acer v5-571 bios corrupted . need repair
  • dellxps15
    • Feb 2014
    • 1598
    • italy
    hi, i have this notebook and i had to change the intel nb with a new one. after that i had to program bios, because it give me black screen. now pc power on, but i need original bios for windows install.
    any help would be great.
  • samanthban
    • Feb 2014
    • 253
    • Sri lanka
    Re: acer v5-571 bios corrupted . need repair
    try this
    sigpic
    • dellxps15
      • Feb 2014
      • 1598
      • italy
      tnx for reply, but i need my bios fixed so i can restore the windows 8 key inside it
      • ala_borbe
        aka Donald
        • 1625
        • Malta
        what happened with update? what was version before update? in your dump is strange me version... details would help, it would be easier to help if you are willing to experiment, maybe i can help...
        edit:
        here is my first test file gl
        Im Back... sort of...
        • dellxps15
          • Feb 2014
          • 1598
          • italy
          i dont know wich version it had. i got this notebook not working and i replaced intel northbridge with a new one. after solder the new one pc power on but didnt post , so i saved original bios and put bios from acer site and now it power on normal, but doing so ive lost windows 8 original key.
          that's all i know about this laptop.
          ill try ur fix and see if it's ok
          • ala_borbe
            aka Donald
            • 1625
            • Malta
            ok, take your time... for a while i had idea to test and try that win8 licencing sh*t but never had any laptop suitable... maybe together we can do it
            u can use rweverything to see if serial is embedded in bios ok
            here is tool
            Code:
            http://rweverything.com/download/
            here is how
            • dellxps15
              • Feb 2014
              • 1598
              • italy
              ok, that utility didnt open bin file, it read your own bios in laptop directly, so i have to flash ur fixed bios, install windows and then give it a try. if that work, can i just save key file , flash newer bios and put serial back so im sure all other things of bios are ok ?
              tnx very much for reply. this notebook is ok for testing, since it has the power on botton into mainboard. can use mainboard only with monitor+vga+keyboard by usb.
              • ala_borbe
                aka Donald
                • 1625
                • Malta
                ehm, this tool does not open bin file, it reads serial for win8 from windows... all you need is to install matching win8 version (core, pro, enterprise), read key, activate windows (must be connected on net) and it shuld work... ive done it few times on Toshiba laptops
                that will work if i fixed bios propertly
                • dellxps15
                  • Feb 2014
                  • 1598
                  • italy
                  tried ur bios, but it wont give post
                  • khaahk
                    • Dec 2013
                    • 830
                    • Estonia
                    You can find the windows number starting from address 6945D5h from your non-working dump. Try to insert it into working dump to the same address.
                    • meritosari
                      • Oct 2010
                      • 774
                      • Indonesia
                      very interesting
                      • ala_borbe
                        aka Donald
                        • 1625
                        • Malta
                        @khaahk
                        how did you know where to look for? (part of FFF12B8D-7696-4C8B-A985-2747075B4F50 guid?)
                        for this to work i think whole guid must be copied
                        @dellxps15
                        there are two bios on web update one v1.22 other 2.18
                        based on my expirience, those are for different motherboards, so i must picked wrong one :/
                        continuing...
                        • khaahk
                          • Dec 2013
                          • 830
                          • Estonia
                          Hexedit - search - for text - allow wildchar "?".
                          search string: ?????-?????-?????-?????-?????
                          • meritosari
                            • Oct 2010
                            • 774
                            • Indonesia
                            @khaahk
                            very-very good idea
                            • ala_borbe
                              aka Donald
                              • 1625
                              • Malta
                              never done this before, never expected to work from first attempt
                              its not only serial important, its the certificate also
                              this is easy for win7 but win8 does it harder
                              try this and report back
                              • dellxps15
                                • Feb 2014
                                • 1598
                                • italy
                                this one give me post
                                gonna install windows 8 to see if i can get windows key.
                                or as khaan say i can save key from one bios and then swap to other bios ?
                                edit: now i could also update bios to latest version ( if this is not the latest) and save it as my original bios dump.
                                tnx very much for the big help for now. will update u soon.
                                • ala_borbe
                                  aka Donald
                                  • 1625
                                  • Malta
                                  its latest version, and key is inserted, should also be visible with rweverything when you reinstall
                                  • dellxps15
                                    • Feb 2014
                                    • 1598
                                    • italy
                                    umh if i left uefi mode in bios it wont load any usb drive and wont load windows. if i put in legacy i was able to install windows, but as soon as i put back uefi in bios it wont load windows annymore and also wont boot from usb drive. rw didnt show me the msdm tab with serial.
