Please unlock bios HP Zbook Firefly 14 G9
  • zzduczz
    • Mar 2014
    • 31
    • viet nam
    Please unlock bios zbook 14 g9.
    Last edited by Vesko356; 01-22-2024, 02:41 AM. Reason: "HP Zbook Firefly 14 G9" to thread title.
  • hoaca388
    Badcaps
    • Jan 2022
    • 12337
    Re: Please unlock bios zbook 14 g9
    Try and report
    • zzduczz
      • Mar 2014
      • 31
      • viet nam
      Originally posted by hoaca388
      Try and report
      thanks hoaca388,password is still there
      • qayyum786
        • Aug 2018
        • 1959
        • INDIA
        again
        • qayyum786
          • Aug 2018
          • 1959
          • INDIA
          Originally posted by qayyum786
          again
          forget to isolate file on post #4
          use this one
          • zzduczz
            • Mar 2014
            • 31
            • viet nam
            use this one
            thanks qayyum786,password is still there.I have returned the laptop to the customer.it's too hard to unlock
            • black0hackers
              • Jul 2020
              • 368
              write main bios file provided by me and 1st thing to do is to reset bios to factory defaults, save, restart and password will go on. Then, in Main tab you have "set machine unique data" and write there what it's written on the label inside the bottom cover.
              • zzduczz
                • Mar 2014
                • 31
                • viet nam
                Thanks black0hackers,good bios and clean password
                • zzduczz
                  • Mar 2014
                  • 31
                  • viet nam
                  after programming your bios, i can't find smbios uuid, i reprogrammed the original bios, the password is gone, don't enter smbios uuid, everything is perfect
                  • souaqi01
                    • Dec 2015
                    • 87
                    • Maroc
                    HI any one hlep me plz for unlock BIOS HP ZBook Firefly 14 G9
                    SN : 5CG31113GK
                    • hoaca388
                      Badcaps
                      • Jan 2022
                      • 12337
                      SN : 5CG31113GK
                      SN : 5CG31113GK
                      • souaqi01
                        • Dec 2015
                        • 87
                        • Maroc
                        SN : 5CG31113GK
                        THANK YOU VERY MUCH HOACA388
                        • trepachka
                          • Oct 2022
                          • 457
                          Please, help me remove bios lock for HP Zbook Firefly 14 G9 with Serial# 5CG3161CFB
                          I am providing 2 bin files, one from each 25W256JVEN chip I found. One chip is located at the front and the other chip is located on the back of the motherboard.
                          I am not sure which files is needed, so I am providing both.
                          Thank you kindly.
                          • hoaca388
                            Badcaps
                            • Jan 2022
                            • 12337
                            Thank you kindly.
                            Unlocked
                            • trepachka
                              • Oct 2022
                              • 457
                              Thank you. The bios lock is gone. However, I am getting "Device in manufacturing mode" message on boot. Is there a command I can run similar to Dell's Alt-F to exit this mode?
                              • qayyum786
                                • Aug 2018
                                • 1959
                                • INDIA
                                you can use hp tool BCU fill the further detail from bottom panel or from sticker
                                • trepachka
                                  • Oct 2022
                                  • 457
                                  It took me a while to figure out how to install the utility and use it successfully but the manufacturing mode has been disabled.
                                  Thank you for all your help.
                                  • volinakis
                                    • Jan 2021
                                    • 2874
                                    • N/A
                                    if you restart laptop how many times MPM counter shows it will exit from manufacturing mode (MPM). BCU have to be used under cmd.
                                    • trepachka
                                      • Oct 2022
                                      • 457
                                      The MPM counter started @ 35 and went down all the way to 1 but wouldn't go down any further until I provided the information provided by hoaca388 such "Feature Byte", "CT Number", etc.
                                      Only after I provided all of this information, the message on the screen came up and asked me whether I wanted to submit this file. Once I answered "Yes", then MPM went away.
                                      • redoxy
                                        • Sep 2018
                                        • 100
                                        Can someone please tell me what the part # of the BIOS chip is? I need to unlock my BIOS but when I opened the laptop, I see two Winbond 25W256JVEN chips (U367, U368) and I'm confused about which one is the correct chip to read/backup. Thanks in advance.
                                          SMDFlea commented
                                          Editing a comment
                                          Theres a clue in the filename at post 14. If youre still unsure just post both.
                                      • zlr8r
                                        Hp Zbook Firefly 14 G10 - corrupted Bios's ? - please check
                                        by zlr8r
                                        Greetings
                                        I am hoping someone could have a check of my Hp Zbook Firefly 14 G10 , 2 x 32MB Bios files... (powers on / black screen).
                                        Serial Number: 5CG3202C16
                                        Product #/SKU: 739P0AV
                                        CT Number: PRTUE00WBI30YX
                                        Description: HP ZBook Firefly 14 inch G10
                                        BuildID: 23WWWGAZ602#SABU#DABU
                                        Feature Byte: 476J6S6b7B7M7Q7U7W7m7saBaEapaqauawbUbhcAfPgSguhKj4jhk8mEn7nVngpDpVpWpnpqprqMqkqz.G3
                                        MAC address not found.
                                        • I extracted both 32mb bios files (Main + EC). But when i run the main 32mb bios through MFIT.exe , it produces this error; ie:,
                                        10-28-2025, 01:56 PM
                                        HP ZBook Firefly ZBook Firefly 14 G8 Mobile Workstation Bundle Mobile workstation Specification for Upgrade or Repair
                                        This specification for the HP ZBook Firefly ZBook Firefly 14 G8 Mobile Workstation Bundle Mobile workstation can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the ZBook Firefly 14 G8 Mobile Workstation Bundle boardview and ZBook Firefly 14 G8 Mobile Workstation Bundle schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on...
                                        09-07-2024, 05:20 AM
                                      • zlr8r
                                        Hp Zbook Firefly 14 G8 - mobo: corvette-605qa321330-mb-a01 - need all bios files checked
                                        by zlr8r
                                        hey guys,
                                        i have been working on for days a Hp Zbook Firefly 14 G8 - mobo: corvette-605qa321330-mb-a01.
                                        Doesn't Boot - only thing working is an LED flashing orange on/off, that's it
                                        - have tried cleaning the Main bios (ME region) which seems to have gone smoothly enough, and have re-soldered it back onto the board, but then I spotted an almost identical Bios chip near the EC on other side, but I don't know what is needed to be done with that bios ?
                                        - i have attached my original Main and EC bios's (they are both 32mb! chips)
                                        - i have...
                                        10-21-2025, 09:39 AM
                                      • zenius
                                        by zenius
                                        12-08-2024, 06:13 AM
                                      • CeeEee4
                                        HP ZBOOK FIREFLY 14 G10 A (AMD) Corrupt BIOS
                                        by CeeEee4
                                        Hello
                                        I have an HP ZBOOK FIREFLY 14 G10 A (AMD) model with HP Blink Error 2-2 (Main area DXE of BIOS has become corrupted and no binary recovery image available.) I have tried BIOS recovery USB but it didnt work.
                                        Tried using a "clean" bin extracted from the HP softpaq but laptop would not even respond to power button, although it had white LED on DC jack.
                                        Here is back up of the BIOS, hope somebody can help. Thanks
                                        09-16-2025, 09:07 AM
