hp elitbook 845 G10 bios locked
  • farouk_1994
    • Mar 2021
    • 405
    • algeria
    #101
    Originally posted by fauzanmint
    send the 16mb EPROM backup results
    their is only 32 mb and thank's i solved it
    • tanneride
      Pro Meddler
      • Jan 2025
      • 9
      Originally posted by danito
      try
      If you don't mind, care to explain the process to unlock these AMD HP bios? At a glance it looks like a few VSS entries have been wiped. I tried similar edits but would get an error on boot and the EC would restore everything.
      • vader191095
        • Oct 2025
        • CZ
        #103
        Please password Elitebook 845 G10
        SN: 5CG43231QG
        • peste
          • 14459
          • ROMANIA
          #104
          Originally posted by vader191095
          Please password Elitebook 745 G10
          SN: 5CG43231QG
          post S/N, full name and model, motherboard model, ..product number,etc.
          post the contents of the bios chip even if it is corrupted..
          • vader191095
            • Oct 2025
            • CZ
            #105
            This Is HP elitebook 845 G10 motherboard HP 8B6E ID 9L7X7AV
            • peste
              • 14459
              • ROMANIA
              #106
              The bios chip must be unsoldered from the board before writing or reading..
              do not use the clip, you may have errors..if you do not have anything to unsolder it with,
              solder wires between the programmer and the bios chip..
              you need an SPI programmer...here is a video for example..https://www.youtube.com/watch?v=DWWi...nnel=ThisIsHow
              • miyagik
                • Jun 2018
                • 37
                • Mexico
                #107
                Hello I have it with BIOS password
                HP Elitebook 845 G10 AMD
                S/N: C2L41702NY
                SKU: A00MFUP#ABA
                Thanks in advance!
                • miyagik
                  • Jun 2018
                  • 37
                  • Mexico
                  #108
                  S/N: C2L41702NY
                  SKU: A00MFUP#ABA
                  Thanks in advance!
                  Sorry here is full info
                  S/N: C2L41702NY
                  PRODID: A00MFUP#ABA
                  System ID: 8B6E
                  • peter99
                    • Mar 2025
                    • 35
                    • kenya
                    #109
                    S/N: C2L41702NY
                    SKU: A00MFUP#ABA
                    Thanks in advance!
                    try!
                    • miyagik
                      • Jun 2018
                      • 37
                      • Mexico
                      #110
                      Originally posted by peter99
                      try!
                      password still exist no changes
                      • danito
                        • Jun 2016
                        • 1329
                        #111
                        S/N: C2L41702NY
                        SKU: A00MFUP#ABA
                        Thanks in advance!
                        try
                        • miyagik
                          • Jun 2018
                          • 37
                          • Mexico
                          #112
                          try
                          still with password, first boot always recovery identity data from embbed controller due to data missmatch
                          any ideas ?
                          • Uknown001
                            • Feb 2025
                            • Philippines
                            #113
                            Hi, I was trying to back up my HP Elitebook 845 G10 (AMD Ryzen 5 pro) but during the process it got corrupted and i tried to flash other firmware it doesn't detect storage and it automatically power off. Anyone can help it will be a big help.
                            S/N: 5CG4031ZG8
                            P/N: 8Y501UC
                            • rex98
                              • Feb 2023
                              • 1299
                              • Mandaue CEBU, Philippines
                              #114
                              I noticed there's a lot of unlock request for this model HP Elitebook 845 G10
                              i forgot to post this before its an old file of mine.
                              The patch won't work if the bios version is latest. use this bin flash both it won't work if you only flash the main you should Flash Both!
                              first boot press f10 apply factory defaults and restart, 2nd boot reset security settings to defaults and exit.
                              use BCU and put your original DMI read post # 5: https://www.badcaps.net/forum/troubl...90#post3756390
                              This bios is extracted from hp website and i put vss2 in it to make the patch work and fastboot.
                              To determine your BID use any hex editor and search for the BID. Ex: V82
                              frequently asked questions:
                              Where can i get cirrus amp calibration data? just use this input in BCU its pointless anyway coz its not touchscreen, everything would still work as normal.
                              Cirrus Discrete Amp Calibration Data
                              3000000002000000536B0601D3350B00C08BDF3A4EF2D90117013728536C0601D3350B003044513C4EF2D9011701C428
                              can i use this to my HP Elitebook 845 G10- yes
                              This is the is BID V82 only.
                              To determine your original DMI use my DMI tool: https://www.badcaps.net/forum/troubl...57-hp-dmi-tool
                              • jimore
                                • Nov 2020
                                • 183
                                • mexico
                                #115
                                Originally posted by minhdigital
                                Send to you, try
                                BRO ADMIN PASSWORD REMOVE
                                  • 22806
                                  RULES UPDATE for BIOS requests/offers AVOID BANNING, READ BEFORE POSTING
                                  You MUST:
                                  • Provide the full machine model number, serial number (or Service tag, SNID) and the board model number (see https://www.badcaps.net/forum/showthread.php?t=88758 ) ,The serial number, make, full model number, motherboard model and revision (except QR codes) must be written/typed at your request as per the rules. Not as a picture, part of the file name and so on.
                                  Badcaps relies on your donations to pay for hosting , site advertising goes nowhere near to covering these costs. If you have found my reply or post helpful please consider making a donation , thank you.
                                  • zlr8r
                                    • Feb 2023
                                    • 114
                                    Hi guys, would greatly appreciate help with a suspected corrupt Bios on my ;
                                    (make/model): HP EliteBook 845 14 G10 (AMD) - (no boot, flashes light 8 times - charges battery ok though). I replaced several chips and also suspect Bios corruption.
                                    (mobo): 6050A3458701-MB-A01 (Rev.1.10)
                                    (SPS): N50832-601
                                    (CT): PRWAB00WBIU6JN
                                    this is all the numbers i can find on the board ?
                                    Could someone please examine both bios files i read from the top and bottom bios chips, and Repair if possible ? thanks in advance
                                    32MB (Underside Bios Chip)
                                    32MB (Top-side Bios Chip)
                                    • danito
                                      • Jun 2016
                                      • 1329
                                      #118
                                      (SPS): N50832-601
                                      try with post 114
                                      • Ayrat Technology
                                        • Dec 2025
                                        • 5
                                        • Bangladesh
                                        #119
                                        try and report
                                        • zenius
                                          by zenius
                                          12-08-2024, 06:13 AM
                                        • macabook
                                          by macabook
                                          🧩 Initial Issue
                                          07-24-2025, 02:17 PM
                                        • TopPop
                                          Dell Latitude 5530 BIOS Password Removal Attempted but I Broke the Laptop
                                          by TopPop
                                          Sorry for the long story. I have a Dell Latitude 5530 (i7) laptop (South Peak 15 MLK MB DDR4 203102-1 FK8VG$JA) with an admin BIOS password that I want to remove. Service Tag: HYKFPT3. Other than that the laptop worked OK.
                                          I found a CH341A Black and went looking for the BIOS chip on the motherboard. After trying to read one chip that was a firmware chip but not the BIOS I think I found the BIOS chip labeled Winbond 25Q256JVEN. Altogether I think I found 4 different firmware chips in the laptop. The BIOS chip is a WSON8 6x8. I used the CH341A, NeoProgrammer, and a cheap pogo pin clip...
                                          12-14-2025, 09:40 PM
                                        • Akhlz001
                                          by Akhlz001
                                          09-20-2025, 07:15 PM
                                        • pirati
                                          by pirati
                                          10-27-2025, 04:20 PM
