  • olegi
    • Jun 2012
    • 63
    The EC chip is not MEC is NPCX997KAABX. Not sure this chip is programmable. There is a 16 Mb chip. I have only board view for this model.
    • Pascal Komlassan
      • Jan 2017
      • 808
      • TOGO
      #2782
      Originally posted by olegi
      Thank you It works very well.
      good
      • adam911
        • Oct 2021
        • 10
        • Poland
        #2783
        I need help with Lenovo T470P. It has COMPUTRANCE and i want to disable it like i do with 50+ lenovo T470/T480 but in this laptop i have problem.
        1.First I turn on laptop and add supervisor password (only with supervisor password autopatcher can reset computrance)
        2.Turn off computer and dissasembly all battery and power adapter
        3.Remove bios chip
        4.read bios
        5.run autopather but it says bios file is wrong or corrupted
        6.solder bios chip without reflashing it
        and now i have a problem. Laptop don't start. only turn on power button and keyboard backlight on 1 sek and nothing else. It's possible that COMPUTRANCE lock computer? I try to flash bios again, and with other dump but still not working.
        Sorry for my english and thanks for reply
        • aldopc
          • Jul 2017
          • 477
          • Chilito
          #2784
          Ok, I didn't realize it was amd, I know that from 10th gen upwards in Intel CPUs it goes in kbc... but amd I have a doubt...
          • Hasiya
            • Sep 2023
            • Srilanka
            #2785
            Originally posted by ednar88
            thanks .. after returning the native bios opiate ask for a password....?
            Lenovo t440 biso password how remover
              • 22159
              https://www.badcaps.net/forum/showthread.php?t=103526
              https://www.badcaps.net/forum/showpo...42&postcount=4
              3.7.2. DXE password bypass driver injection (2012-2018)
              • olegi
                • Jun 2012
                • 63
                Hi I have a bios password on Lenovo T14s gen 3 NM-E422 with AMD CPU. There are 2 chips 32mb and 16mb . Did not have a luck with patching bios my self. Can someone help.
                Any one know how to do it ?
                • ddhlawi
                  • Feb 2017
                  • 169
                  • algerian
                  #2788
                  How to remove password Lenovo X390
                    • 22159
                    Use the forum search function and read some of the X390 threads. Also you must post the serial number and motherboard model,as per the rules
                    You MUST:
                    • frphpaz
                      • Aug 2023
                      • Guatemala
                      #2790
                      Hello wonderful group, I need your wise advice, to start, thanks to you, I have finally managed to remove the administrator lock from my Lenovo T470 and it now allows me to modify the bios, now my problem is that when I connect the SSD m2 PCI NVME hard drive immediately The password lock appears, but when I turn on the PC without said hard drive there, it does let me enter the bios or execute USB boot, when I do the process to install the operating system, it does not recognize the hard drive, is there a way I can format and thus be able to install the operating system?
                      In an improvised way, using a mechanical external hard drive, I was able to install the operating system but only with that external hard drive installed. I would like your advice so I can use it in the normal way. I thank you very much for your attention and I hope for your help and suggestions to try to to be able to use my computer correctly.
                      • Angabow
                        • Jan 2015
                        • Sudan
                        #2791
                        I failed to use Lenovo autopatcher script because it opens and closes itself so please some one help remove svp of my t470
                        Attached bios image
                        • hoaca388
                          Badcaps
                          • Jan 2022
                          • 12423
                          #2792
                          Attached bios image
                          Drag and drop .bin file into Autopach.cmd.
                          • Markus1741
                            • Sep 2020
                            • 969
                            • N/A
                            #2793
                            Attached bios image
                            try ...
                            • Kranatos
                              • Aug 2023
                              The software cannot read my bios file. My bios chip is Winbond w25q256jw
                                • 22159
                                What software, what programmer if you don`t give enough details how can anyone help .If you can`t make a proper backup you won`t be able to write to the chip.
                                Quote:
                                When flashing a BIOS always make a backup first. Take 2 or 3 different dumps and make sure they are identical.
                                On Windows, you can use the command "fc /b" to check if two dumps are identical.
                                Make sure that the dumps looks good, i.e. not filled with 0x00 or 0xFF. After compression, if the file has a size of only a few kilobytes, the EEPROM was most likely not read properly.
                                Additionally, please read the FAQ at: https://www.badcaps.net/forum/showthread.php?t=98665.
                                Also you must post the laptop model number and serial number
                                RULES UPDATE for BIOS requests/offers *AVOID BANNING, READ BEFORE POSTING* https://www.badcaps.net/forum/showthread.php?t=103570
                                • Angabow
                                  • Jan 2015
                                  • Sudan
                                  #2796
                                  try ...
                                  Thanks alot I will try and feedb ack
                                  • Kranatos
                                    • Aug 2023
                                    I meant the Auto-patcher software, I dropped the BIN file into the patcher file but it does not start. My model is Thinkbook 16p Gen 3 ARH and SN is pf47e8e0
                                    • volinakis
                                      • Jan 2021
                                      • 2875
                                      • N/A
                                      #2798
                                      your dump is wrong, if chipset is W25Q256 it should be 32Mb and not 16Mb. Autopatcher doesn't work for your model, open a new thread and dump your bios again, it's 1,8V chipset if it is w25q256jw, if you use CH341A you have to use an adapter for 1.8V.
                                      • Zalman
                                        • May 2020
                                        • 32
                                        • UA
                                        #2799
                                        Man, I'm in the same boat with you. I have posted it here
                                        https://www.badcaps.net/forum/showpo...postcount=2665
                                        I'm leaning towards the idea that the EC firmware got damaged. I do not own the programmer that supports flashing the EC. So the plan is to send the board to a guy that can handle such stuff. I'll let you know if we succeed. If you manage to fix your system sooner, pls also let me know.
                                        • adeil
                                          • Oct 2015
                                          • belgique
                                          #2800
                                          hi
                                          please how to unlock lenovo l15 ryzen 7pro
                                          • macabook
                                            by macabook
                                            🧩 Initial Issue
                                            07-24-2025, 02:17 PM
                                          • cr4zychriss
                                            by cr4zychriss
                                            • Rebrand: PC Specialist
                                            11-14-2025, 04:04 PM
                                          • pirati
                                            by pirati
                                            10-27-2025, 04:20 PM
                                            by Vesko356
                                            08-11-2023, 03:27 AM
                                          • jbonavita
                                            by jbonavita
                                            Some issues
                                            Things I tried
                                            04-29-2025, 09:38 PM
