Please unlock bios HP Zbook Firefly 14 G9
  • badr4k
    • Dec 2018
    • morocco
    Please unlock bios zbook 14 g9
  • redoxy
    • Sep 2018
    • 100
    Please help me remove BIOS password.
    Laptop Model: HP zBook Firefly 14 G9
    Serial #: 5CG24932R4
    Motherboard: FF14-MV-GBM 6050A3310001-MB-A01
    • qayyum786
      • Aug 2018
      • 1959
      • INDIA
      At 1st boot press F10 and RESET BIOS to factory defaults, save, restart and password will go on. After that enter in to bios setup and in Main tab you have "set machine unique data" and write there what it's written on the label inside the cover.
      Or use hp bcu tool
      • redoxy
        • Sep 2018
        • 100
        Or use hp bcu tool
        Thanks Gayyum786 for the quick response and the file. I followed the instructions but there was no option to reset BIOS. The first screen I saw was information stating "there was mismatch in the BIOS and it has been recovered" and the only option was to press OK.
        After that the BIOS lock is still on.
        Not sure if I did anything wrong.
        Thanks again for the help.
        • qayyum786
          • Aug 2018
          • 1959
          • INDIA
          Try again and make sure you follow the steps
          • redoxy
            • Sep 2018
            • 100
            Thanks!
            It worked. The BIOS password is removed but I have the MPM countdown. I have updated the device information through "Set Machine Unique Data" in the BIOS but still have the MPM enabled.
            I'll wait to see if it goes away after the countdown reaches 1.
            I will update the thread once the countdown reaches 1 or whenever, the MPM goes away.
            I appreciate the help.
            Cheers!
            • qayyum786
              • Aug 2018
              • 1959
              • INDIA
              #27
              Thanks!
              Cheers!
              use this HP BCU TOOL ( BIOS Configuration Utility) to fill the DMI info
              • redoxy
                • Sep 2018
                • 100
                A million thanks Guyyum786.That worked.
                For newbies like me, I found this how to video that was very helpful in using the HP BCU tool hp DMI tool || easy way to update serial no || manufacturing mode off (youtube.com)
                It does a walkthrough, original language is not English but provides texts in the video of the important steps so I was able to follow without understanding the language.
                Also, I run into an issue on boot with a MPM error "Cirrus Discrete Amp Calibration Data" Missing or invalid. I found the solution in another thread for HP EliteBook 840 G9 below:
                https://www.badcaps.net/forum/troubl...0-g9-error-mpm
                I just copied the code provided in post # 5 of that thread and it worked for the ZBook Firefly 14 inch G9.
                There is additional information on the same topic in the the thread below with another way of solving the Cirrus Discrete Amp Error
                https://www.badcaps.net/forum/troubl...k-830-g9/page2
                Thanks, again for all the help.
                Cheers!
                • qayyum786
                  • Aug 2018
                  • 1959
                  • INDIA
                  #29
                  Cheers!
                  I'm glad to hear that
                  • kaltmond
                    Default
                    • 13
                    Hi qayyum786, can you help me to temporary unlock the MPM countdown of my Zbook Studio G9, i want to update my ME but only with unlocked MPM possible. My main BIOS dump from U367 is attached.
                    Thanks for the kind help.
                    Serial Number: 0001760LS4
                    UUID: 848A822CFA5C9F44ACF229FBF61C42D6​
                    • qayyum786
                      • Aug 2018
                      • 1959
                      • INDIA
                      #31
                      Provide Some Hisstory Regard How You Got The MPM Error It Was Locked With Password Or Something Els
                      If It Was A Password Issue In Past Then Press F10 And RESET BIOS to Factory Defaults,Go To Security Tab Reset Security Setting Save And Flash Your Old Locked Bios Again
                      Or Simply Use HP BCU TOOL to Fill DMI
                      • kaltmond
                        Default
                        • 13
                        Hi qayyum786, thanks for the reply.
                        It is a sample unit without MPM error or password issue, only the stock BIOS/ME is outdated. I cannot update official BIOS but i can update the ME Region, to do that i need first a unlocked MPM. The BCU tool is not functional with error 6 access denied.
                        I saw you helped redoxy removed his bios pwd, and he got a MPM countdown. So i think maybe you can help me modify the dump to unlock the countdown. In winnex i cannot find the UUID in the bios dump, only SN/Feature Byte/Build ID etc are available.....
                        • qayyum786
                          • Aug 2018
                          • 1959
                          • INDIA
                          #33
                          if you have old bios backup then replace Block 19F1000 TO 1A70FFF from old one to new one
                          • VektorR
                            • Oct 2024
                            • 9
                            • New Zealand
                            #34
                            Hello. Please help me to remove BIOS password from my HP Zbook Firefly 14 G9.
