  • Markus1741
    • Sep 2020
    • 1000
    • N/A
    #2201
    Originally posted by straki007
    Hi guys.
    I'm struggling here with my Thinkpad X250.
    Can't start after last night (apparently updates).
    My BIOS is locked and I don't know how to proceed with autopath.
    PORAD shows me that it saves the file, but it doesn't save it anywhere.
    Can you please help me unlock my BIOS?
    Thank you.
    Try this file ... build whith AUTO-PATCHER ...
    And read this ...
    https://www.badcaps.net/forum/showpo...52&postcount=1
    • straki007
      • Jan 2023
      • 6
      • Česko
      #2202
      Big thanks.
      But notebbok it beeps 5 times twice in a row and the screen is black.
      • Markus1741
        • Sep 2020
        • 1000
        • N/A
        #2203
        Big thanks.
        Hello Try this: Are all batteries removed Battery + CMOS
        If so, press the power button for more than 10 seconds.
        Reset NVRAM
        How would the BIOS be read out via clip or chip desoldered.
        A picture of the current chip would be helpful.
        Check if all capacitors and resistors around the chip are ok.
        Not that a resistor was moved when unsoldering.
        • Vlatchey
          • Sep 2022
          • Macedonia
          #2204
          Hello to all.
          I have Lenovo Thinkpad T470S with Supervisor Password.
          Read a lot of the post on here and I'm not sure what to do..
          Do I need to remove the bios and put on some programmer to get the bios dump and patch it, then to flash it (as it was written on the post #1) ?
          Or should I get a bios dump file with some software then patch it and flash it?
          I do not have a hardware programmer, can I use another patched bios file if there's any here available?
          • douha
            • Sep 2014
            • 44
            • maroc
            #2205
            Hi pleas can any one help me to unlock this lenovo l460 one chip bios
            • straki007
              • Jan 2023
              • 6
              • Česko
              #2206
              Reset NVRAM
              So disconnecting the battery didn't help.
              The chip was read on the board using the clip.
              All resistors seem to be in order.
              • Markus1741
                • Sep 2020
                • 1000
                • N/A
                #2207
                Try ...
                • straki007
                  • Jan 2023
                  • 6
                  • Česko
                  #2208
                  So no matter what I do, the result is still the same.
                  I unplugged the memory and it doesn't work.
                  Removed the batteries and it doesn't work.
                  I only have to beep 5 times 2 times in a row.
                  • Markus1741
                    • Sep 2020
                    • 1000
                    • N/A
                    #2209
                    Try this file from me ME Region Clean that work for me .....
                    • straki007
                      • Jan 2023
                      • 6
                      • Česko
                      #2210
                      Well
                      It doesn't work any other way
                      The advice will beep but it will start soon.
                      it wanted to set password and id.
                      But now it only writes ... To interrupt normal startup, press enter.
                      And nothing
                      • straki007
                        • Jan 2023
                        • 6
                        • Česko
                        #2211
                        Whoah.
                        Everything is in order.
                        After your edit, I loaded back my original BIOS and it's ok.
                        It no longer needs a password and runs.
                        Big thanks.
                        • GreaT
                          • Aug 2014
                          • 6
                          • Hungary
                          • Repairing things
                          #2212
                          I tried the autopatcher on E485, but I got a crc error message when I trying to enter the BIOS.
                          Could you please patch the the original?
                          Thanks,
                          • hardware1
                            • Sep 2021
                            • 2956
                            • N/A
                            #2213
                            Thanks,
                            Try this one.
                            all donations are welcome,
                            • douha
                              • Sep 2014
                              • 44
                              • maroc
                              #2214
                              Try ...
                              Hi friend i test this dump but the machine wont start only green led no fan pleas any sol
                              • sanjay123
                                • Aug 2018
                                • 33
                                • india
                                #2215
                                sir not work this patcher please guid me
                                • GreaT
                                  • Aug 2014
                                  • 6
                                  • Hungary
                                  • Repairing things
                                  #2216
                                  Try this one.
                                  Thanks,
                                  Unfortunately I am still having a bad crc message. Same as with the patcher.
                                  • Markus1741
                                    • Sep 2020
                                    • 1000
                                    • N/A
                                    #2217
                                    Try this file ...
                                    ME Clean from your file ...
                                    • mauri99
                                      • Dec 2022
                                      • 6
                                      • Switzerland
                                      #2218
                                      Hi all
                                      I bought a Lenovo X390 Yoga (Model 20NQ-S1C400) with unknown Supervisor Password on BIOS.
                                      I was able to read the BIOS dump with a CH341A and autopatched the file.
                                      Unfortunately, the patched BIOS doesn't work. The laptop just keeps beeping at startup and the screen is black.
                                      I repeated dumping the original BIOS and checked that the content of the files is the same. --> The dumped BIOS is correct.
                                      Writing again the original BIOS, the Laptop boots but I'm still not able to enter BIOS (because of the Supervisor Password).
                                      Here's the output of the autopatcher:
                                      autopatch "C:\Users\...\original_bios.bin"
                                      Using UEFIReplace to inject 2 DXE drivers...
