Dell G15 5515 La-k454p rev 1.0 Bios Bin Need
  • Dack_bb
    • Jul 2024
    • 4
    • BRASIL
    hey
    Excuse my ignorance, but as you say that the chip is wrong, as it is the chip that came with the machine, what happens is that I need to re-program it.​
      • 20952
      Originally posted by Dack_bb
      hey
      The 25Q16JWSIQ chip is 2MB ,it is for firmware or the vBios, not sure which,but it is not the bios chip.Do not touch it ! Look for a chip that says 25Q128 on it https://www.aliexpress.com/i/1005005024847169.html
      • volinakis
        • Jan 2021
        • 2733
        • N/A
        hey
        try that one in red square Click image for larger version
        • Dack_bb
          • Jul 2024
          • 4
          • BRASIL
          This chip that you marked has the second ID:
          74M12JWSIQ​
          • volinakis
            • Jan 2021
            • 2733
            • N/A
            74M12JWSIQ​
            yep, that's bios chipset
            • Stronger1
              • Jul 2024
              Hello dear friends
              You need to update the BIOS to version 1.20.0
              • brzostos
                • Apr 2018
                • 20
                • Poland
                #27
                I need a verified bios upload for my laptop
                Model: Dell G15 5515 Ryzen Edition
                SN: JDGMRK3
                The laptop with the original batch does not display the image and displays error 3.6 (Flash memory corruption).
                I uploaded the batch from post #4 but it still does not display the image and this batch displays error 2.1 (Possible processor failure).​
                • volinakis
                  • Jan 2021
                  • 2733
                  • N/A
                  #28
                  SN: JDGMRK3
                  try
                  • brzostos
                    • Apr 2018
                    • 20
                    • Poland
                    #29
                    Originally posted by volinakis
                    try
                    Thank you very much, it works perfectly.
                    • hcinne
                      • Jul 2024
                      • 9
                      • Algeria
                      #30
                      I posted a topic in the troubleshooting about dell g15 ryzen5 edition that shows 2amber and 1white (possible processor failure) i suspect it could be a corrupt bios not sure though, i made multiple backups of the original bios winbond 74M12JWSIQ using ch341 and ezp2019+ (i desolderd the chip and used a socket and the 1.8v adapter)
                      i made 3 backups in neoprogrammer using ch341 and all 3 are identical and another 2 backups using ch341 v1.31 (ch341AFree) and the two are identical, however the size is different the bin files extracted with neoprogrammer are 16mb the other bin files of ch341 v1.31 are 1mb only
                      the ezp2019+ gives me different readings everytime i try to read the chip wether in 3mhz or 12mhz, the bin file is 16mb
                      i tried to extract the bios from the exe file of the dell bios however the file is too big to be opened in the programmer the file size is 18mb
                      motherboard version is GDL5L LA-K454P Rev : 1.0 (A00)
                      ST: 4HW54N3
                      EX: 9789041343
                      • hcinne
                        • Jul 2024
                        • 9
                        • Algeria
                        #31
                        ST: 4HW54N3
                        EX: 9789041343
                        Update: identical bin files on the ezp2019+ using 1.5mhz speed same as the ch341 bin files from the neoprogrammer software
                        • hcinne
                          • Jul 2024
                          • 9
                          • Algeria
                          #32
                          I modified the original bios 1.20.0 that i extraced from the dell website and flashed it now its working again
                          • medhat0111
                            • Aug 2024
                            • 3
                            • egypt
                            #33
                            i need these 2 files please G15 5515 Rayzen 7 edition
                            ST: 1WMY7K3
                            someone help please
                            • peste
                              • Dec 2016
                              • 12835
                              • ROMANIA
                              #34
                              ST: 1WMY7K3
                              someone help please
                              post the original bios of the laptop even if it is corrupted..
                              • medhat0111
                                • Aug 2024
                                • 3
                                • egypt
                                #35
                                these are the original which came on board , these pictures i took it before i touch them and someone formated winbond without taking a backup
                                • medhat0111
                                  • Aug 2024
                                  • 3
                                  • egypt
                                  #36
                                  try
                                  i tried this and it works, thanks
                                  • Edward25
                                    • Apr 2024
                                    • 3
                                    • ECUADOR
                                    #37
                                    try
                                    perfect, thank you
                                    • hyditech
                                      • 272
                                      • nigeria
                                      #38
                                      Please help me unlock bios for Dell G15 Ryzen Edition
                                      S\N 9NGY7K3
                                    • hossameldamaty
                                      • Sep 2019
                                      • 4
                                      • Egypt
                                      #39
                                      Originally posted by qayyum786
                                      Re: Dell G15 5515 La-k454p rev 1.0 Bios Bin Need
                                      Service Tag: BN7J9L3
                                      try a new bios extracted from Dell support
                                      how extract this one ?
                                      • qayyum786
                                        • Aug 2018
                                        • 1933
                                        • INDIA
                                        #40
                                        you need dell pfs extractor after extract raw file you need to build it
                                        click here Help with Dell PFS extractor
                                        download extractor from post #6 posted by SMDFlea and there is instruction as well
                                        • NotEnough
                                          Dell G15 5515 RGB Keyboard Not Detected (Compatible Keyboard, Possible BIOS/EC Issue?)
                                          by NotEnough
                                          I'm working on a Dell G15 5515 (Ryzen 7 5800H, RTX 3050 Ti) and recently installed a compatible 4-zone RGB keyboard and controller (for Dell G15 5510/5511/5515 models). While the keyboard functions for typing, the RGB lighting is not detected by Alienware Command Center (AWCC), which displays “No AlienFX devices found.”
                                          What I've Tried So Far:
                                          • Reseated the cables.
                                          • Reinstalled AWCC and AlienFX services.
                                          • Attempted BIOS downgrade but no improvement.
                                          • Inspected ribbon cables for damage.
                                          • Explored the possibility of BIOS or
                                          10-19-2024, 01:34 AM
                                        • zenius
                                          by zenius
                                          12-08-2024, 06:13 AM
                                        • DavidChunco
                                          Dell G15 5515 Ryzen Edition Apparently Bricked BIOS Request
                                          by DavidChunco
                                          Hi, I hope someone can help me with this, my Dell G15 Ryzen Edition does not post anymore (black screen, no Windows boot, no BIOS screen) after Windows Update pushed what appears to be a buggy bios image, I've tried the following with no success:
                                          - Receive help from Dell Support (it is out of warranty).
                                          - Disconnect machine from AC power and battery overnight.
                                          - BIOS recovery process
                                          - Connected external display via HDMI
                                          - Disassembled machine and found bios chip, its a Gigadevice 25LR128DSIG (GD25LR128DSIG), at first I tried to get it detected by CH341A (with...
                                          03-15-2025, 11:00 AM
                                        • mikeybass
                                          by mikeybass
                                          04-23-2025, 04:30 PM
                                        • jhanra
                                          by jhanra
                                          in windows 11 sound driver compatibility, but overall its ok, for me i can deal with it, 😅😅😅...
                                          11-02-2024, 04:19 AM