                            Serial: 5CG3107JP8, Prod.ID: 6W4R9PA#ABG
                            Motherboard version: 6050A3417601-MB-A01.
                            I really hope that you can do it because other techs guys failed.
                            Thanks in advance!
                            • rex98
                              • Feb 2023
                              • 1289
                              • Mandaue CEBU, Philippines
                              #35
                              Thanks in advance!
                              first boot press f10 apply factory defaults and restart, 2nd boot reset security settings to defaults and exit.
                              use BCU. you can permanently disable Absolute lock in BCU.
                              here's your dmi:
                              Serial Number: 5CG3107JP8
                              Product #/SKU: 6W4R9PA#ABG
                              CT Number: PRBPL00WBHT229
                              Description: HP ZBook Firefly 14 inch G9
                              BuildID: 22WWWPBT601#SABG#DABG
                              Feature Byte: 476J6S6b7B7M7Q7U7W7m7saBaEapaqauawbUbhcAdpdqfAfPgSguhKjhk8mEn7nVngpTpqqj.a5
                              MAC Address : 7C:4D:8F:FB:B9:A3​
                              • VektorR
                                • Oct 2024
                                • 9
                                • New Zealand
                                #36
                                here's your dmi:
                                Thanks for a super quick reply. Is there any way to flash this patched BIOS without unsoldering that BIOS chip again and programmator?
                                • VektorR
                                  • Oct 2024
                                  • 9
                                  • New Zealand
                                  #37
                                  here's your dmi:
                                  Hi again. I flashed provided patched BIOS followed by firsr boot, second boot instructions. Unfortunately Security Settings can't be restored to defaults - current Admin password request is popping up. So my laptop boots up with red warning message 'System boots up in Manufacturing Programm Mode..... . Can't get rid of it. BCU tool doesn't allow change any vallues due to Admin password. It's still there. Provided patched BIOS allows to bypass BIOS password an access BIOS but it's not removing it . Could you help with it please?
                                  • mohammad faisal
                                    • Apr 2015
                                    • 9
                                    • pakistan
                                    #38
                                    need unlock firefly 14 g10 plz make patch
                                      • 21679
                                      Off topic, this thread is for the G9 model. Post your request in firefly 14 G10 thread,and include the required laptop serial number --> https://www.badcaps.net/forum/troubl...before-posting
                                      • rex98
                                        • Feb 2023
                                        • 1289
                                        #40
                                        Here try this same procedure
                                          HP ZBook Firefly ZBook Firefly 14 G8 Mobile Workstation Bundle Mobile workstation Specification for Upgrade or Repair
                                          This specification for the HP ZBook Firefly ZBook Firefly 14 G8 Mobile Workstation Bundle Mobile workstation can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the ZBook Firefly 14 G8 Mobile Workstation Bundle boardview and ZBook Firefly 14 G8 Mobile Workstation Bundle schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on...
                                          09-07-2024, 05:20 AM
                                        • zenius
                                          by zenius
                                          12-08-2024, 06:13 AM
                                        • CeeEee4
                                          HP ZBOOK FIREFLY 14 G10 A (AMD) Corrupt BIOS
                                          by CeeEee4
                                          Hello
                                          I have an HP ZBOOK FIREFLY 14 G10 A (AMD) model with HP Blink Error 2-2 (Main area DXE of BIOS has become corrupted and no binary recovery image available.) I have tried BIOS recovery USB but it didnt work.
                                          Tried using a "clean" bin extracted from the HP softpaq but laptop would not even respond to power button, although it had white LED on DC jack.
                                          Here is back up of the BIOS, hope somebody can help. Thanks
                                          09-16-2025, 09:07 AM
                                        • Andrew Bower
                                          BIOS Unlock for HP zbook studio x360 g5
                                          by Andrew Bower
                                          I've been working on this for about a week. I've read the threads and ordered and attempted to use a programmer to pull the BIOS dump from the laptop with no luck. I tried using RcUnlocker, but keep getting a dll error even after reinstalling the C++ Redistributable. I also tried NeoUnlocker and another program. None would pull up the chip.
                                          That leaves me asking for help unlocking this BIOS. The laptop boots up to the Domain login with no issue. I can pull up the boot menu. Any attempt to open the BIOS or the BIOS upgrade menu is met with a password request....
                                          12-04-2024, 05:55 PM
                                        • beal
                                          bios hp ZBook Firefly 14 inch G9
                                          by beal
                                          hi
                                          Please Bios hp ZBook Firefly 14 inch G9
                                          FF14-MV-GCE 6050A3310001-MB-A01
                                          SN : 5CG31412Q7
                                          thanks...
                                          09-03-2025, 09:55 AM
