hp elitbook 845 G10 bios locked
  • ivojk
    • Jun 2013
    • 4
    • BG
    #81
    Solved
    • tanneride
      • Jan 2025
      • 7
      hello please unlock my HP elitebook 845 G10. Tried the EC unlock script and the HPUnlocker with no luck.
      SN#: 2MQ41907D8
      ProdID: A00MFUP
      • peter99
        • Mar 2025
        • 21
        • kenya
        #83
        I replaced the "new "mainboard for my HP laptop elitebook , I often get the error "FAR must be enabled before MPM can be locked".
        I filled in all the DMI information, selected Lock MPM, but it can't be Locked.
        Please help me. How to fix?
        Thank you very much!!!
        Laptop HP EliteBook 845 G10
        serinumber: 5CD0B9KM24
        • peste
          peste commented
          Editing a comment
          post merged..next time look for a thread with the name and model, motherboard model of the laptop, and post there, if you can't find it, then make a new thread..
      • peter99
        • Mar 2025
        • 21
        • kenya
        #84
        every body can help ?
        • Stefan Steff
          • Mar 2024
          • 310
          • Romania
          #85
          Try this DMI file
          • peter99
            • Mar 2025
            • 21
            • kenya
            #86
            Originally posted by Stefan Steff
            Try this DMI file
            thanks! this working !
            • peter99
              • Mar 2025
              • 21
              • kenya
              #87
              Try this DMI file
              I have a problem: I add full information . but still have error "Your system is not fully configured. Please contact HP customer support."
              can you help me fix DMI ?
              thanks !!!!
              • Stefan Steff
                • Mar 2024
                • 310
                • Romania
                #88
                thanks !!!!
                Start from 0 again.
                Write your BIOS and fill DMI correctly.
                • peter99
                  • Mar 2025
                  • 21
                  • kenya
                  #89
                  Start from 0 again.
                  I still don't understand what you mean. In this case, I only have the way to load a new bios.
                  Can you explain in detail?
                  • Stefan Steff
                    • Mar 2024
                    • 310
                    • Romania
                    #90
                    Yes it's exactly what I mean...Write your BIOS chip again with the content what you provided in post 83
                    There is no error "Your system is not fully configured. Please contact HP customer support." right?...just the FAR error...
                    Then try to rewrite your DMI data according to what you have...even without any tool, just go to BIOS settings and enter the missing data at option "Set Machine Unique Data" when entering the bios...you have it all in the second file you provided in post 83
                    • peter99
                      • Mar 2025
                      • 21
                      • kenya
                      #91
                      ok, i will try !
                      thank you so much !!!
                      • Echoo
                        • Apr 2018
                        • 91
                        • Budapest
                        #92
                        Have a nice day!
                        Can I find a description somewhere for the newer series of HP machines that no longer work with HPUnlocker? I don't want to post on the forum with every machine if I can solve it myself.
                        • Echoo
                          • Apr 2018
                          • 91
                          • Budapest
                          #93
                          I tried it based on the video I found on youtube, but the password remains, but the keyboard is not detected. I will upload the original bios, please someone delete the password!
                          EliteBook 845 G10
                          SN: 5CG3416K5W
                          ProdID: 70A35AV
                          • Udemzy
                            • May 2017
                            • 162
                            • Guatemala
                            #94
                            ok, i will try !
                            to fix the system not fully configured,download NbDmifit 2.0 extract and locate ssm.dat run it and click on yes then restart.
                            • tanneride
                              • Jan 2025
                              • 7
                              Echoo the fix for the intel hardware for this generation is to wipe the EC firmware NVRamActriveRegn section, about 4Kb. That section isn't populated in the AMD EC firmware but i've found it in a different area. Going to try wiping it and see if works!
                              • tanneride
                                • Jan 2025
                                • 7
                                Reporting back that it did not work :/ didn't brick the system or see any messages about bios recovery which we get when we make any edits to the main bios - but the bios password remained
                                Also tried wiping the EC firmware entire, system recovered it. So i tried wiping the EC firmware and flashing an 'unlocked bios' created with the older HPUnlocker tool. Still no dice.
                                • tanneride
                                  • Jan 2025
                                  • 7
                                  Looks like somebody figured this all out months ago. Trying this now, post 161
                                  https://www.badcaps.net/forum/troubl...g10-bios/page9
                                  Edit - I need to learn how to read, this is the Intel based system. Naturally the ECUnlock script works.
                                  • farouk_1994
                                    • Mar 2021
                                    • 395
                                    • algeria
                                    #98
                                    hello i have hp 845 g10 bios locked
                                    SN: 5CG4290M9W
                                    • fauzanmint
                                      • Jun 2018
                                      • 80
                                      • Indonesia
                                      #99
                                      SN: 5CG4290M9W
                                      send the 16mb EPROM backup results
                                      • danito
                                        • Jun 2016
                                        • 1049
                                        • Romania
                                        #100
                                        SN: 5CG4290M9W
                                        try
                                        • zenius
                                          by zenius
                                          12-08-2024, 06:13 AM
                                        • macabook
                                          by macabook
                                          🧩 Initial Issue
                                          07-24-2025, 02:17 PM
                                        • kuraimangetsu
                                          DELL VOSTRO LA-L246P BIOS LOCKED NEED TO UNLOCK
                                          by kuraimangetsu
                                          Hi guys
                                          i have this laptop with locked bios!
                                          tried to flash it with some bins i found but with no vail. either no boot up at all or boots to green blue red screens only!
                                          tried to download latest bios from dell site and exctracted bin files from exe bios but got no boot at all after flashing that
                                          here is the dumbs for both chips 16 and 8
                                          12-24-2023, 05:04 AM
                                        • salim5566
                                          loking for bio tool that hve all feature like ps5 bios and laptop bios unlock and repair 1 tool can do all please good tool?
                                          by salim5566
                                          Hi guys i like to buy tool that automatic unlock bios or find password also can flash and repair bios ic, looking for good tool have good software that have 1 click and unlock bios any recommend good tool? looking for sony ps5 and and laptop bios
                                          06-26-2025, 03:25 PM
                                        • Vesko356
                                          by Vesko356
                                          08-11-2023, 03:27 AM
