  • lucaszmn
    • Oct 2023
    Problem:
    Initial Findings:
    • I concluded that the N1KET58W (1.45) BIOS is not compatible with the standard patching methods, and a downgrade to an older, more vulnerable version is necessary.
    • The target BIOS version for the downgrade is N1KTC58W, which was released in 2017.
    • I attempted to find a donor BIOS file from a community site but could only find a generic file dump from 2018. Using command-line tools (strings and grep), I verified that this file is not the N1KTC58W version.
    • I identified the critical importance of preserving my laptop's unique DMI data. The plan is to transfer my DMI data from my personal backup into a patched donor BIOS file.
    Current Situation & Questions:
    I have my original BIOS backup, but I am unable to find a compatible donor BIOS file to patch.
    I am looking for:
    1. A verified BIOS dump for a Lenovo ThinkPad T560 with the N1KTC58W firmware.
    2. Any leads on where I can find the official Lenovo update utility for the N1KTC58W BIOS, as official sources now only provide newer versions.
    3. Confirmation that a known working patch for the N1KTC58W BIOS exists.
    Goal:
    To obtain a working, verified, and patched N1KTC58W BIOS file to flash onto my laptop, which will remove the WWAN whitelist and allow my card to work.
  • TopPop
    Dell Latitude 5530 BIOS Password Removal Attempted but I Broke the Laptop
    by TopPop
    Sorry for the long story. I have a Dell Latitude 5530 (i7) laptop (South Peak 15 MLK MB DDR4 203102-1 FK8VG$JA) with an admin BIOS password that I want to remove. Service Tag: HYKFPT3. Other than that the laptop worked OK.
    I found a CH341A Black and went looking for the BIOS chip on the motherboard. After trying to read one chip that was a firmware chip but not the BIOS I think I found the BIOS chip labeled Winbond 25Q256JVEN. Altogether I think I found 4 different firmware chips in the laptop. The BIOS chip is a WSON8 6x8. I used the CH341A, NeoProgrammer, and a cheap pogo pin clip...
    12-14-2025, 09:40 PM
  • Olegst44
    Acer Aspire 3 A315-22G - NB8607G02-MB (Compal LA-J761P) - BIOS Password Removal / Clean BIOS Needed
    by Olegst44
    I need help with BIOS password removal for Acer Aspire 3 A315-22G laptop.
    Device Information:
    - Model: Acer Aspire 3 A315-22G
    - Motherboard: NB8607G02-MB (Compal LA-J761P)
    - BIOS Chip: Winbond W25Q64 (8MB)
    - Serial: NXHE7ER00X95002B784S00
    Problem:
    - BIOS is password protected (Supervisor Password)
    - Boot from USB is disabled in BIOS
    - After 3 wrong password attempts, system shows Unlock Key Hint
    - I have RT809H programmer available
    What I need:
    1. Clean BIOS dump (password...
    04-11-2026, 05:36 PM
  • macabook
    by macabook
    🧩 Initial Issue
    07-24-2025, 02:17 PM
  • rumVV
    [Request] MSI GT72 2QE Dominator Pro G — BIOS password removal (MS-1781)
    by rumVV
    I need help removing the BIOS password from my MSI GT72.
    Laptop: MSI GT72 2QE Dominator Pro G
    Motherboard: MS-1781
    BIOS chip: GigaDevice 64Mbit (8MB), Read ID C84017
    BIOS version: E1781IMS.10R
    Serial: 9S71781311241ZF4000007
    Problem: The laptop asks for a BIOS password at power-on and I cannot enter the BIOS setup. CMOS clear did not help, and MSI support declined to help with the password.
    Attached is my own backup dump, read twice from the BIOS chip with a CH341A programmer + SOIC8 clip. Both reads are 8,388,608 bytes...
    11-07-2026, 07:45 PM
  • helpmepleasethanks
    Thinkpad T440P bios repair after WIFI whitelist mod
    by helpmepleasethanks
    As per the the rules, here are the specifications of my laptop :
    • Make and model number : Thinkpad T440P
    • Serial number (S/N) : PB-03A7V7
    • Model type - Model (MTM) : 20AW-S2N800
    • Bios version : 2.50 (not 100% sure, that's what I remember)
    Here is the problem, and the events leading to it :
    1. Upgrade screen, keyboard, trackpad, RAM and CPU
    2. Reboot and use the laptop for a bit : everything is working fine
    3. Shutdown (no power) and upgrade WIFI with unsupported chip (AX210)
    4. Boot up the device : bios warning, as expected
    5. Shutdown the device again (no power)
    6. Connect the 8-pin clip of a CH341a
    01-09-2025, 12:09 PM
