Please remove the password.
Panasonic Toughbook CF-53 Mk3 BIOS Password Removal
Re: Panasonic Toughbook CF-53 Mk3 BIOS Password Removal
hi
please bios password clear.Attached FilesComment
try this...Attached FilesComment
Afaik it contains SN etc and probably ME is not cleaned so it is way better to just upload your own dump and get the password removed on that.Comment
So if we clean the ME and leave the SN as is it will be possible to work fine?
I ask because i'll receive a pallet with 30 laptops for unlock.Comment
So i must change the MAC address and UUID in every bios.
Perhaps it will be easier if i remove the bios password on every bios my self.
Is there any guide for CF-53 ?Comment
I mean if there is any online guide with instructions on how to remove the bios password from CF-53 dump by my self.
It's not right to upload 30 bios dumps and wait others to work for me.Comment
, just compare with other files
edit :
I forgot the 01 at the end and replace by 00 and not FFLast edited by Maxpower3; 09-04-2020, 03:06 AM.Comment
yes, beware the address changes for each bios.
Search with the keywords "AMITSESetup".(the second often)
I gave you the technique for the supervisor password.
It can have the user's password too.
It is just above if there is a.
It will always start with 5B.
Look at my picture here you will understand.
https://www.badcaps.net/forum/showthread.php?t=88289Comment
Ok, i'll let you know when i receive the pallet. Thank you!Comment
Hello, I have done what you indicate, and it has worked for me. It asked me for a password to enter the BIOS, and now it no longer asks me for it. Thanks a lot!!!Comment
Hi, I have a CF-53 that is also locked,
can someone help me ?Comment
please remove password
thanksAttached FilesLast edited by gpatadia; 09-27-2021, 12:53 AM.Comment
by AquaMan UaHello. I am asking you for a hint on how to solve the problem with my touchbook Panasonic CF53-2 standart model. After setting up the BIOS, the laptop displays the wrong image until Windows loads. (More precisely, it displays, but distorted, instead of the Panasonic image immediately after turning it on, it displays what is in photo #1 in the attached file) Then the image appears when Windows starts loading and then there are no problems with the screen until the reboot. If you enter the BIOS, just a black screen. If you connect an external screen, the image on it is the same as on the built-in...2 Photos
Channel: BIOS Requests ONLY!
by aa10aa10Good day,
I have tried to remove BIOS supervisor password from Panasonic Toughbook CF-33 mk1. Model number CF-33AENABTG, unfortunately I don't have any other info.
I read the BIOS using afuwin, edited it and tried to flash new edited BIOS using afuwin. Unsuccessfully. Afuwin showed "Error: Problem erasing flash." starting with 0x00040000 and stoped. Then I tried many other options to flash BIOS from Windows without any luck. Finally i rebooted the device - and no post. Afterwards I have read the corrupted bios chip (MX25L12873F) using EZP2010 programmer....-
by adil12hello everyone, can you please help me to clear the bios password from Panasonic toughbook cf53-as-50de
thank you...-
by macabookHello everyone,
🧩 Initial Issue- Board powers on (fans spin, keyboard lights up and can be adjusted, caps lock led lights), but no display or backlight
- External display (HDMI) shows
Today, 02:17 PM -
by eukalHello, i have a Panasonic Toughbook Cf-H2 Mk1 that won't power on. The battery charge without problem but no response from the laptop when i press the power button.
I have disassemble and unpluged the cmos battery, same no power on on battery with and whitout the adapter, and only adapter
I have check the voltage i have the main power rail ( +-16v normal for toughbook it's not 19v). I have on the coil after power management chip 3.3v and 5v.
I have check the 3.3v on the power button ribbon cable attach to the motherboard and the voltage go to 0v when i press the button. So... - Loading...
