bios dump elitebook 840 g3
Re: HP Elitebook 840 g3 hp dxe update error
try .. write both bios chips ..Attached Filesif you find these attachements useful please consider making a small donation to the site
Every donation made will go towards server fees and maintenance costs.Comment
Last edited by SMDFlea; 04-02-2023, 12:22 PM.Due to a lack of donations, server free space at a critical level, and possible closure of Bios Requests all donations are welcome, click:
Re: bios dump elitebook 840 g3
yes, you can rewrite a new chip with a bios, if we have the bios ... post the full name and model of the laptop and the motherboard model ... let's see if we find the bios ..Due to a lack of donations, server free space at a critical level, and possible closure of Bios Requests all donations are welcome, click:
Thanks for the info. It's an HP 840 G3. Motherboard model number is 918313-601.Comment
if it works enter the DMI information
https://www.youtube.com/watch?v=9T57ktw8n3YLast edited by SMDFlea; 04-02-2023, 12:22 PM.Due to a lack of donations, server free space at a critical level, and possible closure of Bios Requests all donations are welcome, click:
Re: HP EliteBook 850 G3 corrupted extracted image
Hi all. I have a hp 850 g3 bought from a pawn store which had password locked bios. I desoldered the W25Q128 chip and made a dump read with ch341 programmer v1.29. After that, i've used HP bios unlocker to generate the unlocked bios, erased the chip, made a blank check and then write + verify. Made this operations few times and each time got an error that said that the info i have written on the chip is not the same as the one loaded in programmer. Soldered the chip altough i knew i have this error and the laptop either did not do anything, either started to work with no image on display and fan blowing at maximim. After furher searches on google found that only ASProgrammer works ok with this chip or CH341 programmer version 1.18. Hence, i used the bios clean me file posted by SMDFlea here because i suspected that my dump read might be corrupt, wrotted with asprogrammer and laptop start working again.
My curiosity now is if the dump read i made is corrupt or no, and if it's ok, can i unlocked it and then flash it via windows or BIOS? I am asking this because of the windows lincese which is embded on it and because i am not willing to dissasembly the laptop and desolder the chip again.
Here is my dump.Last edited by SMDFlea; 04-02-2023, 12:22 PM.Comment
by AhariHi all,
I...-
by mkdjDear all,
I would appreciate if someone could take time to explain the issue, so that I can learn. But I would...-
Channel: BIOS Requests ONLY!
by Habble7The Samsung S49CG934SU monitor does not power on - no LED indicator activity and no response to power button. However, when 21V power is connected, it immediately draws 0.8A of current with no display output. The motherboard processor gets warm, and there is continuous reading activity from the W25Q128BV BIOS chip.
Suspected Cause:
Troubleshooting Attempts:
Hello engineers 😀,
🔧 Device Info:
- Model: HP 15-da2007ne
- Product Number: 8XF55EA#ABV
- Serial Number: CND0338P0D
- CPU: Intel Celeron N4000
💀 Problem:😅
- Device shows “Administrator Password”...2 Photos-
by CityminHi all,
S/N : 5RNK9FFT70...-
- Loading...
