Acer IPIMB-AR R1.02A bios corrupted. Need help.
  • TheKROCZ
    • Jan 2022
    • 8
    • Malaysia
    Hello everyone. As the title says, my bios is corrupted. I have already checked every other possible solution like ram position and reset cmos but nothing worked. I have no idea how or why it happened. The motherboard takes hours to POST. When it does POST, it gives 1 long beep and 2 short beeps. After some scavenging on other forums, I discovered that it had something to do with video output. Not sure what else is damaged in the bios but I managed to take a dump of the bios.
    I wanted to reflash the bios chip with another dump from the net. Unfortunately, I could not find any for my motherboard specifically.
    (Note: There are quite a few pcs from Acer, Gateway and HP with the same motherboard but not all use the same bios chips. Most have UEFI support. Sadly, that is not the case with my motherboard.)
    I tried flashing the bios update files from Acer's website but I quickly learnt that those files are just updates and not dumps. That did not help.
    I will upload my bios dump here. I really hope someone can take a look at it and point out what is wrong and upload a repaired copy of it. I would really appreciate that.
    OR
    My motherboard came from an Acer Aspire M1935 and it has a Winbond 25Q64FVSIG bios chip. I need a bios copy, version P01-A2L for it.
    Many thanks in advanced and Happy New Year.
  • peste
    • 13436
    • ROMANIA
    Re: Acer IPIMB-AR R1.02A bios corrupted. Need help.
    OR
    try..
    • TheKROCZ
      • Jan 2022
      • 8
      • Malaysia
      Originally posted by peste
      try..
      It works. Thanks a ton. However, it still takes a long time to POST. I could manage with that. All I had to do was flash the bios update file to solve that issue.
      Really appreciate your effort. Cheers and have good year ahead!
      • TheKROCZ
        • Jan 2022
        • 8
        • Malaysia
        For anyone who needs a working dump of P01-A2L for the IPIMB-AR Rev1.02A, here is a copy.
        • RJARRRPCGP
          • Jul 2004
          • 6304
          1 long and 2 short=Often means RAM init failure.
          ASRock B550 PG Velocita
          Ryzen 9 "Vermeer" 5900X
          Arc A770 16 GB
          eVGA Supernova G3 750W
          Alienware AW3423DWF OLED
          • James194zt
            Acer Nitro 50-640E Corrupted BIOS Dump
            by James194zt
            My daughter has accidentally managed to kill her Acer gaming desktop it has a blank screen after updating and when you press the power button the fans spin, light comes on and it makes 1 long and 1 short beep and no attempt to boot.
            All basic troubleshooting has been done we replaced CPU, GPU and RAM from a working machine and no joy, I also noticed a post on here with the same issue and it was the BIOS. I am pretty sure also because it was doing a BIOS update that stopped it working, she knocked the keyboard out by accident during the update and the screen just went...
            04-28-2025, 03:29 PM
          • glovecaps
            by glovecaps
            11-25-2024, 04:23 PM
          • oragano
            ASUS ex-b250-V7 motherboard bios corrupted - by me
            by oragano
            hey all, i did a silly thing and flashed bios to perfectly working board. None of the asus official download bios would work with ez flash. They all gave error saying not supported bios file. I tried using uefi tool to extract it to a bin file but then ez flash wouldnt even recognise it.
            So, i used freedos and afudos with the aforementioned bin file i extracted and forced the issue. After bios reprogram, reboot and it was dead. Fans spinning but no post.
            i have a bios writer and none of the .cap files from the official site work either. I just get one spin, then off, then all fans...
            10-17-2024, 02:53 AM
          • EbrahimSiami
            Acer Aspire 5920G - Requesting Modded BIOS (9600M GT) from .WPH for CH341A Flasher
            by EbrahimSiami
            I need help with my Acer Aspire 5920G laptop. Its original GeForce 8600M GT graphics card failed, so I replaced it with an Nvidia GeForce 9600M GT MXM card.
            **Problem:** The laptop powers on, but there is no display (black screen) on either the internal LCD or external monitor. This indicates a BIOS compatibility issue with the new graphics card.
            **What I have tried so far:**
            1. I have my **original stock BIOS dump (1MB .BIN file)** from my laptop, which works and allows the laptop to power on normally (but no display with 9600M...
            07-02-2025, 02:31 PM
          • fluzocapacitor
            ACER Aspire 5542 does not boot. Can not read BIOS on the motherboard
            by fluzocapacitor
            I am trying to fix an Acer Aspire 5542. Upon turning it on, the fan starts to spin for a few seconds and then it stops. I hear no beeps from the speaker. I have no image both on the laptop screen and through VGA and HDMI connectors.
            I measured voltages, and it seems all power supplies are OK. There are 5V, 3.3V (BIOS), 1.8V (RAM), and 1.1V (VCORE).
            I tried to read the BIOS using a CH341A programmer, but it did not detect the chip. I took the BIOS chip away from the motherboard, and then the CH341A detected the chip, and I was able to read the code. However,...
            02-01-2024, 01:24 PM
