Dell Xps 13 9370 bios
  • hoaca388
    Badcaps
    • Jan 2022
    • 12237
    #81
    Originally posted by 3mz3t
    Dell XPS 9370, ST: 1PP8HM2
    The machine does not turn on, when pressing the power button the keyboard lights up, but the machine turns off immediately.
    Starting the display test (power buttons + D) does light up the display and goes through the basic colors nicely. There's no short
    on the board, so I'm assuming a bios issue.
    MEAnalyzer reports one error for the bios dump: "Error: Detected CSE Extension 0x03 with wrong Partition Hash at FTPR > FTPR.man!"
    Anybody able to help?
    Thank you.
    XPS 13 9370
    Service Tag: 1PP8HM2
    • 3mz3t
      • Sep 2023
      • 13
      • Slovakia
      #82
      Originally posted by hoaca388
      XPS 13 9370
      It works, thank you!
      • skinner
        • Jun 2013
        • 58
        I'm looking for some help with this bios. The machine turns on, then off right away.
        st: 71XB0N2
        • kalilinux25
          • Mar 2018
          • 2089
          • ZAMBOANGA SIBUGAY
          #84
          st: 71XB0N2
          is it VPRO or non Vpro?
            • 21582
            Go to Dell support and enter the service tag. On the right side of the page you should see "View product specs" ,click on that to see the System Configuration . Expand the list and read it carefully. Every Dell can be checked this way, look for the CPU version (if the bios update has different CPU versions you will know which one is the right one) and vPro, non vPro ,vPro enabled or disabled
            • kalilinux25
              • Mar 2018
              • 2089
              • ZAMBOANGA SIBUGAY
              #86
              Wow, that was an amazing tip that will be a good thing to take note of on these Dell units. Thanks for the help. I i tried it for my self the unit is Non Vpro, ?
              • skinner
                • Jun 2013
                • 58
                It is indeed n-Vpro
                • skinner
                  • Jun 2013
                  • 58
                  It is indeed n-Vpro
                  Still looking for a little bit of help if possible. Thanks.
                  • Markus1741
                    • Sep 2020
                    • 889
                    • N/A
                    #89
                    Hello try this file perhaps it helps you ...
                    Service Tag: 63VN5S2
                    Good luck ....
                    • baiceanu_stefan
                      • Feb 2015
                      • 40
                      • Romania
                      #90
                      Originally posted by peste
                      Re: Dell Xps 13 9370 bios
                      try..
                      Confirm that the bios is working. Thank you!
                      • pat0500
                        • Jan 2022
                        • 4
                        • Nederland
                        #91
                        Thank you.
                        I have the same issue as 3mz3t
                        when i hold D and plug in charger the screen does self test, but when i try to turn on the laptop i just get blinking LEDs which indicate:
                        2 5 Invalid memory installed
                        I suspect bios issue, here is the bios file i read using my CH341A.
                        ST : 3FJ9TT2
                        EX : 7469710886
                        Reg Model : P82G
                        Reg Type No : P82G002
                        Thanks!​
                        • hoaca388
                          Badcaps
                          • Jan 2022
                          • 12237
                          #92
                          ST : 3FJ9TT2
                          EX : 7469710886
                          Reg Model : P82G
                          Thanks!​
                          TRy
                          • niggi
                            • May 2016
                            • 198
                            • UAE
                            #93
                            try..
                            yes ok file
                            • dscomputer
                              • Aug 2022
                              • 11
                              • pakistan
                              #94
                              Dell XPS 9370 BIOS fix needed.
                              51801
                                • 21582
                                51801
                                Post service tag, backup ,description of the problem etc,etc,etc
                                https://www.badcaps.net/forum/troubl...ore-posting​
                                • Marcello2233
                                  • Nov 2020
                                  • 4
                                  • Algeria
                                  #96
                                  HELLO
                                  can you PLEASE REMOVE BIOS PASSWORD this DELL XPS 13 9370
                                  CAZ60 LA-E671 rev 1.0
                                  service tag DGWNNV2
                                  • shiyab
                                    • Sep 2023
                                    • 1581
                                    • india
                                    #97
                                    Originally posted by Marcello2233
                                    HELLO
                                    service tag DGWNNV2
                                    hi try
                                    • ninsa
                                      • Dec 2018
                                      • 29
                                      • republica dominicana
                                      #98
                                      I have this dell xps 9370
                                      CAZ61 LA-E671P Motherboard with some issues.
                                      2 amber and 5 white.
                                      May be this a bios issue?
                                      there's the original bios file.​
                                      • peste
                                        • Dec 2016
                                        • 13335
                                        • ROMANIA
                                        #99
                                        post S/T, etc.
                                        read the forum rules..
                                        • ninsa
                                          • Dec 2018
                                          • 29
                                          #100
                                          ST: DP1VNQ2
                                          • Ahari
                                            by Ahari
                                            I...
                                            08-13-2025, 06:12 AM
                                          • mikeybass
                                            by mikeybass
                                            04-23-2025, 04:30 PM
                                          • Akhlz001
                                            by Akhlz001
                                            09-20-2025, 07:15 PM
                                          • jhanra
                                            by jhanra
                                            in windows 11 sound driver compatibility, but overall its ok, for me i can deal with it, 😅😅😅...
                                            11-02-2024, 04:19 AM
                                          • Habble7
                                            by Habble7
                                            Suspected Cause:
                                            Troubleshooting Attempts:
                                            05-22-2025, 07:28 AM
