HP ProBook 650 G2 6050a2723701-mb-a02
  • lucasa_alvez
    • Jun 2017
    • 13
    • brazil
    BIOS HP ProBook 650 G2
    6050a2723701-mb-a02
  • tanveer920
    • Jul 2015
    • 32
    • INDIA
    Re: HP ProBook 650 G2 6050a2723701-mb-a02
    i have admin password anybody can help ???????
    • imranromi
      • Jan 2015
      • 1290
      • Pakistan
      Try this and reply.
      • ravenmx
        • May 2018
        • 182
        • puebla
        iranromi, i check your bin file, but the laptop power on in black screen, y check the original bin file , the laptop works fine, but have password bios. any idea?
        • ravenmx
          • May 2018
          • 182
          • puebla
          Any solution?
          • mielta
            • Apr 2015
            • 368
            Hi
            Try this
            • ravenmx
              • May 2018
              • 182
              • puebla
              this my backup, this have password, any can help me please
              • mcm022006
                • Jan 2015
                • 24
                • romania
                bios hp probook 650 g2
                hello, can someone help me with a repair to a bios dump from a hp probook 650 g2?
                it powers on and nothing on display, and makes 2 long beels then 2 short ones
                here is an attachement of the dump. thank you
                • Jeroentje
                  • Dec 2017
                  • 82
                  • Nederland
                  Re: bios hp probook 650 g2
                  this is stock bios and unlocked descriptor with youre intel image, remember you have to brand it again with NbDmiFit-2.10+ with your serial(s)
                  goodluck
                  • mcm022006
                    • Jan 2015
                    • 24
                    • romania
                    thanks, IT WORKS!!
                    • peben
                      • Mar 2017
                      • 6
                      • Netherlands
                      I have same issue with my probook 650 g2.
                      when turning the laptop on, it gives 2 long beeps followed by two short beeps.
                      can somebody help me.
                      dump as attachment
                      thanx in advance
                      • Jeroentje
                        • Dec 2017
                        • 82
                        • Nederland
                        Try this, unlocked and fresh bios, next step could be to clean up the me, but takes extra time
                        • VasX
                          • Sep 2016
                          • N/A
                          Hello! Can you help me? My laptop behaves the same way, turns on and makes 2 long, then 2 short sounds. Here is my bios. Thanks.
                          • peben
                            • Mar 2017
                            • 6
                            • Netherlands
                            Thanx it worked
                            • maksudpabel
                              • Mar 2015
                              • france
                              is this ok ?
                              • dv007
                                • Jul 2014
                                hp probook 650 g2 corrupted bios
                                I have a HP 650 G2. Without memory it just beeps. With memory it does a boot and restart loop with no picture on display. Battery charges fine. I've attached a bios dump. Can someone please help me fix this bios? Thanks
                                • peste
                                  • 13917
                                  • ROMANIA
                                  Re: hp probook 650 g2 corrupted bios
                                  https://www.badcaps.net/forum/showth...probook+650+g2
                                  https://www.badcaps.net/forum/showth...ghlight=650+g2
                                  try...
                                  • dv007
                                    • Jul 2014
                                    Thanks peste. Didn't have a chance to use your file.
                                    I Managed to get my laptop working again. For those with similar problem. Here is how I did it.
                                    I downloaded latest bios directly from HP website and use UEFITool_v0.26.0 (google it to download) to replace the bios section of the corrupted dump with the bios from HP (N76_0139.bin). Laptop started fine with the modded bios but with "Manufacturer Programming Mode is in Unlock Mode". I then used NbDmiFit_2.10 to set all the manufacture info and lock the mpm. You can get the your hp laptop info from http://pro-psurf-web-glb.austin.hp.com/Search.aspx with serial #.
                                    Installed windows 10 but it's not auto activated .
                                    • mcplslg123
                                      • Jun 2015
                                      • 7262
                                      • india
                                      Check for windows key in your edited bios and original bios and compare. I doubt, you lost the win key in overwriting bios region with uefi tool. If so, you can re insert it with hex editor.
                                      • vignesharivuslm
                                        • Nov 2014
                                        • 33
                                        • India
                                        Working bios please i tried many bios above. Display not comes, stock rom bios also lost, before that display comes... Urgent sir
                                        • studdy05
                                          Bricked HP Probook 450 G7 Bios questions
                                          by studdy05
                                          Hp Probook 450 G7 s# SCD0348W35 had a locked BIOS. Bought BIOS and EC chips off Ebay that were supposed to match this machine - the 450 G7. Flashed in the BIOS on chip i bought using a CH341. BIOS unlocked next boot. Some error to contact HP. Entered BIOS and reset to system defaults and rebooted. Machine worked fine but every cold boot the contact HP message popped and everything else worked as fine. Assumed the error was from EC chip not matching BIOS that i just flashed in. So i flashed in the EC that was supposed to match from the EBay chip i bought and instant brick.
                                          Ive got...
                                          07-08-2025, 09:24 PM
                                        • intelg
                                          HP Elitedesk 800 G6 lost BIOS admin password
                                          by intelg
                                          Hello everyone, I am looking for help as I am struggling to remove lost BIOS Admin password on an HP EliteDesk G6 800 series desktop. I wanted to reset the vPro remote control IP kvm for homelab use.
                                          Here is the hardware identification specs:
                                          HP EliteDesk 800 G6 Desktop Mini PC
                                          Intel(R) Core(TM) i5-10500 CPU @ 3.10GHZ 16384 MB RAM
                                          BIOS ver S21 Ver. 02.05.01 01/05/2021
                                          Born on date: 07/26/2021
                                          SN MXL11841GN
                                          SKU 3X8V9UCHABA
                                          UUID 8116E79EF6FFE94DB0B98A3188270C5C
                                          SYSTEM BOARD ID 8710
                                          SYSTEM BOARD CT NUKBER PJLHQ0A8JF236L...
                                          11-03-2023, 02:05 AM
                                        • Phad
                                          Seeking help and advice to remove bios admin password – HP ProBook 4520s
                                          by Phad
                                          Dear All,
                                          Hope that this post is at the right place of the forum.
                                          I am seeking help and technical advice to remove bios admin password from HP ProBook 4520s.
                                          The laptop is operating normally and, I am not facing any major issue with it except; the bios admin password that I found about by coincidence only few weeks back.
                                          As the laptop is operating normally, I am reluctant to take it to a workshop to de-solder the bios chip in order to read it by an external programmer, as I am not an expert in doing such a thing.
                                          After...
                                          11-10-2021, 12:05 AM
                                        • macabook
                                          by macabook
                                          🧩 Initial Issue
                                          07-24-2025, 02:17 PM
                                        • cr4zychriss
                                          by cr4zychriss
                                          • Rebrand: PC Specialist
                                          11-14-2025, 04:04 PM
