Panasonic Toughbook CF-53 Mk3 BIOS Password Removal
  • 94summit
    • Nov 2018
    Please remove the password.
  • rioreno
    • Feb 2009
    • 540
    • Indonesia
    Re: Panasonic Toughbook CF-53 Mk3 BIOS Password Removal
    post your full backup with spi programmer...
    your post files only bios region, no me region...
    • recep1982
      • Aug 2014
      • 88
      • istanbul
      hi
      please bios password clear.
      • rioreno
        • Feb 2009
        • 540
        • Indonesia
        Originally posted by recep1982
        hi
        try this...
        • Andreasbest
          • Aug 2014
          • 1163
          • Hellas ( Greece )
          Originally posted by rioreno
          try this...
          Hello.
          This bios dump can be used in multiple CF-53's OR it's unique per laptop?
          Thank you!
          • RethoricalCheese
            • Mar 2013
            • 1518
            • Estonia
            Afaik it contains SN etc and probably ME is not cleaned so it is way better to just upload your own dump and get the password removed on that.
            • Andreasbest
              • Aug 2014
              • 1163
              • Hellas ( Greece )
              So if we clean the ME and leave the SN as is it will be possible to work fine?
              I ask because i'll receive a pallet with 30 laptops for unlock.
              • Maxpower3
                Bad Veteran
                • Feb 2018
                • 1224
                • France
                Warning Mac adress and UUID
                if used in the same corporate network.
                • Andreasbest
                  • Aug 2014
                  • 1163
                  • Hellas ( Greece )
                  So i must change the MAC address and UUID in every bios.
                  Perhaps it will be easier if i remove the bios password on every bios my self.
                  Is there any guide for CF-53 ?
                  • Maxpower3
                    Bad Veteran
                    • Feb 2018
                    • 1224
                    • France
                    that is to say, not understood
                    • Andreasbest
                      • Aug 2014
                      • 1163
                      • Hellas ( Greece )
                      I mean if there is any online guide with instructions on how to remove the bios password from CF-53 dump by my self.
                      It's not right to upload 30 bios dumps and wait others to work for me.
                      • Maxpower3
                        Bad Veteran
                        • Feb 2018
                        • 1224
                        • France
                        here sur bad caps , just compare with other files
                        edit :
                        I forgot the 01 at the end and replace by 00 and not FF
                        • Andreasbest
                          • Aug 2014
                          • 1163
                          • Hellas ( Greece )
                          edit :
                          So clear everything with 00 including the 01 @ 00AB3090x03 ?
                          • Maxpower3
                            Bad Veteran
                            • Feb 2018
                            • 1224
                            • France
                            yes, beware the address changes for each bios.
                            Search with the keywords "AMITSESetup".(the second often)
                            I gave you the technique for the supervisor password.
                            It can have the user's password too.
                            It is just above if there is a.
                            It will always start with 5B.
                            Look at my picture here you will understand.
                            https://www.badcaps.net/forum/showthread.php?t=88289
                            • Andreasbest
                              • Aug 2014
                              • 1163
                              • Hellas ( Greece )
                              Ok, i'll let you know when i receive the pallet. Thank you!
                              • ivank2020
                                • Jan 2021
                                • Ukraine
                                Please help me to reset CF-53 password.
                                What is the procedure?
                                • joaquinmjuan
                                  • Sep 2014
                                  • 31
                                  • España
                                  edit :
                                  Hello, I have done what you indicate, and it has worked for me. It asked me for a password to enter the BIOS, and now it no longer asks me for it. Thanks a lot!!!
                                  • Thro'ellet
                                    • Jul 2021
                                    • Belgium
                                    Hi, I have a CF-53 that is also locked,
                                    can someone help me ?
                                    • LenBios
                                      • 122
                                      • Ker
                                      post your locked bios file please
                                      • gpatadia
                                        • Sep 2015
                                        • 15
                                        • India
                                        please remove password
                                        thanks
                                        • AquaMan Ua
                                          by AquaMan Ua
                                          05-17-2025, 09:40 AM
                                        • aa10aa10
                                          Panasonic Toughbook CF-33 mk1 BIOS repair
                                          by aa10aa10
                                          Good day,
                                          I have tried to remove BIOS supervisor password from Panasonic Toughbook CF-33 mk1. Model number CF-33AENABTG, unfortunately I don't have any other info.
                                          I read the BIOS using afuwin, edited it and tried to flash new edited BIOS using afuwin. Unsuccessfully. Afuwin showed "Error: Problem erasing flash." starting with 0x00040000 and stoped. Then I tried many other options to flash BIOS from Windows without any luck. Finally i rebooted the device - and no post. Afterwards I have read the corrupted bios chip (MX25L12873F) using EZP2010 programmer....
                                          01-21-2025, 06:13 AM
                                        • adil12
                                          Panasonic toughbook cf53-as-50de bios password removal help
                                          by adil12
                                          hello everyone, can you please help me to clear the bios password from Panasonic toughbook cf53-as-50de
                                          thank you...
                                          09-14-2021, 10:39 AM
                                        • macabook
                                          by macabook
                                          🧩 Initial Issue
                                          07-24-2025, 02:17 PM
                                        • eukal
                                          Panasonic toughbook cf-h2 Mk1 no power, 3.3v-5v present but no 3v on bios chip
                                          by eukal
                                          Hello, i have a Panasonic Toughbook Cf-H2 Mk1 that won't power on. The battery charge without problem but no response from the laptop when i press the power button.
                                          I have disassemble and unpluged the cmos battery, same no power on on battery with and whitout the adapter, and only adapter
                                          I have check the voltage i have the main power rail ( +-16v normal for toughbook it's not 19v). I have on the coil after power management chip 3.3v and 5v.
                                          I have check the 3.3v on the power button ribbon cable attach to the motherboard and the voltage go to 0v when i press the button. So...
                                          07-01-2023, 01:00 PM
