HP ProBook 650 G2 6050a2723701-mb-a02
  • lucasa_alvez
    • Jun 2017
    • 13
    • brazil
    BIOS HP ProBook 650 G2
    6050a2723701-mb-a02
  • tanveer920
    • Jul 2015
    • 32
    • INDIA
    Re: HP ProBook 650 G2 6050a2723701-mb-a02
    i have admin password anybody can help ???????
    • imranromi
      • Jan 2015
      • 1288
      • Pakistan
      Try this and reply.
      • ravenmx
        • May 2018
        • 171
        • puebla
        iranromi, i check your bin file, but the laptop power on in black screen, y check the original bin file , the laptop works fine, but have password bios. any idea?
        • ravenmx
          • May 2018
          • 171
          • puebla
          Any solution?
          • mielta
            • Apr 2015
            • 368
            Hi
            Try this
            • ravenmx
              • May 2018
              • 171
              • puebla
              this my backup, this have password, any can help me please
              • mcm022006
                • Jan 2015
                • 24
                • romania
                bios hp probook 650 g2
                hello, can someone help me with a repair to a bios dump from a hp probook 650 g2?
                it powers on and nothing on display, and makes 2 long beels then 2 short ones
                here is an attachement of the dump. thank you
                • Jeroentje
                  • Dec 2017
                  • 82
                  • Nederland
                  Re: bios hp probook 650 g2
                  this is stock bios and unlocked descriptor with youre intel image, remember you have to brand it again with NbDmiFit-2.10+ with your serial(s)
                  goodluck
                  • mcm022006
                    • Jan 2015
                    • 24
                    • romania
                    thanks, IT WORKS!!
                    • peben
                      • Mar 2017
                      • 6
                      • Netherlands
                      I have same issue with my probook 650 g2.
                      when turning the laptop on, it gives 2 long beeps followed by two short beeps.
                      can somebody help me.
                      dump as attachment
                      thanx in advance
                      • Jeroentje
                        • Dec 2017
                        • 82
                        • Nederland
                        Try this, unlocked and fresh bios, next step could be to clean up the me, but takes extra time
                        • VasX
                          • Sep 2016
                          • 4
                          • N/A
                          Hello! Can you help me? My laptop behaves the same way, turns on and makes 2 long, then 2 short sounds. Here is my bios. Thanks.
                          • peben
                            • Mar 2017
                            • 6
                            • Netherlands
                            Thanx it worked
                            • maksudpabel
                              • Mar 2015
                              • france
                              is this ok ?
                              • dv007
                                • Jul 2014
                                • 3
                                hp probook 650 g2 corrupted bios
                                I have a HP 650 G2. Without memory it just beeps. With memory it does a boot and restart loop with no picture on display. Battery charges fine. I've attached a bios dump. Can someone please help me fix this bios? Thanks
                                • peste
                                  • Dec 2016
                                  • 12859
                                  • ROMANIA
                                  Re: hp probook 650 g2 corrupted bios
                                  https://www.badcaps.net/forum/showth...probook+650+g2
                                  https://www.badcaps.net/forum/showth...ghlight=650+g2
                                  try...
                                  • dv007
                                    • Jul 2014
                                    • 3
                                    Thanks peste. Didn't have a chance to use your file.
                                    I Managed to get my laptop working again. For those with similar problem. Here is how I did it.
                                    I downloaded latest bios directly from HP website and use UEFITool_v0.26.0 (google it to download) to replace the bios section of the corrupted dump with the bios from HP (N76_0139.bin). Laptop started fine with the modded bios but with "Manufacturer Programming Mode is in Unlock Mode". I then used NbDmiFit_2.10 to set all the manufacture info and lock the mpm. You can get the your hp laptop info from http://pro-psurf-web-glb.austin.hp.com/Search.aspx with serial #.
                                    Installed windows 10 but it's not auto activated .
                                    • mcplslg123
                                      • Jun 2015
                                      • 7262
                                      • india
                                      Check for windows key in your edited bios and original bios and compare. I doubt, you lost the win key in overwriting bios region with uefi tool. If so, you can re insert it with hex editor.
                                      • vignesharivuslm
                                        • Nov 2014
                                        • 31
                                        • India
                                        Working bios please i tried many bios above. Display not comes, stock rom bios also lost, before that display comes... Urgent sir
                                        widgetinstance 457 (Related Topics) skipped due to lack of content & hide_module_if_empty option.
