Macbook Pro A1989 fallen, reboots if touchbar connected
  • modtool
    • Jul 2015
    • 58
    • Italy
    Hi to all,
    the owner of this macbook brought it to me after a fall, that hit the upper right corner of the top case.
    Luckily enough, the screen and all other parts of the machine haven't been damaged, only the touch bar wasn't lighting up anymore, and the macbook began to behave strangely, because it seems to start and work fine but suddendly it shutsdown (and at the same time the fans make a high rotation for half a second, as if an animal was annoyed by something...) at random times, sometimes after 2 minutes, sometimes after 5 minutes, but never over 10 minutes, then restarts by itself .
    At first I thought that the heatspreader was damaged, so I installed an app to monitor temperatures, but that wasn't the problem, also because fans were working correctly when temperature goes high.
    I disassembled the mainboard and inspected it carefully with a big magnifying lens and found no broken or fallen components, then I reassembled everything and the behaviour was the same.
    Then I detached all flat cables but the display one and noticed that the mainboard and the MacOS were working good, even after 1 hour and with high temperatures (hitting 100°C during start times).
    I started testing the board by connecting one flat cable at time, and starting MacOS, and everything went smooth until I connected the last one, responsible for the touch bar (the one that connects to J5100), coded 821-00681-A.
    I noticed also that conneting the one that goes to J5100 and disconnecting the one that goes to J5110 let the macbook work correctly without rebooting itself, so I can say that the touchbar isn't working anymore but I didn't know that this kind of fault could led to a self shutdown.
    I don't have enough experience with machines with a T2 IC onboard, but since I've seen that touchbar eeprom is connected to it, I can imagine that it's the T2 itself that forces the shutdown, but then I don't understand why it doesn't if the touchbar is completely disconnected...
    Another thing that I don't understand is why in System preferences I see "Touch bar backlight" under USB->T2 section even if the touchbar is completely disconnected...
    In the end, I need an advice to understand if the touch bar can be replace with a new one without the T2 going upset and screw something, because I've read that putting the mainboard in another topcase may led the T2 to lock the platform and disable access to the onboard ssd, as also have read that a not-working touch bar may cause problems on future firmware/MacOS updates.
    Please, can someone enlight me about these questions?
  • Stephen
    Meow Meow MEOW!
    • Apr 2020
    • 667
    Re: Macbook Pro A1989 fallen, reboots if touchbar connected
    Heads up, any model with Touch Bar will have issues if the Touch Bar goes bad. You will need to replace the Touch Bar even if it is not cracked. You will have booting issues or functional issues if the Touch Bar goes bad. A1706, A1707, A1989, etc. all have these known issues. I would suggest using a used top case if you have one laying around with a good Touch Bar and testing it in that. This will easily tell you if the issue persists. Hope this helps.
    You can replace the Touch Bar on these models without issue, they are not married to the board, the only thing married to the board on these models is the Touch ID. Just make sure you get the correct Touch Bar for this model.
    sigpic
    MEOWING IN THE IMPOSSIBLE UNIVERSE!
    • modtool
      • Jul 2015
      • 58
      • Italy
      Hi Stephen,
      thank you for the hints, a new touch bar arrived, I installed it and everything has gone well, no more reboots and who knows what other problems it could have caused in future MacOS updates.
      Have a nice day
      • Stephen
        Meow Meow MEOW!
        • Apr 2020
        • 667
        Pleasure to have helped you!
        sigpic
        • MullySculder
          A1989 EMC3214 can't boot to USB drives due to T2 but SSD can't be initialized and Macbook freezes then reboots in recovery
          by MullySculder
          Hey folks, I'm working a 2018 13" Macbook Pro that I can't get to install an OS on.
          This was given to me by a friend who told me I could have it, if I fixed it.
          I've noticed a couple of dents on the laptop case and the touch bar doesn't have any activity lights when first turning on. When I boot up the machine, it gives a folder with a question mark. When I do eventually get to internet recovery with High Sierra, I can go to Disk Utility but I'll get errors when I try to erase the 512GB SSD. First Aid comes back with no issues. But if you linger too long on anything,...
          07-10-2024, 02:17 AM
        • KappaDev
          Macbook Pro A1989 (Touchbar), 820-00850-A, 20V 0A, Not Charging
          by KappaDev
          I have a Macbook Pro A1989 that had liquid spilled on a thunderbolt hub that was plugged into one of the USB-C ports. The laptop will now no longer charge.
          Hitting the power button displays the low battery icon and then goes off.
          Power meter shows 20V drawing 0A. The same voltage displayed and amperage drawing on all 4 ports. Since the board is relatively cheap on this model, is there anyway to force charge the battery or run the board with a DC power supply to simulate the battery to retrieve the data?
          Thanks.
          07-29-2022, 11:16 AM
        • ErinV
          MacBook Pro A1989 820-00850-A not powering on
          by ErinV
          Hey everyone!
          I have a MacBook Pro A1989 with a 820-00850-A board that recently stopped working. I used it overnight to charge my phone, in the morning it didn't turn on, I assumed flat battery but now won't charge and doesn't start at all.
          I have fully dissassembled it, when disconnected the battery reads at 0.012V. Even with the battery disconnected the laptop doesn't boot.
          The diode voltages around all 4 CD3215's seem fine.
          For all CD3215 (UB300, UB400, U3100 and U3200) I read just above 5V on PP20V_USBC_TA_VBUS, 3.3V on PP3V3UPC_TA_LDO, 1.8V...
          09-30-2024, 10:21 PM
        • Madoy104
          Macbook Pro A1989 - No image, working fine with external monitor
          by Madoy104
          I have a MacBook Pro A1989 that was likely exposed to liquid. It doesn't display an image on the built-in screen, but the screen is backlit (you can't see the Apple logo or any other elements when held up to light). The laptop provides 20V and 1.5-2A, and it works fine when I use it with an external monitor. Currently, the connector for the display (J8500) is disconnected. I'm writing to ask for help in diagnosing the issue. I've heard that when the J8500 is exposed to liquid, the processor pin responsible for the display might short-circuit, and I'd like to know...
          08-15-2024, 10:01 AM
        • PITERPENY
          Macbook A1989, 820-00850, won't boot. 20V, 0A.
          by PITERPENY
          Today I have a MacBook A1989 at work 820-00850. When assembled, the laptop switches to 20 volts but the consumption is 0.00 ampere. if the motherboard is on the table then the consumption of all ports is 5 volts and0.35 amperes and does not go to 20 volts only if you assemble a MacBook.
          Here are some measurements, maybe someone can tell what the problem is.
          The initial problem was a burnt out induction coil L8504 (replaced).
          When connected to another MacBook, it constantly hangs in dfu and cannot install updates, something is wrong.
          here are some measurementsmotherboard...
          01-16-2024, 02:19 PM
