MacBook Pro 15" 2017 A1707 Touchbar No power
  • Stephen
    Meow Meow MEOW!
    • Apr 2020
    • 667
    Great forum! Love you guys for helping me learn here. Pulled up Schematics.
    USB C Tester plugged in. Starts at 5V then the USB C tester shuts off and restarts. No test further. I plugged the USB C Tester into a working logic board (has a bad SSD Corruption) to verify the USB C Tester is working, and it works fine so the logic board we are testing is looping at 5V. Turns on the USB C Tester after 3 seconds it turns it off and on again. Loops. Tested voltage for G3H and it seems the enable switch at U6903 is present. Tried both USB C ports, same result
    Any points I should test to determine what I am missing? So far I have learned a lot but small things like this come up and I could use the knowledge for further future repairs and enjoyment!
    sigpic
    MEOWING IN THE IMPOSSIBLE UNIVERSE!
  • Stephen
    Meow Meow MEOW!
    • Apr 2020
    • 667
    Re: MacBook Pro 15" 2017 A1707 Touchbar No power
    Tested for G3H. And its present. Then the voltage drops to 0 then starts over at 3.4Volts then drops again. This is obviously the cause of it shutting down. It still is not getting to 20V on the tester. Just stays at 5.20Volts then shuts itself down and starts over.
    sigpic
    • piernov
      • Jan 2016
      • 4435
      • France
      Try all 4 ports in both orientation.
      • Stephen
        Meow Meow MEOW!
        • Apr 2020
        • 667
        All 4 Ports do the same thing.
        sigpic
        • Stephen
          Meow Meow MEOW!
          • Apr 2020
          • 667
          Bump
          sigpic
          • MobileXT
            • Oct 2012
            • 196
            I would give a try to replace 4 of the CD32 as long as you get steady 3v3 then start from there. But if you have a fluctuating voltage it could be the ISL9240
            • Stephen
              Meow Meow MEOW!
              • Apr 2020
              • 667
              Thank you! I will test that tomorrow!
              sigpic
              • Stephen
                Meow Meow MEOW!
                • Apr 2020
                • 667
                So went through all my stencil tools and I do not have a CD32 Stencil. Does anyone know where I can purchase one?
                sigpic
                • Stephen
                  Meow Meow MEOW!
                  • Apr 2020
                  • 667
                  Scratch that found one on eBay from China. Sucks I thought I had one!
                  sigpic
                  • mon2
                    • Dec 2019
                    • 14118
                    hi. yes, you can source the stencil from MobileSentrix - they have some good stuff. Purchased from them recently:
                    https://www.mobilesentrix.ca/ic-comp...06-a1707-mac-5
                    Give them a shot and post your results.
                    Also, they have a USA as well as a Canadian distribution warehouse so you should be covered.
                    • Stephen
                      Meow Meow MEOW!
                      • Apr 2020
                      • 667
                      Thank you! I just purchased from them! Didn't realize they had stencils on their site! Now I do!
                      sigpic
                      • mon2
                        • Dec 2019
                        • 14118
                        Funny - about to order the same d*mn thing - have a bad CD3215 on an A1990 that will not turn on the battery charger.
                        Ordering a fresh CD3215 batch and the SMD stencil - actually may have it here already but easier to buy a fresh stencil than to dig. Apparently their cutoff for same day shipping is 8 PM - sweet!
                        • Stephen
                          Meow Meow MEOW!
                          • Apr 2020
                          • 667
                          Yeah just ordered that stencil. I think the China order hasn't delivered yet, but I need to do 4 CD3215 stencils for this A1707. Hopefully this solves the issue. If this fixes it, that brings out a board we had laying around and can put it into our inventory.
                          sigpic
                          • mon2
                            • Dec 2019
                            • 14118
                            What is the 820-xxxx code for your A1707 logic board?
                            Is it 820-00281-A?
                            • mon2
                              • Dec 2019
                              • 14118
                              Remove the 0 ohm resistor @ R6923 and power up again.
                              What is the voltage out out on pin 1 of R6923 (without this series resistor)?
                              Do you see a steady 3v3 on this rail or still power cycles for this rail?
                              • mon2
                                • Dec 2019
                                • 14118
                                Also, from here:
                                https://logi.wiki/index.php/CD3215_Bootup_Sequence
                                See the following:
                                Satyrcon 11.12.2020
                                Issue: 820-00840 wont take anything from charger, either port, or orientation.
                                Visible inspection resulted in marks on CC1/2 pins on both USB-C ports.
