acer v5-571 bios corrupted . need repair
  • dellxps15
    • Feb 2014
    • 1598
    • italy
    Re: acer v5-571 bios corrupted . need repair
    big damn, flashed back original 1.22 bios so i could updrage to 2.18 and then backup and compare bios, but after desolder bios, pc now wont power on annymore and cant figure out why. for me possible cause are:
    1) lost 3.3 5volt
    2)while heating bios chip i heated reballed nb that got leaded balls, but looks strange since i use alluminium near bios.
    flashed also back ur bios again but still the same. pc looks like dead.
    now i have to look for schematic.
    edit: ok 3.3 and 5volt comes after pressing power botton, but still pc doesnt turn on. now or bad bios chip or bad nb again and i need to rework it for the 2nd time....
    • meritosari
      • Oct 2010
      • 774
      • Indonesia
      that's why I prefer to use 2 pieces of iron solder just for desolder Soic8. for me more faster and safety for others component
      of course using K-type soldering tip
      • raajkumar
        • Mar 2015
        • 354
        • Srilanka
        I have a ACER aspire V5-571. All of the usb connectors not responding on this notebook. I try with webcam also. i checked power of the usb connectors it shows 4.98V on VCC. And D-, D+ also showing 2.23V and 2.78v is it ok. But it is not responding any devices connected through usb.
        • James194zt
          Acer Nitro 50-640E Corrupted BIOS Dump
          by James194zt
          My daughter has accidentally managed to kill her Acer gaming desktop it has a blank screen after updating and when you press the power button the fans spin, light comes on and it makes 1 long and 1 short beep and no attempt to boot.
          All basic troubleshooting has been done we replaced CPU, GPU and RAM from a working machine and no joy, I also noticed a post on here with the same issue and it was the BIOS. I am pretty sure also because it was doing a BIOS update that stopped it working, she knocked the keyboard out by accident during the update and the screen just went...
          04-28-2025, 03:29 PM
        • EbrahimSiami
          Acer Aspire 5920G - Requesting Modded BIOS (9600M GT) from .WPH for CH341A Flasher
          by EbrahimSiami
          I need help with my Acer Aspire 5920G laptop. Its original GeForce 8600M GT graphics card failed, so I replaced it with an Nvidia GeForce 9600M GT MXM card.
          **Problem:** The laptop powers on, but there is no display (black screen) on either the internal LCD or external monitor. This indicates a BIOS compatibility issue with the new graphics card.
          **What I have tried so far:**
          1. I have my **original stock BIOS dump (1MB .BIN file)** from my laptop, which works and allows the laptop to power on normally (but no display with 9600M...
          07-02-2025, 02:31 PM
        • FalconPunch
          Surface Pro X 1876 Bios corrupted
          by FalconPunch
          Hello everyone, I happen to have a Microsoft Surface Pro X 1876 in my hands. It was brought to me by a friends which happen to have taken off the bios chip to test another motherboard. Upon putting back the bios chip on the original motherboard, The PC is stucked on Windows logo and won t boot to bios or anything. I suspect that the changes of bios chip somehow corrupted the firmware inside. Is the hypothesis correct?
          Also i extracted the bios inside the chip which was on Winbond 25R128JWPQ you can find the file attached if you can fix it (if possible, I would like some insight on...
          08-09-2025, 03:56 AM
        • zlr8r
          Hp Zbook Firefly 14 G10 - corrupted Bios's ? - please check
          by zlr8r
          Greetings
          I am hoping someone could have a check of my Hp Zbook Firefly 14 G10 , 2 x 32MB Bios files... (powers on / black screen).
          Serial Number: 5CG3202C16
          Product #/SKU: 739P0AV
          CT Number: PRTUE00WBI30YX
          Description: HP ZBook Firefly 14 inch G10
          BuildID: 23WWWGAZ602#SABU#DABU
          Feature Byte: 476J6S6b7B7M7Q7U7W7m7saBaEapaqauawbUbhcAfPgSguhKj4jhk8mEn7nVngpDpVpWpnpqprqMqkqz.G3
          MAC address not found.
          • I extracted both 32mb bios files (Main + EC). But when i run the main 32mb bios through MFIT.exe , it produces this error; ie:,
          10-28-2025, 01:56 PM
        • TheKROCZ
          Acer IPIMB-AR R1.02A bios corrupted. Need help.
          by TheKROCZ
          Hello everyone. As the title says, my bios is corrupted. I have already checked every other possible solution like ram position and reset cmos but nothing worked. I have no idea how or why it happened. The motherboard takes hours to POST. When it does POST, it gives 1 long beep and 2 short beeps. After some scavenging on other forums, I discovered that it had something to do with video output. Not sure what else is damaged in the bios but I managed to take a dump of the bios.
          I wanted to reflash the bios chip with another dump from the net. Unfortunately, I could not find any for...
          01-25-2022, 09:44 PM
