Panasonic CF-54 Bios Password
    VIP Moderator
    • Aug 2018
    • 4386
    • Bulgaria 🇧🇬
    #261
    Re: Panasonic CF-54 Bios Password
    Originally posted by lenovo270
    I reviewed it.
    It wasn't loading properly.
    What about this?
    Looks good.
    Below is your unlocked dump, try it and let me know:
    Become a Badcaps supporter
    Thanks to all supporters.​
    • lenovo270
      • Mar 2023
      • 11
      • japan
      #262
      Originally posted by Vesko356
      Looks good.
      it is perfect
      donated
        VIP Moderator
        • Aug 2018
        • 4386
        • Bulgaria 🇧🇬
        #263
        it is perfect
        donated
        Great!
        I appreciate you joining in and donating the forum in this difficult situation!
        • lenovo270
          • Mar 2023
          • 11
          • japan
          #264
          Great!
          please help me if I'm in trouble again
            VIP Moderator
            • Aug 2018
            • 4386
            • Bulgaria 🇧🇬
            #265
            Sure, I'll be happy to help again if needed.
            Cheers
            • Sudam ouellet
              • Apr 2023
              • canada
              #266
              Hi
              I am trying to remove the supervisor password on this bios, but normally the password should be at 2 places, but I find like 6 places where the password seems to be.
              Beginning by 5B 13 B6 9F11 69 6C
              Thanks for any help
              • peste
                • 13880
                • ROMANIA
                #267
                Originally posted by Sudam ouellet
                Hi
                Thanks for any help
                try..
                • Sudam ouellet
                  • Apr 2023
                  • canada
                  #268
                  It did not work but after removing all the instance of the password it did work, but there is a section for Optional kit configuration still locked any advice on this
                    • 22216
                    https://www.badcaps.net/forum/showth...on#post1049861 .Not sure how to remove it,perhaps flashing another bios that doesn`t have the hardcoded password in it.
                    • Sudam ouellet
                      • Apr 2023
                      • canada
                      #270
                      Ok
                      The password is "toughkit" not much setting in the menu
                      So the bios is unlocked now thanks.
                      I was trying to upgrade the Wi-Fi card but the bios, I guess seems to block the new card. any info on that you are aware of?
                      • Sudam ouellet
                        • Apr 2023
                        • canada
                        #271
                        Ok
                        I have found a workaround if someone want to upgrade their Wi-Fi card I followed this guide to mask off 2 pins (54 and 56) on the new card, so the computer can't send the off signal to the card the Wi-Fi card. The Wi-Fi light is off, but the card work.
                        I installed an Intel ax210 WiFi6e
                        https://thecomputerperson.wordpress....-pin-20-trick/
                        • imran421
                          • Apr 2020
                          • 83
                          PLEASE help me in unlocking the bios paswsword.
                          bin file attached
                            VIP Moderator
                            • Aug 2018
                            • 4386
                            • Bulgaria 🇧🇬
                            #273
                            bin file attached
                            Here you are:
                            • imran421
                              • Apr 2020
                              • 83
                              no go. powers on and shut down right away
                                VIP Moderator
                                • Aug 2018
                                • 4386
                                • Bulgaria 🇧🇬
                                #275
                                Give me a break - no way, check the soldering or orientation of the chip to the motherboard, or if you using ch341a with the clip verify the content of the chip.
                                • imran421
                                  • Apr 2020
                                  • 83
                                  My apologies. Bin file was not correct. Can You please fix this one. Thousand apologies to waste your time.
                                    VIP Moderator
                                    • Aug 2018
                                    • 4386
                                    • Bulgaria 🇧🇬
                                    #277
                                    "...shut down right away" huh?
                                    • imran421
                                      • Apr 2020
                                      • 83
                                      it worked this time and donated as well.
                                        VIP Moderator
                                        • Aug 2018
                                        • 4386
                                        • Bulgaria 🇧🇬
                                        #279
                                        Well done!
                                        Thank you for your support, appreciate it.
                                        • gandalffoogray
                                          • May 2023
                                          does any one have the bios file for the CF-54FX.
                                          • outsider
                                            Panasonic FZ-G1 MK5 - BIOS password returning
                                            by outsider
                                            Hello
                                            I removed the BIOS password thanks to the help of one of the friends of this forum.
                                            https://www.badcaps.net/forum/troubl...61#post3637661
                                            The batch from which the password was removed works correctly but... after some time, the BIOS password is set again, I reprogrammed the batch with the removed password, it's ok, there is no password, I set my password, ok, I can enter the BIOS with my password but...
                                            06-17-2025, 12:51 AM
                                          • zenius
                                            by zenius
                                            12-08-2024, 06:13 AM
                                          • traxformania
                                            TONGFANG "GM7TG7P" Bios Password Problem?
                                            by traxformania
                                            I'm using TONGFANG "GM7TG7P" model laptop for over 3 years and i'm entering the same bios administrator password everyday. My laptop has Aptio BIOS (American Megatrends, AMI).
                                            But today it's not accepting my password. I'm %100 sure i'm entering the correct password.
                                            I'm trying to reset my bios without success.
                                            I tried :
                                            -I removed the BIOS battery and main battery. Waited for a long time but it didn't work. They already stated in the user manual that the password will not be reset even if the batteries...
                                            11-15-2023, 07:32 AM
                                          • longmt1990
                                            Panasonic Cf-w5 bios password remove
                                            by longmt1990
                                            Hi, i have a Panasonic Cf-W5 with the bios password, I tried remove cmos but problem didnot solve.
                                            I uploaded the picture after remove cmos battery, It look like this is a Phoenix bios. The bios dump file in the link i attached
                                            Please help me remove bios password.
                                            Thank you so much
                                            07-06-2025, 10:50 PM
                                          • AquaMan Ua
                                            Problem with PANASONIC CF53 laptop after changing BIOS settings
                                            by AquaMan Ua
                                            Hello. I am asking you for a hint on how to solve the problem with my touchbook Panasonic CF53-2 standart model. After setting up the BIOS, the laptop displays the wrong image until Windows loads. (More precisely, it displays, but distorted, instead of the Panasonic image immediately after turning it on, it displays what is in photo #1 in the attached file) Then the image appears when Windows starts loading and then there are no problems with the screen until the reboot. If you enter the BIOS, just a black screen. If you connect an external screen, the image on it is the same as on the built-in...
                                            05-17-2025, 09:40 AM
