Panasonic CF-54 Bios Password
    • 22401
    Re: Panasonic CF-54 Bios Password
    Originally posted by freeflight
    I got it. Looking through other bios dumps in this thread, I saw that the mac address is often found here 0x1000 and here 0x2000.
    I copied these lines of code from the backup bios and it didn't change anything. Then I realized that the problem was probably with the Windows system. It had somehow memorized the Mac's address and didn't change it. After reinstalling Windows, the problem was solved, and the Mac address changed to the one in the original bios.
    Changing only the MAC address bytes sometimes does not work, you have to copy the whole Gbe region. It can be extracted as-is with UEFITool, it shows the start address and file length in the info column on the right side.
    • freeflight
      • Feb 2019
      • 10
      • UA
      #422
      Thank you for the information
      • imran421
        • Apr 2020
        • 83
        Originally posted by hoaca388
        You must resolve the issue of hardware damage that arises.
        was able to fix the hardware issue. Change the screen and it worked. Thanks for the help.
        I also try to remove the bios passward for another laptop. Any one, please confirm if the bios password is remove. Attaching both bins.
          • 22401
          Provide the full machine model number, serial number (or Service tag, SNID) and the board model number (see https://www.badcaps.net/forum/showthread.php?t=88758 )
          • imran421
            • Apr 2020
            • 83
            Picture attached for serial number.
            • kocka104
              • Nov 2023
              • 11
              #426
              Anyone has a bios dump for cf-54mk1?
              model number is CF-54cy003ee
              serial number 6atca40941
              someone tried to remove password and they messed original dump.
              • volinakis
                • Jan 2021
                • 2887
                • N/A
                #427
                nope, you missed a spot
                • imran421
                  • Apr 2020
                  • 83
                  Thanks for the reply. I was able to remove it myself
                  • kocka104
                    • Nov 2023
                    • 11
                    #429
                    can someone help me to remove password? from cf-54mk1?
                    • volinakis
                      • Jan 2021
                      • 2887
                      • N/A
                      #430
                      serial number?
                      • kocka104
                        • Nov 2023
                        • 11
                        #431
                        sorry, forget it, I mentioned earlier above
                        • volinakis
                          • Jan 2021
                          • 2887
                          • N/A
                          #432
                          upload original bios, not your attempt to clear password.
                          • kocka104
                            • Nov 2023
                            • 11
                            #433
                            Unfortunatelly this is my only file what I have. I got laptop without bios file. I asked earlier If someone has a correct file but did not get answer. Managed to purchase a file online but it is password protected. This is the only file that boot the laptop. Any help would be appriciated
                            • flooodi
                              • Dec 2020
                              #434
                              I have a Panasonic CF-54BY009TG with password. There is only one area after "AMITSESetup" to clear but it didn't clear the password. Can you help me?
                              Serial number is 7CTCA19400.
                              Thank you!
                              • hoaca388
                                Badcaps
                                • Jan 2022
                                • 12498
                                #435
                                Originally posted by flooodi
                                hello,
                                i have a panasonic cf-54by009tg with password. There is only one area after "amitsesetup" to clear but it didn't clear the password. Can you help me?
                                Serial number is 7ctca19400.
                                Thank you!
                                wwwwww
                                ​https://www.badcaps.net/donate
                                • hoaca388
                                  Badcaps
                                  • Jan 2022
                                  • 12498
                                  #436
                                  unfortunatelly this is my only file what i have. I got laptop without bios file. I asked earlier if someone has a correct file but did not get answer. Managed to purchase a file online but it is password protected. This is the only file that boot the laptop. Any help would be appriciated
                                  wwwwwww
                                  • kocka104
                                    • Nov 2023
                                    • 11
                                    #437
                                    keep getting checksum error after verifying. Only power light flashes and does not boot
                                    • qayyum786
                                      • Aug 2018
                                      • 1959
                                      • INDIA
                                      #438
                                      once more
                                      • flooodi
                                        • Dec 2020
                                        #439
                                        wwwwww
                                        Thank you for your answser hoaca388!
                                        Tested but I still have bios password active.
                                        Best Regards!
                                        • flooodi
                                          • Dec 2020
                                          #440
                                          This solution worked for me.
                                          Thank you!
                                          • outsider
                                            Panasonic FZ-G1 MK5 - BIOS password returning
                                            by outsider
                                            Hello
                                            I removed the BIOS password thanks to the help of one of the friends of this forum.
                                            https://www.badcaps.net/forum/troubl...61#post3637661
                                            The batch from which the password was removed works correctly but... after some time, the BIOS password is set again, I reprogrammed the batch with the removed password, it's ok, there is no password, I set my password, ok, I can enter the BIOS with my password but...
                                            06-17-2025, 12:51 AM
                                          • zenius
                                            by zenius
                                            12-08-2024, 06:13 AM
                                          • traxformania
                                            TONGFANG "GM7TG7P" Bios Password Problem?
                                            by traxformania
                                            I'm using TONGFANG "GM7TG7P" model laptop for over 3 years and i'm entering the same bios administrator password everyday. My laptop has Aptio BIOS (American Megatrends, AMI).
                                            But today it's not accepting my password. I'm %100 sure i'm entering the correct password.
                                            I'm trying to reset my bios without success.
                                            I tried :
                                            -I removed the BIOS battery and main battery. Waited for a long time but it didn't work. They already stated in the user manual that the password will not be reset even if the batteries...
                                            11-15-2023, 07:32 AM
                                          • longmt1990
                                            Panasonic Cf-w5 bios password remove
                                            by longmt1990
                                            Hi, i have a Panasonic Cf-W5 with the bios password, I tried remove cmos but problem didnot solve.
                                            I uploaded the picture after remove cmos battery, It look like this is a Phoenix bios. The bios dump file in the link i attached
                                            Please help me remove bios password.
                                            Thank you so much
                                            07-06-2025, 10:50 PM
                                          • AquaMan Ua
                                            Problem with PANASONIC CF53 laptop after changing BIOS settings
                                            by AquaMan Ua
                                            Hello. I am asking you for a hint on how to solve the problem with my touchbook Panasonic CF53-2 standart model. After setting up the BIOS, the laptop displays the wrong image until Windows loads. (More precisely, it displays, but distorted, instead of the Panasonic image immediately after turning it on, it displays what is in photo #1 in the attached file) Then the image appears when Windows starts loading and then there are no problems with the screen until the reboot. If you enter the BIOS, just a black screen. If you connect an external screen, the image on it is the same as on the built-in...
                                            05-17-2025, 09:40 AM