                                    • dellxps15
                                      • Feb 2014
                                      • 1598
                                      • italy
                                      ok ive seen the windows key, but file version 2.18 is 13mb instead of 8mb.
                                      • ala_borbe
                                        aka Donald
                                        • 1625
                                        • Malta
                                        you cant boot uefi if you install system in legacy mode
                                        if you wont uefi, you must use GPT uefi file system partitions and usb and install cd myst be uefi compatible
                                        maybe this helps
                                        Code:
                                        http://www.eightforums.com/tutorials/2328-uefi-unified-extensible-firmware-interface-install-windows-8-a.html
                                        as for bios on web, bios file (13mb) contains boot files and flash utility all in one file, bios file must be extracted from it...
                                        • James194zt
                                          Acer Nitro 50-640E Corrupted BIOS Dump
                                          by James194zt
                                          My daughter has accidentally managed to kill her Acer gaming desktop it has a blank screen after updating and when you press the power button the fans spin, light comes on and it makes 1 long and 1 short beep and no attempt to boot.
                                          All basic troubleshooting has been done we replaced CPU, GPU and RAM from a working machine and no joy, I also noticed a post on here with the same issue and it was the BIOS. I am pretty sure also because it was doing a BIOS update that stopped it working, she knocked the keyboard out by accident during the update and the screen just went...
                                          04-28-2025, 03:29 PM
                                        • EbrahimSiami
                                          Acer Aspire 5920G - Requesting Modded BIOS (9600M GT) from .WPH for CH341A Flasher
                                          by EbrahimSiami
                                          I need help with my Acer Aspire 5920G laptop. Its original GeForce 8600M GT graphics card failed, so I replaced it with an Nvidia GeForce 9600M GT MXM card.
                                          **Problem:** The laptop powers on, but there is no display (black screen) on either the internal LCD or external monitor. This indicates a BIOS compatibility issue with the new graphics card.
                                          **What I have tried so far:**
                                          1. I have my **original stock BIOS dump (1MB .BIN file)** from my laptop, which works and allows the laptop to power on normally (but no display with 9600M...
                                          07-02-2025, 02:31 PM
                                        • FalconPunch
                                          Surface Pro X 1876 Bios corrupted
                                          by FalconPunch
                                          Hello everyone, I happen to have a Microsoft Surface Pro X 1876 in my hands. It was brought to me by a friends which happen to have taken off the bios chip to test another motherboard. Upon putting back the bios chip on the original motherboard, The PC is stucked on Windows logo and won t boot to bios or anything. I suspect that the changes of bios chip somehow corrupted the firmware inside. Is the hypothesis correct?
                                          Also i extracted the bios inside the chip which was on Winbond 25R128JWPQ you can find the file attached if you can fix it (if possible, I would like some insight on...
                                          08-09-2025, 03:56 AM
                                        • zlr8r
                                          Hp Zbook Firefly 14 G10 - corrupted Bios's ? - please check
                                          by zlr8r
                                          Greetings
                                          I am hoping someone could have a check of my Hp Zbook Firefly 14 G10 , 2 x 32MB Bios files... (powers on / black screen).
                                          Serial Number: 5CG3202C16
                                          Product #/SKU: 739P0AV
                                          CT Number: PRTUE00WBI30YX
                                          Description: HP ZBook Firefly 14 inch G10
                                          BuildID: 23WWWGAZ602#SABU#DABU
                                          Feature Byte: 476J6S6b7B7M7Q7U7W7m7saBaEapaqauawbUbhcAfPgSguhKj4jhk8mEn7nVngpDpVpWpnpqprqMqkqz.G3
                                          MAC address not found.
                                          • I extracted both 32mb bios files (Main + EC). But when i run the main 32mb bios through MFIT.exe , it produces this error; ie:,
                                          10-28-2025, 01:56 PM
                                        • TheKROCZ
                                          Acer IPIMB-AR R1.02A bios corrupted. Need help.
                                          by TheKROCZ
                                          Hello everyone. As the title says, my bios is corrupted. I have already checked every other possible solution like ram position and reset cmos but nothing worked. I have no idea how or why it happened. The motherboard takes hours to POST. When it does POST, it gives 1 long beep and 2 short beeps. After some scavenging on other forums, I discovered that it had something to do with video output. Not sure what else is damaged in the bios but I managed to take a dump of the bios.
                                          I wanted to reflash the bios chip with another dump from the net. Unfortunately, I could not find any for...
                                          01-25-2022, 09:44 PM
