Panasonic CF-54 Bios Password
  • medinfo
    • May 2016
    • 331
    • Morocco
    Panasonic Toughbook CF-54 mk1
    Bios = 16 Mb
    i need a clean bios plz
    Last edited by SMDFlea; 04-03-2023, 09:22 AM. Reason: Attachments cleanup,server space low.
  • medinfo
    • May 2016
    • 331
    • Morocco
    Re: Panasonic CF-54 Bios Password
    Problem fixed
    • mshobra90
      • egypt
      thanks bro
      • oluwaseun109
        • Jan 2020
        • Nigeria
        Hi guy kindly help me out on how it was used. urgent thanks.
        • oluwaseun109
          • Jan 2020
          • Nigeria
          Originally posted by medinfo
          Problem fixed
          How was it used please
          • oluwaseun109
            • Jan 2020
            • Nigeria
            Bios = 16 Mb
            How do i use it please. thanks.
            • RethoricalCheese
              • Mar 2013
              • 1519
              • Estonia
              So how does posting 3 times in 10 minutes help?
              Make a dump of your bios, clear out AMITSESetup sections and write it back.
              • oluwaseun109
                • Jan 2020
                • Nigeria
                Am sorry if my post look much can you please help me with the procedure of how to make a dumb of my bios
                Thanks.
                Hi my Toughbook CF-54 has a bios lock but I forgot what it was mm
                the serial number is CF-54AY006ZZ kindly help me out on the unlocking.
                Thanks.
                • chriszzler
                  • Jul 2020
                  • 6
                  • South Africa
                  Good day ,
                  Could someone please remove the bios password from my bios dump or supply me with the password , and also maybe teach me how to do it ? i have tried using a hex editor and changing the Amitsetup directory which contains the encrypted password with no success.
                  Kind regards
                  • rioreno
                    • Feb 2009
                    • 540
                    • Indonesia
                    Originally posted by chriszzler
                    Good day ,
                    Kind regards
                    try this... and goodluck
                    • chriszzler
                      • Jul 2020
                      • 6
                      • South Africa
                      Thank you for the effort , i get an error "43 - error: problem erasing flash" , did i do something wrong , how can i fix this ?
                      • rioreno
                        • Feb 2009
                        • 540
                        • Indonesia
                        i am not sure how to give explained to you... because i always t to desoldering chip instead using afuwin,,,,
                        just check how to flash using afuwin fromm this thread...
                        https://gist.github.com/en4rab/55088...omment-3276663
                        • chriszzler
                          • Jul 2020
                          • 6
                          • South Africa
                          Thank you for your assistance , seems as if it is locked , i updated the bios recently and might be the cause. Could you please share how you edited the rom ?
                          • chriszzler
                            • Jul 2020
                            • 6
                            • South Africa
                            Could someone please decrypt my bios password from my bios dump ? I cannot flash to the bios chip as it does not allow me to.
                            Panasonic CF-54D3961T2
                            Kind regards
                              • 23372
                              Kind regards
                              You need to make a full backup with an SPI programmer.Its the only way.
                              • chriszzler
                                • Jul 2020
                                • 6
                                • South Africa
                                I have attached the full backup , here is the password hex as well from the AMITSetup:
                                5B 86 B6 FF 11 89 6C B0 C7 2B 22 81 7D A4 D8 70
                                33 AE 8E 4E E9 F7 44 74 9F DE FA 5C 55 D3 B0 71
                                0B 29 66 02 C1 B9 1C B6 77 16 D2 A9 2D 3D 88 D0
                                E3 63 3E F7 99 8A F4 1D 4F B1 AA 44 05 D8 60 6B
                                Let me know if i can add any more info.
                                • tooko
                                  • Nov 2014
                                  • 38
                                  • france
                                  I have a Panasonic toughbook CF-54, I need to remove BIOS password. I have just read the MX25L12873f. Can someone remove password please ?
                                  Best regards
                                  • rioreno
                                    • Feb 2009
                                    • 540
                                    • Indonesia
                                    Best regards
                                    this..goodluck and please confirm
                                    • tooko
                                      • Nov 2014
                                      • 38
                                      • france
                                      Finally I had paid someone to do it, i was under pressure to do it. But I have tested yours rioreno and it works like a charm.
                                      thanks !
                                      Best regards
                                      • meskellil
                                        • Jan 2020
                                        • 8
                                        • casa
                                        I tried to flash with the bin that ( rioreno ) posted:TOUGHBOOKCF54_UNLOCK.rar (6.40 MB) but it don't work
                                        Can someone remove password ?
                                        I have read the MX25L12873f on my laptop .
                                        THANKS
                                        • outsider
                                          Panasonic FZ-G1 MK5 - BIOS password returning
                                          by outsider
                                          Hello
                                          I removed the BIOS password thanks to the help of one of the friends of this forum.
                                          https://www.badcaps.net/forum/troubl...61#post3637661
                                          The batch from which the password was removed works correctly but... after some time, the BIOS password is set again, I reprogrammed the batch with the removed password, it's ok, there is no password, I set my password, ok, I can enter the BIOS with my password but...
                                          06-17-2025, 12:51 AM
                                        • TopPop
                                          Dell Latitude 5530 BIOS Password Removal Attempted but I Broke the Laptop
                                          by TopPop
                                          Sorry for the long story. I have a Dell Latitude 5530 (i7) laptop (South Peak 15 MLK MB DDR4 203102-1 FK8VG$JA) with an admin BIOS password that I want to remove. Service Tag: HYKFPT3. Other than that the laptop worked OK.
                                          I found a CH341A Black and went looking for the BIOS chip on the motherboard. After trying to read one chip that was a firmware chip but not the BIOS I think I found the BIOS chip labeled Winbond 25Q256JVEN. Altogether I think I found 4 different firmware chips in the laptop. The BIOS chip is a WSON8 6x8. I used the CH341A, NeoProgrammer, and a cheap pogo pin clip...
                                          12-14-2025, 09:40 PM
                                        • zenius
                                          by zenius
                                          12-08-2024, 06:13 AM
                                        • Dudebroman
                                          Lenovo Ideapad Slim 3 Bios Password Ghost
                                          by Dudebroman
                                          Hello Hello,
                                          I have been browsing the site and gotten so much useful info from here, including extremely helpful boardviews and several other very useful types of information. I am very grateful to this community, as I have actually eeked out a living from buying salvage PC's & Macbooks and repairing them. So, thank you all in advance!
                                          I have searched and found some useful information regarding my issue, but my case is a bit different than the info I'm finding. But if anyone here can give me any useful advice, it would be highly appreciated.
                                          12-18-2025, 12:22 PM
                                        • traxformania
                                          TONGFANG "GM7TG7P" Bios Password Problem?
                                          by traxformania
                                          I'm using TONGFANG "GM7TG7P" model laptop for over 3 years and i'm entering the same bios administrator password everyday. My laptop has Aptio BIOS (American Megatrends, AMI).
                                          But today it's not accepting my password. I'm %100 sure i'm entering the correct password.
                                          I'm trying to reset my bios without success.
                                          I tried :
                                          -I removed the BIOS battery and main battery. Waited for a long time but it didn't work. They already stated in the user manual that the password will not be reset even if the batteries...
                                          11-15-2023, 07:32 AM
