New Panasonic Decrypter Hash?
  • Maxpower3
    Bad Veteran
    • Feb 2018
    • 1356
    • France
    Do you have any info on the new way to decrypt the password.
    The Xor key only works on some older models.
    If I compare different bios,
    I notice that it changes only one byte every 2 bytes. (see screen)
    I think that the key is not false but the way of decrypting has to change.
    Otherwise what interest to find the Xor key identical or almost,
    if it was a hash, it would not need to be presented anymore?
    if it can help for research
  • RethoricalCheese
    • Mar 2013
    • 1519
    • Estonia
    Re: New Panasonic Decrypter Hash?
    It is not only with newer panasonics but some other laptops aswell. You can still XOR decrypt using the same XOR key but what you get as a result is a 192 bit encrypted key which needs to be decrypted aswell. Once I saw that, I stopped trying because laptops with such encryption have been easily opened up so I just used a programmer to delete the passwords.
    • BootLoader1
      • Aug 2020
      • 70
      • Poland
      New Panasonic algorythm looks like this :
      Password -> SHA1 -> XOR = hash
      There are several different algorithms. Not possible to decrypt password. You are wasting your time.
      • kelyssonw
        • Apr 2021
        • 1
        • Brasil
        Re:bios password?
        I have a CF-53 mk3, here in the company with the bios blocked. I can only unlock by reading the eeprom?
        • BigPete
          Panasonic Heatpump Dryer Repair
          by BigPete
          I picked up a Panasonic NH-P70G2, though it would apply to the NH-P80G2, NH-P70G1 and NH-P80G1 models as well, as maybe some other models. This one was coming up with a H86 error. After lots of testing and googling it was an error with one of the thermistors in the condenser area.
          The attached French service manuals is incorrect, TH11 is gray and is a 95k thermistor and TH12 is black and is a 35k thermistor.
          In my case TH12 was bad. I was able to get a 35k thermistor on AliExpress. It's 6mm in diameter.
          Unfortunately the whole machine has to come apart to fix it.
          I have...
          11-01-2025, 06:40 PM
        • Andre Gilbert
          by Andre Gilbert
          Hello! yes I know there is already lots of information about this issue. I have a Panasonic TC-P55ST50 that originally displayed an 8-blink error code. Following the troubleshooting flowchart, I ended up replacing the SS board. However, even after replacing it, the issue persists. The TV turns on and stays on without displaying an image, and continuity is confirmed on all connectors. What am I missing here🤔?
          Ok Im a mechanical engineer ...but I thought I was able to follow a rather simple flowchart for electric troubleshooting 😂.
          11-20-2024, 08:52 PM
        • Vusal
          CPU replace | OEM Hash key poblem
          by Vusal
          first of all hello everyone
          If there is a short circuit on the motherboard of the HP laptop. The CPU was broken (i3-10th) I found a donor motherboard on ebay and replaced the CPU.
          The CPU on the donor motherboard had the OEM Hash key. But I did not check the OEM Hash key before ordering the donor motherboard.
          Normally, after changing the CPU, the motherboard started and the white LED light on the DC jack was blinking.
          The motherboard was in reset state and the current drawn was 60mah.
          I checked the BIOS information and added the OEM Hash key on the donor motherboard...
          04-04-2024, 02:30 PM
        • AquaMan Ua
          Problem with PANASONIC CF53 laptop after changing BIOS settings
          by AquaMan Ua
          Hello. I am asking you for a hint on how to solve the problem with my touchbook Panasonic CF53-2 standart model. After setting up the BIOS, the laptop displays the wrong image until Windows loads. (More precisely, it displays, but distorted, instead of the Panasonic image immediately after turning it on, it displays what is in photo #1 in the attached file) Then the image appears when Windows starts loading and then there are no problems with the screen until the reboot. If you enter the BIOS, just a black screen. If you connect an external screen, the image on it is the same as on the built-in...
          05-17-2025, 09:40 AM
        • stecos
          Panasonic Plasma main board repair (ST30 GT30 VT30 ST50 GT50 VT50),LED with 3 blincks
          by stecos
          Hi everyone!
          I happened several times, in the search for help from the web, to consult this very interesting forum.
          So I decided to sign up and I intend to participate actively by making available my knowledge and experience on the subject, I'm a new user but at the same time I'm old in the sense that I have 4 decades of experience in repairing and designing electronics but above all I'm a great passionate about the subject.
          Having said that I come to the gist of my post on the forum as the title suggests.
          For my passion for technology I'm now collecting several...
          11-28-2022, 11:39 AM
