6050a2723701-mb-a02
HP ProBook 650 G2 6050a2723701-mb-a02
Tags: None
Re: HP ProBook 650 G2 6050a2723701-mb-a02
i have admin password anybody can help ???????Attached FilesPremium supporters get full download access and other benefits.
Try this and reply.Attached FilesPremium supporters get full download access and other benefits.
Hi
Try thisAttached FilesPremium supporters get full download access and other benefits.
this my backup, this have password, any can help me pleaseAttached FilesPremium supporters get full download access and other benefits.
bios hp probook 650 g2
hello, can someone help me with a repair to a bios dump from a hp probook 650 g2?
it powers on and nothing on display, and makes 2 long beels then 2 short ones
here is an attachement of the dump. thank youAttached FilesPremium supporters get full download access and other benefits.
Re: bios hp probook 650 g2
this is stock bios and unlocked descriptor with youre intel image, remember you have to brand it again with NbDmiFit-2.10+ with your serial(s)
goodluckAttached FilesPremium supporters get full download access and other benefits.
I have same issue with my probook 650 g2.
when turning the laptop on, it gives 2 long beeps followed by two short beeps.
can somebody help me.
dump as attachment
thanx in advanceAttached FilesPremium supporters get full download access and other benefits.
Try this, unlocked and fresh bios, next step could be to clean up the me, but takes extra time
Hello! Can you help me? My laptop behaves the same way, turns on and makes 2 long, then 2 short sounds. Here is my bios. Thanks.Attached FilesPremium supporters get full download access and other benefits.
hp probook 650 g2 corrupted bios
I have a HP 650 G2. Without memory it just beeps. With memory it does a boot and restart loop with no picture on display. Battery charges fine. I've attached a bios dump. Can someone please help me fix this bios? ThanksAttached FilesPremium supporters get full download access and other benefits.
Re: hp probook 650 g2 corrupted bios
https://www.badcaps.net/forum/showth...probook+650+g2
https://www.badcaps.net/forum/showth...ghlight=650+g2
try...Attached FilesPremium supporters get full download access and other benefits.
Last edited by peste; 05-29-2019, 02:36 AM.If you have found our forum useful please consider supporting us. Subscribe for a small monthly fee and receive extra benefits including our boardview / schematic archive.
It only takes 1 minute:
https://www.badcaps.net/settings/subscriptionsComment
Thanks peste. Didn't have a chance to use your file.
I Managed to get my laptop working again. For those with similar problem. Here is how I did it.
I downloaded latest bios directly from HP website and use UEFITool_v0.26.0 (google it to download) to replace the bios section of the corrupted dump with the bios from HP (N76_0139.bin). Laptop started fine with the modded bios but with "Manufacturer Programming Mode is in Unlock Mode". I then used NbDmiFit_2.10 to set all the manufacture info and lock the mpm. You can get the your hp laptop info from http://pro-psurf-web-glb.austin.hp.com/Search.aspx with serial #.
Installed windows 10 but it's not auto activated
Check for windows key in your edited bios and original bios and compare. I doubt, you lost the win key in overwriting bios region with uefi tool. If so, you can re insert it with hex editor.Comment
by chriswfrye21Hi everyone,
I’m working on an HP 255R 15.6" G10 Notebook PC that has a BIOS Administrator / Setup password I cannot bypass. I can boot Windows normally, but F10 is completely blocked unless the password is entered. I do not know the password.
This is not a Power‑On Password. This is a BIOS Admin password stored in NVRAM, and the system will not allow BIOS access at all.
I’m posting here to get help identifying the correct procedure, dump, or method needed to clear the password on this model. System Details
Model: HP 255R 15.6 inch G10 Notebook PC SK...-
Channel: BIOS Requests ONLY!
by studdy05Hp Probook 450 G7 s# SCD0348W35 had a locked BIOS. Bought BIOS and EC chips off Ebay that were supposed to match this machine - the 450 G7. Flashed in the BIOS on chip i bought using a CH341. BIOS unlocked next boot. Some error to contact HP. Entered BIOS and reset to system defaults and rebooted. Machine worked fine but every cold boot the contact HP message popped and everything else worked as fine. Assumed the error was from EC chip not matching BIOS that i just flashed in. So i flashed in the EC that was supposed to match from the EBay chip i bought and instant brick.
Ive got... -
by riallioHi Guys
I need help repairing/rebuilding the BIOS for an HP ProBook 630 G8 with no display.
I have read the BIOS chip twice using a CH341A and a WSON8 probe. Both reads match exactly, so I believe the dump is reliable.
Machine details found from my original BIOS dump:
Model: HP ProBook 630 G8 Notebook PC
Platform: T72
Current BIOS: T72 Ver. 01.12.00
System board ID: 87EA
KBC Version: 33.22.00
CPU: Intel Core i5-1145G7
BIOS chip: Macronix MX25L25673GZ4I-08G
Chip size: 32MB / 33,554,432 bytes
by intelgHello everyone, I am looking for help as I am struggling to remove lost BIOS Admin password on an HP EliteDesk G6 800 series desktop. I wanted to reset the vPro remote control IP kvm for homelab use.
Here is the hardware identification specs:
HP EliteDesk 800 G6 Desktop Mini PC
Intel(R) Core(TM) i5-10500 CPU @ 3.10GHZ 16384 MB RAM
BIOS ver S21 Ver. 02.05.01 01/05/2021
Born on date: 07/26/2021
SN MXL11841GN
SKU 3X8V9UCHABA
UUID 8116E79EF6FFE94DB0B98A3188270C5C
SYSTEM BOARD ID 8710
SYSTEM BOARD CT NUKBER PJLHQ0A8JF236L...-
by vic6688Hello everyone,
I would like to ask for your help with my ASUS desktop.
Model:
ASUS ExpertCenter D700SA
BIOS:
AMI Aptio V
BIOS Flash:
Winbond W25Q128JV (16MB)
I forgot the BIOS Administrator password.
I have already read and verified the complete BIOS dump using a CH341A programmer, and I have attached the original 16MB BIOS dump.
If possible, I would prefer to recover or identify the current BIOS password so that I can continue using the original BIOS without reflashing.
If...-
- Loading...