                                Diode mode measurement showed ~0.550V on 3 of them, one ~0.040V.
                                Replacing the port fixed the issue.
                                Conclusion: One damaged CC pin can cause the whole lot to stop functioning.
                                Post your diode readings for the CC1 and CC2 pins on each of your USB Type C connectors. An incorrect reading on one or more could indicate a fault on that specific CD3215 controller. If found, you could attempt to just remove that CD3215 controller out of circuit to see if that makes a difference for the balance of the logic board. Be sure that no pads are removed in the process and that no pads are shorting after this removal process.
                                • mon2
                                  • Dec 2019
                                  • 14118
                                  Check to confirm that the LDO_BMC value for EACH of the CD3215 is @ 1v1. This voltage rail powers the BMC communication for the USB power delivery handshakes.
                                  Do review this very nice webpage on this subject:
                                  The TBT (thunderbolt) controller apparently is required to communicate with each of the CD3215 controllers over the I2C bus. If something is wrong with this process, this may cause your cyclic booting.
                                  Do check for any voltages on SMBUS_SMC_4_G3H_SCL and also SMBUS_SMC_4_G3H_SDA.
                                  Any voltages? What are the values? If no activity, then I2C bus communication is not working.
                                  • Stephen
                                    Meow Meow MEOW!
                                    • Apr 2020
                                    • 667
                                    Hey replaced a few CD32 and still same issue, Going to check this now.
                                    sigpic
                                    • Stephen
                                      Meow Meow MEOW!
                                      • Apr 2020
                                      • 667
                                      Also our board is
                                      820-00281-A
                                      sigpic
                                      • Stephen
                                        Meow Meow MEOW!
                                        • Apr 2020
                                        • 667
                                        Removed the O OHM resistor. It is not power cycling anymore and I now have a 3.3v steady on PIN 1.
                                        sigpic
                                        • sofles
                                          Macbook a1707 2017 model 820-00928 GPU issue
                                          by sofles
                                          Hello there
                                          I have problem with Macbook Pro 15" 2017, model 2017, MB code 820-00928.
                                          I bought it as broken with some artefacts on the screen, first I thought that this is problem with ribbon cable but after inspectiing ribbon cable I know it is fine. I tried to reinstall macOs and then I figured out that this must be something with GPU as installation freezes at the end (when drivers are loaded). I installed Windows and was able to install every each of drivers except GPU driver, as soon as I tried to install GPU driver - black screen and restart.
                                          11-21-2024, 05:25 AM
                                        • Ryan.man
                                          by Ryan.man
                                          02-04-2025, 12:23 PM
                                        • modtool
                                          Macbook Pro A1989 fallen, reboots if touchbar connected
                                          by modtool
                                          Hi to all,
                                          the owner of this macbook brought it to me after a fall, that hit the upper right corner of the top case.
                                          Luckily enough, the screen and all other parts of the machine haven't been damaged, only the touch bar wasn't lighting up anymore, and the macbook began to behave strangely, because it seems to start and work fine but suddendly it shutsdown (and at the same time the fans make a high rotation for half a second, as if an animal was annoyed by something...) at random times, sometimes after 2 minutes, sometimes after 5 minutes, but never over 10 minutes, then restarts...
                                          11-10-2023, 07:42 AM
                                        • kurtspirit
                                          Macbook A1706 EMC3071 (2017 Touchbar)
                                          by kurtspirit
                                          I have a Macbook Pro 2017 Touchbar (A1706) that suddenly shut down for no reason.
                                          So I took it apart and started measuring.
                                          The PP3V3_G3H seems problematic. I traced the line to component U6903 and on Pin 10, I measured 1.9V instead of 3.3V.
                                          Unfortunately, my skills stop there and I don't understand where this type of failure can come from.
                                          I saw on videos of repairers that the failure could come from the U7000 component which would be at the origin of the 3.3V but they have absolutely no voltage. I have a 1.9v...
                                          What do you think ?...
                                          08-23-2022, 05:57 AM
                                        • leonemax81
                                          Macbook a1707 820-00281 Battery no Power
                                          by leonemax81
                                          Hi guys I have a Macbook a1707 with motherboard 820-00281, without liquid damage that behaves strangely, with the battery connected the Macbook does not turn on and the USBC meter stops at 5v in loop, when I disconnect the battery the Macbook turns on and works fine, I have already tried to replace the battery twice without success, as soon as I connect the black cable of the battery the Macbook does not turn on, it stops at 5v and in loop.
                                          08-23-2024, 09:24 AM
