Part will be from SILERGY.
IC Marking Codes and Datasheets #2
Hi ya folks,
I have a NEC laptop with a burning chip which is supplying power to CPU.
Thankfully CPU is not burned.
I just gotta replace this chip.
Unfortunately i don't know the name of the chip.
Markings are
1st line W072
2nd line 5335
I know the maker is GMT Global Mixed-Mode Technology.
But i cant find out the chip name.
Any help is appreciated.
GMT5335
G5335
https://gmt.com.tw/product/datasheet/EDS-5335.pdf
I just found this on AliExpress: US $3.52 | (5piece)100% New G5335QT1U G5335 5335 QFN-23 Chipset
https://a.aliexpress.com/_oEv9sexLast edited by mon2; 09-09-2025, 11:42 PM.Comment
GMT5335
G5335
https://a.aliexpress.com/_oEv9sexComment
Hello
Could someone identify this IC ? Its from an asus striker II EXTREME montherboard.
I know that its not worth it but customer is inlove with this mobo.
The IC is near PCI EXPRESS SLOT 1. I cannot determine whats the use of this IC.
Without it short is gone , but motherboard isn't responding. Thank you in advance.Comment
by SMDFleaThread started and edited by piernov and SMDFlea. All members are welcome to contribute to the thread, if you have any
pictures, suggestions, spot any mistakes or want new content adding send me a PM or just make a post. Thanks
EDIT: See "IC Marking Codes and Datasheets #2" for more posts. All members please post comments in thread #2.
__________________________________________________ __________________________________________________ ________
Click on the name next to the post # to view the single post... -
by SMDFleaRicoh Power Management IC`s Marking Codes
The attached pdf titled "Ricoh PMIC`s Marking Codes,pdf" was made by me from the main pdf Ricoh_MARKINGS.
....06-06-2021, 12:29 PM -
by mitsu2kHello folks, I seem to have a lot of trouble when it comes to distinguishing markings on SMD components especially when it comes to the question of whether it is a 1 or an I. for example, I see components marked NI. It looks just like that. However, I cannot tell if that "I" might be a number one instead. Is there a rule of thumb that manufacturers use when using these characters? Attached is an example. This is just one example out of many I come across but it's a good illustration of my point. I appreciate any input....
by dqtechim working on HP Probook 450 g5 with no power issue and found out coil beside this ic is short to ground...i remove the ic and short gone....ic code AQP,...looking on this ic marking code but not found https://www.badcaps.net/forum/troubl...and-datasheets...
by abajorHad someone drop off a laptop in which they were upgrading the ram but forgot to unplug the battery.
Looks like the ram RFI shield shorted a rail going to or coming from a Silergy IC which blasted a component off the board. I'm going to assume it was a cap but really have no way to know for sure since this board schematic doesn't appear to be in the wild yet.
I'm trying to identify the IC model now but it doesn't appear to match any of the Silergy codes from https://www.badcaps.net/forum/troubl...-tablets-and-m... - Loading...
