Please unlock bios HP Zbook Firefly 14 G9
  • zzduczz
    • Mar 2014
    • 30
    • viet nam
    Please unlock bios zbook 14 g9.
    Last edited by Vesko356; 01-22-2024, 02:41 AM. Reason: "HP Zbook Firefly 14 G9" to thread title.
  • hoaca388
    • Jan 2022
    • 11131
    • Viet Nam
    Re: Please unlock bios zbook 14 g9
    Originally posted by zzduczz
    Please unlock bios zbook 14 g9[ATTACH]308731[/ATTACH]
    Try and report
    Become a Badcaps supporter
    Thanks to all supporters.
    • zzduczz
      • Mar 2014
      • 30
      • viet nam
      Originally posted by hoaca388
      Try and report
      thanks hoaca388,password is still there
      • qayyum786
        • Aug 2018
        • 1933
        • INDIA
        again
        • qayyum786
          • Aug 2018
          • 1933
          • INDIA
          Originally posted by qayyum786
          again
          forget to isolate file on post #4
          use this one
          • zzduczz
            • Mar 2014
            • 30
            • viet nam
            use this one
            thanks qayyum786,password is still there.I have returned the laptop to the customer.it's too hard to unlock
            • black0hackers
              • Jul 2020
              • 365
              write main bios file provided by me and 1st thing to do is to reset bios to factory defaults, save, restart and password will go on. Then, in Main tab you have "set machine unique data" and write there what it's written on the label inside the bottom cover.
              • zzduczz
                • Mar 2014
                • 30
                • viet nam
                Thanks black0hackers,good bios and clean password
                • zzduczz
                  • Mar 2014
                  • 30
                  • viet nam
                  after programming your bios, i can't find smbios uuid, i reprogrammed the original bios, the password is gone, don't enter smbios uuid, everything is perfect
                  • souaqi01
                    • Dec 2015
                    • 85
                    • Maroc
                    HI any one hlep me plz for unlock BIOS HP ZBook Firefly 14 G9
                    SN : 5CG31113GK
                    • hoaca388
                      • Jan 2022
                      • 11131
                      • Viet Nam
                      SN : 5CG31113GK
                      SN : 5CG31113GK
                      • souaqi01
                        • Dec 2015
                        • 85
                        • Maroc
                        SN : 5CG31113GK
                        THANK YOU VERY MUCH HOACA388
                        • trepachka
                          • Oct 2022
                          • 411
                          Please, help me remove bios lock for HP Zbook Firefly 14 G9 with Serial# 5CG3161CFB
                          I am providing 2 bin files, one from each 25W256JVEN chip I found. One chip is located at the front and the other chip is located on the back of the motherboard.
                          I am not sure which files is needed, so I am providing both.
                          Thank you kindly.
                          • hoaca388
                            • Jan 2022
                            • 11131
                            • Viet Nam
                            Thank you kindly.
                            Unlocked
                            • trepachka
                              • Oct 2022
                              • 411
                              Thank you. The bios lock is gone. However, I am getting "Device in manufacturing mode" message on boot. Is there a command I can run similar to Dell's Alt-F to exit this mode?
                              • qayyum786
                                • Aug 2018
                                • 1933
                                • INDIA
                                you can use hp tool BCU fill the further detail from bottom panel or from sticker
                                • trepachka
                                  • Oct 2022
                                  • 411
                                  It took me a while to figure out how to install the utility and use it successfully but the manufacturing mode has been disabled.
                                  Thank you for all your help.
                                  • volinakis
                                    • Jan 2021
                                    • 2607
                                    • N/A
                                    if you restart laptop how many times MPM counter shows it will exit from manufacturing mode (MPM). BCU have to be used under cmd.
                                    • trepachka
                                      • Oct 2022
                                      • 411
                                      The MPM counter started @ 35 and went down all the way to 1 but wouldn't go down any further until I provided the information provided by hoaca388 such "Feature Byte", "CT Number", etc.
                                      Only after I provided all of this information, the message on the screen came up and asked me whether I wanted to submit this file. Once I answered "Yes", then MPM went away.
                                      • redoxy
                                        • Sep 2018
                                        • 100
                                        Can someone please tell me what the part # of the BIOS chip is? I need to unlock my BIOS but when I opened the laptop, I see two Winbond 25W256JVEN chips (U367, U368) and I'm confused about which one is the correct chip to read/backup. Thanks in advance.
                                          SMDFlea commented
                                          Editing a comment
                                          Theres a clue in the filename at post 14. If youre still unsure just post both.
                                        HP ZBook Firefly ZBook Firefly 14 G8 Mobile Workstation Bundle Mobile workstation Specification for Upgrade or Repair
                                        This specification for the HP ZBook Firefly ZBook Firefly 14 G8 Mobile Workstation Bundle Mobile workstation can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the ZBook Firefly 14 G8 Mobile Workstation Bundle boardview and ZBook Firefly 14 G8 Mobile Workstation Bundle schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on...
                                        09-07-2024, 05:20 AM
                                      • zenius
                                        by zenius
                                        12-08-2024, 06:13 AM
                                      • Andrew Bower
                                        BIOS Unlock for HP zbook studio x360 g5
                                        by Andrew Bower
                                        I've been working on this for about a week. I've read the threads and ordered and attempted to use a programmer to pull the BIOS dump from the laptop with no luck. I tried using RcUnlocker, but keep getting a dll error even after reinstalling the C++ Redistributable. I also tried NeoUnlocker and another program. None would pull up the chip.
                                        That leaves me asking for help unlocking this BIOS. The laptop boots up to the Domain login with no issue. I can pull up the boot menu. Any attempt to open the BIOS or the BIOS upgrade menu is met with a password request....
                                        12-04-2024, 05:55 PM
                                      • phoxicy
                                        HP ZBOOK Firefly 14 G10A BIOS Password
                                        by phoxicy
                                        HP ZBOOK Firefly 14 G10 A HAVE BIOS Password,can anyone help? thanks a lot
                                        mother board number is 6050A3458701-MB-A01
                                        SN:5CG4152KCY
                                        it has two chip both of 32MB...
                                        04-15-2025, 03:22 AM
                                        HP ZBook Firefly 15 G7 Mobile workstation Specification for Upgrade or Repair
                                        This specification for the HP ZBook Firefly 15 G7 Mobile workstation can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Firefly 15 G7 boardview and Firefly 15 G7 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or...
                                        09-06-2024, 07:20 PM
