUTO-PATCHER for Supervisor Password Removal
  • Pygo86
    • Oct 2022
    • 13
    • Deutschland
    #2521
    Re: LENOVO BIOS AUTO-PATCHER for Supervisor Password Removal
    Worked on a T580!
    TYVM!
    Next Project:
    X13 Gen 2 Supervisor passworded
    • w1zard90
      • Jan 2021
      • 12
      • Serbia
      #2522
      Originally posted by w1zard90
      Please patch me the bios
      Lenovo carbon x1 gen 3
      11246-1 LGS-1MB 48.4RQ01.011
      Or explain to me the way how to remove the password, I own CH341A and SAS IO Programmer
      any help?
      • Vesko356
        VIP Moderator
        • Aug 2018
        • 4386
        • Bulgaria 🇧🇬
        #2523
        any help?
        Read the rules before posting:
        RULES UPDATE for BIOS requests/offers *AVOID BANNING, READ BEFORE POSTING*:
        Originally posted by piernov
        BIOS request section has been getting a little bit wild lately, therefore we need to be more strict with the rules, both for people requesting help and people offering help.
        — You are requesting help
        If you do not abide by the following rules, your post will be deleted.
        You MUST:
        Become a Badcaps supporter
        Thanks to all supporters.
        • gline
          Learning
          • May 2014
          • 5
          • Ireland
          #2524
          Thanks to the op, it worked flawlessly on an L480, 1st try.
          I used a CH341a with a SOP8 clip. I read the bios with Colibri, AsProgrammer and CH341a programmer software and compared using HashTools. I used the latest CH341a drivers.
          • aqibi_
            • May 2023
            • 5
            • England
            #2525
            Thank you!
            • _demool_
              • May 2023
              • 3
              • tokyo
              #2526
              It worked perfectly on a T450, many thanks to the creator for his enormous work!
              and this great community! ����
              • qba82
                • Jun 2021
                • 10
                • Poland
                #2527
                It works on Lenovo A485, just removed password. Thanks.
                badcaps.net
                • santi2019
                  • Jun 2019
                  • 9
                  • españa
                  #2528
                  Worked on a Lenovo T460S!
                  Thanks!!
                  • Yannis Honda
                    • May 2023
                    • United Kingdom
                    #2529
                    Originally posted by Knucklegrumble
                    Hello everyone...
                    Hi. Will it work with lenovo p73 9gen intel . as I am not even able to set time clock or boot from ssd. The os was working butt got wipe . I found it had bios password cant get access now . Any help will be great. I do have the dump from the Bios and its a 32meg if that helps in any way. Yannis.
                    • Vesko356
                      VIP Moderator
                      • Aug 2018
                      • 4386
                      • Bulgaria 🇧🇬
                      #2530
                      With some trial and error I was able to reliably patch BIOS dumps for SVP-locked Lenovo machines up to the 8th generation
                      https://www.badcaps.net/forum/showpo...postcount=1825
                        • 31264
                        no, i tried on a p73 - no luck.
                        • DrSnuggles
                          • Dec 2021
                          • 4
                          Tried on a L560, probably with up to date bios. Did not work.
                          Other people seem to have the same issue as me in that thread, since I could replicate those steps with the autopatcher https://www.badcaps.net/forum/showth...t=72789&page=3
                          Used a T48 with a decent soic8 mount. Just gets the fan on high rpm for around 2 seconds and then it turns off with the powerbutton lit up in green/yellow and does not post. Tried pulling out the drive, putting a new one in, using the locked drive.
                          if anyone has a tip for me what I could try next, please let me know.
                          • DrSnuggles
                            • Dec 2021
                            • 4
                            I got it to work!!!
                            Maybe it was due to testing windows 11 right now. Someone here mentioned hashtools. I tried it out and saw that my generated bios had a different hash. So I just switched to linux and after altering the python command in autopatcher to python3 it worked flawlessly
                            • elkhiyhie
                              • Jun 2020
                              • 35
                              • philippines
                              #2534
                              not working in t14 gen 2 ..
                              • Jaduselhombre
                                • Jul 2022
                                • 4
                                • Polska
                                #2535
                                I need help, I downloaded the python software, after starting the autopatcher file, it shows up for a second and turns off. I don't know where to look for a solution.
                                  • 22012
                                  Read the instructions carefully.
                                  "From command line use either autopatch.cmd (Windows) or autopatch.sh (Linux) as follows:
                                  • aungkyawmoe
                                    • May 2023
                                    • Myanmar
                                    #2537
                                    T480 (Type 20L5, 20L6) Laptop (ThinkPad) - Type 20L6
                                    Intel(R) Core(TM) i5-8350U CPU @ 1.70GHz
                                    BIOS version:*N24ET72W*1.47
                                    Can I remove supervisor password from T480 and can someone explain step by step me? I have to solve it coz inside battery does not work and also I'm not an IT guy😥
                                    • alfredposadas09
                                      • Aug 2020
                                      • 342
                                      • Philippines
                                      #2538
                                      upload bios we will remove it for u
                                        • 22012
                                        The instructions are at post #1 ,you will need an SPI programmer to backup the chip.
                                        https://www.badcaps.net/forum/showpo...postcount=2523
                                        • speeedh
                                          • May 2023
                                          • 5
                                          • alger
                                          #2540
                                          Lenovo x240
                                          NM-A091
                                          After flashing... I restored the original file
                                          When I turn on the pc, it just shows a black screen
                                          Plz help
                                          And thnks
                                          • macabook
                                            by macabook
                                            🧩 Initial Issue
                                            07-24-2025, 02:17 PM
                                          • pirati
                                            by pirati
                                            10-27-2025, 04:20 PM
                                          • Vesko356
                                            by Vesko356
                                            08-11-2023, 03:27 AM
                                          • jbonavita
                                            by jbonavita
                                            Some issues
                                            Things I tried
                                            04-29-2025, 09:38 PM
                                          • zenius
                                            by zenius
                                            12-08-2024, 06:13 AM
