  • mielta
    • Apr 2015
    • 368
    Hello
    Please can anyone unlock Bios
    • Markus1741
      • Sep 2020
      • 1000
      • N/A
      #2462
      Originally posted by mielta
      Hello
      Hello try this patch from your original file.
      Good luck ...
      • mielta
        • Apr 2015
        • 368
        Works
        Thanks a Lot
        • smic717394
          • Jun 2017
          • 136
          • Spain
          #2464
          How did you solved the problem? I have the same problem. L390 nothing but beeping
          Originally posted by CornholioGSM
          Hello hello,
          i have here L390. Dump from bios (25Q128) was verified, patched and flashed back.
          Problem is , that i have nothing os screen - i can hear only ugly melody
          HDD was removed, tamper switch not found on mobo
          *****SOLVED******
          • neonchaos
            • Mar 2023
            Hello All,
            I have a t470 (Type 20JM-000BUS) with an svp i am trying to unlock. I successfully gotten to the TPM certificate reset, erased the bios chip then reflashed the original bios, opened up the computer, hit f1 to enter bios and... the svp is still there? I've attempted 3 times with no luck. Does anyone know what im missing?
            • splus11
              • May 2016
              • 74
              • Poland
              #2466
              Originally posted by dresq1027
              Try this. If it doesn't work, you'll need someone else's help who is smarter than me. All I did was ran it through the patch program on page 1 of this thread.
              Thank you for your help . Unfortunately, it didn't help. The computer beeps
              • neonchaos
                • Mar 2023
                Originally posted by neonchaos
                Hello All,
                Here are copies of my bios and patched bios...
                • b0n3v
                  • Mar 2023
                  • 7
                  • EU
                  #2468
                  Looking for some who can remove SP password from BIOS, the machine is T14 G1 AMD ID:TP00103G , Type:20UE-S0VT00. I have CH431 and TTL866 Plus.
                  • JoPsE
                    • Mar 2023
                    Please help me with my T560. I make all off with instruktion but not funktion.
                    Sorry for my bad English.
                    • b0n3v
                      • Mar 2023
                      • 7
                      • EU
                      #2470
                      Originally posted by b0n3v
                      Looking for some who can remove SPV password from BIOS, the machine is T14 G1 AMD ID:TP00103G , Type:20UE-S0VT00. I have CH431 and TTL866 Plus.
                      I try to do factory reset and now have 0199 error for too many tries of SPV, can I reset(disable warning) only this to make it boot again? Is this setting is stored on some "easy" eeprom?
                      • reformatt
                        • Feb 2020
                        • 1747
                        Worked perfectly on a X1 Yoga 3rd gen. Mucho gracias
                        • neonchaos
                          • Mar 2023
                          I figured it out! I had to remove the locked drive only AFTER i flashed the original bios back. Then i could boot from a usb. Fyi for anyone else that may have this issue.
                          • Mcenziee
                            • Apr 2023
                            • germany
                            #2473
                            can someone help me to remove the SP Password from Bios from my
                            ThinkBook 14s Yoga ITL - Type 20WE ?
                            • jrmbanaag12
                              • Mar 2023
                              Good day, tried this earlier on one of our laptops. I managed to patch it and flash in BIOS setup. After placing the original bios.bin the laptop does not turn on. Laptop is Lenovo T470
                              • PhotoVoltaic
                                • Apr 2023
                                #2475
                                Does this method also work with Think Centre desktop Systems? I have an M920q with an i5 8500T that needs SVP clearing so I can disable Secure boot, to run Linux
                                • Echoo
                                  • Apr 2018
                                  • 105
                                  • Budapest
                                  #2476
                                  Hello!
                                  Is there a way to remove the T590 bios password? I've seen a few videos on YouTube, but none of them are detailed. They are obviously keeping the secret
                                  • moises_84
                                    • Mar 2023
                                    • buenos aires
                                    #2477
                                    Max Power 3, thank you very much
                                    it worked on a lenovo T440s
                                    worked perfect tested
                                    • nekko
                                      • Apr 2023
                                      • mexico
                                      #2478
                                      is to easy, i unlock the x2800 with this method, sae help this video
                                      https://www.youtube.com/watch?v=AX_e9jlhbAg
                                      its the same but anyther lenovo.
                                      • kordex35
                                        • Apr 2015
                                        • 49
                                        • Polska
                                        #2479
                                        T590 can be tried with this method described in this post
                                          VIP Moderator
                                          • Aug 2018
                                          • 4387
                                          • Bulgaria 🇧🇬
                                          • Gadget & motorcycle addicted
                                          #2480
                                          Use "Search this Thread" tool:
                                          https://www.badcaps.net/forum/showpo...postcount=1948
                                          Become a Badcaps supporter
                                          Thanks to all supporters.
                                          • macabook
                                            by macabook
                                            🧩 Initial Issue
                                            07-24-2025, 02:17 PM
                                          • Trademark
                                            Acer Predator Triton 16 PT16-51-99GL (DA0ZQDMB8AE Rev. E) - Looking for original 32MB BIOS dump (Winbond W25Q256JVEN)
                                            by Trademark
                                            I’m hoping someone can help me locate a verified original BIOS dump for my Acer laptop.
                                            This is NOT a BIOS password removal request.
                                            I’m looking for an original 32MB SPI BIOS dump to use as a reference in case my BIOS firmware is corrupted. My plan is to first dump and back up my own BIOS as soon as my programmer arrives. I am not planning to blindly flash someone else’s BIOS.
                                            Laptop Information
                                            • Model: Acer Predator Triton 16 PT16-51-99GL
                                            • Motherboard: DA0ZQDMB8AE Rev. E
                                            • Main SPI flash: Winbond W25Q256JVEN (32MB)
                                            • Secondary
                                            07-22-2026, 08:57 AM
                                          • cr4zychriss
                                            by cr4zychriss
                                            • Rebrand: PC Specialist
                                            11-14-2025, 04:04 PM
                                          • TopPop
                                            Dell Latitude 5530 BIOS Password Removal Attempted but I Broke the Laptop
                                            by TopPop
                                            Sorry for the long story. I have a Dell Latitude 5530 (i7) laptop (South Peak 15 MLK MB DDR4 203102-1 FK8VG$JA) with an admin BIOS password that I want to remove. Service Tag: HYKFPT3. Other than that the laptop worked OK.
                                            I found a CH341A Black and went looking for the BIOS chip on the motherboard. After trying to read one chip that was a firmware chip but not the BIOS I think I found the BIOS chip labeled Winbond 25Q256JVEN. Altogether I think I found 4 different firmware chips in the laptop. The BIOS chip is a WSON8 6x8. I used the CH341A, NeoProgrammer, and a cheap pogo pin clip...
                                            12-14-2025, 09:40 PM
                                          • Arzigol
                                            Acer Nitro Lite 16 NL16-71G (V1.19) - BIOS Unlock / Advanced Menu / CFG Lock
                                            by Arzigol
                                            Hello everyone!
                                            I am looking for experienced BIOS modders who can help analyze or unlock the BIOS of my Acer Nitro Lite 16 NL16-71G.
                                            Please note that this post was written with the help of ChatGPT because my English is limited. My native language is Russian. If anything is unclear, please let me know and I will do my best to explain.
                                            Laptop Information
                                            Model:
                                            Motherboard:
                                            CTE_NB_NL160P1G_RTH (NB6807C)
                                            CPU:
                                            Intel...
                                            07-12-2026, 02:27 AM
