Panasonic CF-54 Bios Password
  • Vesko356
    VIP Moderator
    • Aug 2018
    • 4386
    • Bulgaria 🇧🇬
    #261
    Re: Panasonic CF-54 Bios Password
    Originally posted by lenovo270
    I reviewed it.
    It wasn't loading properly.
    What about this?
    Looks good.
    Below is your unlocked dump, try it and let me know:
    Become a Badcaps supporter
    Thanks to all supporters.​
    • lenovo270
      • Mar 2023
      • 11
      • japan
      #262
      Originally posted by Vesko356
      Looks good.
      it is perfect
      donated
      • Vesko356
        VIP Moderator
        • Aug 2018
        • 4386
        • Bulgaria 🇧🇬
        #263
        it is perfect
        donated
        Great!
        I appreciate you joining in and donating the forum in this difficult situation!
        • lenovo270
          • Mar 2023
          • 11
          • japan
          #264
          Great!
          please help me if I'm in trouble again
          • Vesko356
            VIP Moderator
            • Aug 2018
            • 4386
            • Bulgaria 🇧🇬
            #265
            Sure, I'll be happy to help again if needed.
            Cheers
            • Sudam ouellet
              • Apr 2023
              • 4
              • canada
              #266
              Hi
              I am trying to remove the supervisor password on this bios, but normally the password should be at 2 places, but I find like 6 places where the password seems to be.
              Beginning by 5B 13 B6 9F11 69 6C
              Thanks for any help
              • peste
                • Dec 2016
                • 12378
                • ROMANIA
                #267
                Originally posted by Sudam ouellet
                Hi
                Thanks for any help
                try..
                • Sudam ouellet
                  • Apr 2023
                  • 4
                  • canada
                  #268
                  It did not work but after removing all the instance of the password it did work, but there is a section for Optional kit configuration still locked any advice on this
                    • 20481
                    https://www.badcaps.net/forum/showth...on#post1049861 .Not sure how to remove it,perhaps flashing another bios that doesn`t have the hardcoded password in it.
                    • Sudam ouellet
                      • Apr 2023
                      • 4
                      • canada
                      #270
                      Ok
                      The password is "toughkit" not much setting in the menu
                      So the bios is unlocked now thanks.
                      I was trying to upgrade the Wi-Fi card but the bios, I guess seems to block the new card. any info on that you are aware of?
                      • Sudam ouellet
                        • Apr 2023
                        • 4
                        • canada
                        #271
                        Ok
                        I have found a workaround if someone want to upgrade their Wi-Fi card I followed this guide to mask off 2 pins (54 and 56) on the new card, so the computer can't send the off signal to the card the Wi-Fi card. The Wi-Fi light is off, but the card work.
                        I installed an Intel ax210 WiFi6e
                        https://thecomputerperson.wordpress....-pin-20-trick/
                        • imran421
                          • Apr 2020
                          • 73
                          PLEASE help me in unlocking the bios paswsword.
                          bin file attached
                          • Vesko356
                            VIP Moderator
                            • Aug 2018
                            • 4386
                            • Bulgaria 🇧🇬
                            #273
                            bin file attached
                            Here you are:
                            • imran421
                              • Apr 2020
                              • 73
                              no go. powers on and shut down right away
                              • Vesko356
                                VIP Moderator
                                • Aug 2018
                                • 4386
                                • Bulgaria 🇧🇬
                                #275
                                Give me a break - no way, check the soldering or orientation of the chip to the motherboard, or if you using ch341a with the clip verify the content of the chip.
                                • imran421
                                  • Apr 2020
                                  • 73
                                  My apologies. Bin file was not correct. Can You please fix this one. Thousand apologies to waste your time.
                                  • Vesko356
                                    VIP Moderator
                                    • Aug 2018
                                    • 4386
                                    • Bulgaria 🇧🇬
                                    #277
                                    "...shut down right away" huh?
                                    • imran421
                                      • Apr 2020
                                      • 73
                                      it worked this time and donated as well.
                                      • Vesko356
                                        VIP Moderator
                                        • Aug 2018
                                        • 4386
                                        • Bulgaria 🇧🇬
                                        #279
                                        Well done!
                                        Thank you for your support, appreciate it.
                                        • gandalffoogray
                                          • May 2023
                                          • 4
                                          does any one have the bios file for the CF-54FX.
                                          • outsider
                                            Panasonic FZ-G1 MK5 - BIOS password returning
                                            by outsider
                                            Hello
                                            I removed the BIOS password thanks to the help of one of the friends of this forum.
                                            https://www.badcaps.net/forum/troubl...61#post3637661
                                            The batch from which the password was removed works correctly but... after some time, the BIOS password is set again, I reprogrammed the batch with the removed password, it's ok, there is no password, I set my password, ok, I can enter the BIOS with my password but...
                                            06-17-2025, 12:51 AM
                                          • zenius
                                            by zenius
                                            12-08-2024, 06:13 AM
                                          • traxformania
                                            TONGFANG "GM7TG7P" Bios Password Problem?
                                            by traxformania
                                            I tried :
                                            -I removed the BIOS battery and main battery. Waited for a long time but it didn't work. They already stated in the user manual that the password will not be reset even if the batteries...
                                            11-15-2023, 07:32 AM
                                          • Nopslide
                                            by Nopslide
                                            04-01-2024, 04:27 PM
                                          • AquaMan Ua
                                            by AquaMan Ua
                                            05-17-2025, 09:40 AM
