  • allkuhar
    • Oct 2021
    • Poland
    #2001
    Hello, could someone help me with my BIOS? I can't run this autopatcher on my PC. That's the BIOS from lenovo l440 with supervisor password.
    • ymifdal
      • Jan 2022
      • 120
      • Morocco
      #2002
      Sure, here you go
      • ymifdal
        • Jan 2022
        • 120
        • Morocco
        #2003
        Originally posted by phildefer
        Hello guys,
        Could you help me, please?
        I have a Lenovo T480. I read the bios, then generated the patched file with the autopatcher. Then I flashed the chipset (without unsoldering it).
        When I turned the T480 back on, I got a beep melody. Now, no sign of life. It doesn't turn on anymore. No beep.
        Could you please tell me what I should do? Are my files corrupted?
        Thank you very much for your help.
        Phil
        THE Melody sound! Happened to me once, left me wondering for 30mins then I discovered I was soldering the bios chip to the wrong emplacement
        I guess it isn't your case, since you did not unsolder anything. So, did you try disconnecting all power sources including the cmos battery for a while? before booting up the laptop again with the original bios dump
        • phildefer
          • Oct 2022
          • France
          #2004
          Thanks your help. I have tried with all power sources disconnecting... but without success.
          Perhaps another idea ?
          • Kristiano
            • Nov 2022
            • Poland
            #2005
            Hello. Could someone unlock this BIOS(supervisor) for me? Laptop t470s. I would be very grateful.
            • Vusal
              Senior Tech
              • Feb 2016
              • 44
              • Azerbaycan
              #2006
              hi
              ThinkPad t470 (NM-B081) password
              I need auto patch bios. thank you for now.
              • jetseth
                • Sep 2022
                • 7
                Thanks for the tool! It worked perfectly on a 3rd gen X1 Carbon.
                just as a note for anyone having a 5 short, 5 short beep issue at least with this model after flashing the patch, you need to remove the system board and disconnect the CR2016 battery that sits on the other side of the board, reattach the ribbon cables and power it on, afterwards you can flash the stock BIOS back and reconnect the CMOS battery
                • Vusal
                  Senior Tech
                  • Feb 2016
                  • 44
                  • Azerbaycan
                  #2008
                  Did you restore the old bios after patching?
                  • jetseth
                    • Sep 2022
                    • 7
                    Yeah, you need to flash the original "locked" BIOS, otherwise it'll keep trying to run the unlocking program
                    • Vusal
                      Senior Tech
                      • Feb 2016
                      • 44
                      • Azerbaycan
                      #2010
                      thanks
                      I think the patch file works with the program in EC. because in these models the password is stored in EC
                      • ymifdal
                        • Jan 2022
                        • 120
                        • Morocco
                        #2011
                        Nothing comes in mind unfortunately
                        BUMP
                        • Markus1741
                          • Sep 2020
                          • 946
                          • N/A
                          #2012
                          hi
                          Try this ...
                          • K7SBE
                            • Nov 2022
                            Just wanted to say Thank you!
                            The autopatcher worked perfectly for me on a T470 and a T480.
                            • oloboy
                              • Nov 2022
                              • france
                              #2014
                              Hi
                              when I try to unlock my bios for the L480 the script not generated any output file
                              WHY????
                              • oloboy
                                • Nov 2022
                                • france
                                #2015
                                Originally posted by TJJones94
                                I can confirm that is the Motherboard model, Would the ITE IO chip be on the back side of the board (opposite side to the ram).
                                Please see attached photos below.
                                have you solved your problem? how?
                                • dimba91
                                  • Nov 2022
                                  • Ukraine
                                  #2016
                                  Hi. Is it possible to remove BIOS password on lenovo thinkpad E14?
                                  • Kristiano
                                    • Nov 2022
                                    • Poland
                                    #2017
                                    Guys it worked on t470s. But I had to clear ME Region in patched bios because when I tried to boot without it laptop only plays a melody and dead. Thank you for this tool.
                                    //Remember to clear ME Region//
                                    to clean ME Region I used this guide:
                                    https://www.badcaps.net/forum/showthread.php?t=88533
                                    Thank you.
                                    • oloboy
                                      • Nov 2022
                                      • france
                                      #2018
                                      Originally posted by oloboy
                                      Hi
                                      WHY????
                                      Ok just a python path problem
                                      • johnplusjoy
                                        • Nov 2022
                                        • Portugal
                                        #2019
                                        Can anyone help me with this X1 Yoga 1st gen, 20frs09n05 bios?
                                        • hoaca388
                                          Badcaps
                                          • Jan 2022
                                          • 12322
                                          #2020
                                          Here
                                          • macabook
                                            by macabook
                                            🧩 Initial Issue
                                            07-24-2025, 02:17 PM
                                          • pirati
                                            by pirati
                                            Yesterday, 04:20 PM
                                            by Vesko356
                                            08-11-2023, 03:27 AM
                                          • jbonavita
                                            by jbonavita
                                            Some issues
                                            Things I tried
                                            04-29-2025, 09:38 PM
                                          • zenius
                                            by zenius
                                            12-08-2024, 06:13 AM