                                      [1/2] BootOption (GUID e0746c42-d3f9-4f8b-b211-1410957b9ff5)
                                      [2/2] LenovoTranslateService (GUID 826bcf56-bac4-43f4-8ea1-8cdf0a121abd)
                                      Looking for volumes to patch...
                                      [1/1] NVRAM_EfiSystemNvDataFvGuid (checksum 2609h):
                                      Not found... Skipping.
                                      Done.
                                      PATCH FILE: original_bios_PATCHED.bin
                                      Good luck.
                                      Can anyone help me?
                                      What means the constant beeping at startup with the patched BIOS? Is the CRC wrong?
                                      Thanks in advance.
                                      Regards, M. Erni
                                      Hi all
                                      I bought a Lenovo X390 Yoga (Model 20NQ-S1C400 with i7 8th generation CPU) with unknown Supervisor Password on BIOS.
                                      I was able to read the BIOS dump with a CH341A and autopatched the file (https://www.badcaps.net/forum/showthread.php?t=87588).
                                      Unfortunately, the autopatched BIOS doesn't work. The laptop just keeps beeping at startup and the screen is black.
                                      I repeated dumping the original BIOS and double checked that the content of the files is the same. --> The dumped BIOS is correct.
                                      The BIOS chip is MX25L25673G
                                      The sticker on the mainboard indicates WKS FRU: 02HM794
                                      It's a 8th generation i7 Intel CPU inside
                                      Can anyone help me and remove the BIOS Supervisor Password?
                                      Thanks in advance.
                                      Regards, M. Erni
                                      • mauri99
                                        • Dec 2022
                                        • 6
                                        • Switzerland
                                        #2219
                                        Try this file ...
                                        btw: BIOS chip is MX25L25673G.
                                        • Markus1741
                                          • Sep 2020
                                          • 1000
                                          • N/A
                                          #2220
                                          Originally posted by mauri99
                                          Hi all
                                          Done.
                                          Good luck.
                                          Can anyone help me?
                                          Thanks in advance.
                                          Regards, M. Erni
                                          Sorry this will not work Yoga X380 yes AUTO-Patcher Yoga X390 no.
                                          Only goes from the 4th to the 8th Intel generation.
                                          The BIOS will have a self-healing function because of the beebs only.
                                          • macabook
                                            by macabook
                                            🧩 Initial Issue
                                            07-24-2025, 02:17 PM
                                          • Trademark
                                            Acer Predator Triton 16 PT16-51-99GL (DA0ZQDMB8AE Rev. E) - Looking for original 32MB BIOS dump (Winbond W25Q256JVEN)
                                            by Trademark
                                            I’m hoping someone can help me locate a verified original BIOS dump for my Acer laptop.
                                            This is NOT a BIOS password removal request.
                                            I’m looking for an original 32MB SPI BIOS dump to use as a reference in case my BIOS firmware is corrupted. My plan is to first dump and back up my own BIOS as soon as my programmer arrives. I am not planning to blindly flash someone else’s BIOS.
                                            Laptop Information
                                            • Model: Acer Predator Triton 16 PT16-51-99GL
                                            • Motherboard: DA0ZQDMB8AE Rev. E
                                            • Main SPI flash: Winbond W25Q256JVEN (32MB)
                                            • Secondary
                                            07-22-2026, 08:57 AM
                                          • cr4zychriss
                                            by cr4zychriss
                                            • Rebrand: PC Specialist
                                            11-14-2025, 04:04 PM
                                          • TopPop
                                            Dell Latitude 5530 BIOS Password Removal Attempted but I Broke the Laptop
                                            by TopPop
                                            Sorry for the long story. I have a Dell Latitude 5530 (i7) laptop (South Peak 15 MLK MB DDR4 203102-1 FK8VG$JA) with an admin BIOS password that I want to remove. Service Tag: HYKFPT3. Other than that the laptop worked OK.
                                            I found a CH341A Black and went looking for the BIOS chip on the motherboard. After trying to read one chip that was a firmware chip but not the BIOS I think I found the BIOS chip labeled Winbond 25Q256JVEN. Altogether I think I found 4 different firmware chips in the laptop. The BIOS chip is a WSON8 6x8. I used the CH341A, NeoProgrammer, and a cheap pogo pin clip...
                                            12-14-2025, 09:40 PM
                                          • Arzigol
                                            Acer Nitro Lite 16 NL16-71G (V1.19) - BIOS Unlock / Advanced Menu / CFG Lock
                                            by Arzigol
                                            Hello everyone!
                                            I am looking for experienced BIOS modders who can help analyze or unlock the BIOS of my Acer Nitro Lite 16 NL16-71G.
                                            Please note that this post was written with the help of ChatGPT because my English is limited. My native language is Russian. If anything is unclear, please let me know and I will do my best to explain.
                                            Laptop Information
                                            Model:
                                            Motherboard:
                                            CTE_NB_NL160P1G_RTH (NB6807C)
                                            CPU:
                                            Intel...
                                            07-12-2026, 02:27 AM
