Macbook a1707 820-00281 Battery no Power
  • leonemax81
    • Nov 2015
    • 57
    • italia
    Hi guys I have a Macbook a1707 with motherboard 820-00281, without liquid damage that behaves strangely, with the battery connected the Macbook does not turn on and the USBC meter stops at 5v in loop, when I disconnect the battery the Macbook turns on and works fine, I have already tried to replace the battery twice without success, as soon as I connect the black cable of the battery the Macbook does not turn on, it stops at 5v and in loop.
  • leonemax81
    • Nov 2015
    • 57
    • italia
    Parts already replaced without success: Battery. U7800. Q7030. Q7040. Q7065. D6950. D6902. U7000.
    • mon2
      • 15869
      Connect the battery and the USB Type C adapter.
      Measure the voltage to ground of:
      SMBUS_SMC_5_G3_SCL
      SMBUS_SMC_5_G3_SDA
      at battery connector J6951.
      • leonemax81
        • Nov 2015
        • 57
        • italia
        yes already done, I have no shorts and the voltage goes up to 2.95V and goes in loop, without battery connected I have stable voltage 3.34, I suspect it is the SMC chip.​
        • mon2
          • 15869
          Remove all power. Meter in lowest resistance scale.
          Measure the resisance across C7020. We are interested in the full resistance path of the battery leg current sense circuit. What is the resistance in ohms?
          • leonemax81
            • Nov 2015
            • 57
            • italia
            C7020, with black lead to GND and red lead to PIN 1 and then PIN 2, resistance 470 KOHM, while if I put black lead to PIN 2 and red lead to PIN 1, I measure 3.7 OHM, which compared to other working motherboards is too low.​
            • mon2
              • 15869
              Short your meter probes by touching them together. What is the resistance? That is your 0 ohm baseline measurement.
              Then when you measure the resistance across pins 1 & 2 of C7020 - the true resistance is the value on the meter - baseline value. There are 3 resistors in the measured path @ R7061, R7060, R7062. We know from the schematics that R7061 = R7062 = 1 ohms each. So your measurement should be ~2 ohms since R7060 = 5 milliohms = 5/1000 ohms.
              If you have a working motherboard of the same, measure at the same points of interest. Compare the measurements.
              • leonemax81
                • Nov 2015
                • 57
                • italia
                if I put the tip and the tip has a tolerance of 0.03 ohm, R7061 = R7062 = they are 1 ohm, I don't have an identical motherboard, I take reference from a motherboard of a macbook pro 13.​
                • mon2
                  • 15869
                  measure the resistance across pins 1 & 2 of C7020 - this should be very close to 2 ohms (not 3R7). Can you confirm this measurement again?
                  • leonemax81
                    • Nov 2015
                    • 57
                    • italia
                    measures 3.7 ohm
                    • leonemax81
                      • Nov 2015
                      • 57
                      • italia
                      I also replaced the R7060 resistor without success.
                      • leonemax81
                        • Nov 2015
                        • 57
                        • italia
                        also replaced the resistors R7061 = R7062 and also u7000 once again, without success.
                        • mon2
                          • 15869
                          Remove the battery mosfet off the board and test again with the power adapter and battery attached. Does the power cycling stop and the board boots?
                          Are the batteries the same as the original and recommended for use in this machine?
                          • leonemax81
                            • Nov 2015
                            • 57
                            • italia
                            which mosfet should i remove?, the batteries are working on other mocbooks, i noticed that with the battery connected i have no voltage on PPBUS.
                            • leonemax81
                              • Nov 2015
                              • 57
                              • italia
                              I remove the q7065 mosfet, same defect, 5v in loop on USBC.
                              • mon2
                                • 15869
                                Flux and remove carefully the dual diode @ D6950. Test again.
                                • leonemax81
                                  • Nov 2015
                                  • 57
                                  • italia
                                  removed D6950, nothing usual defect, I'm going crazy!
                                  • mon2
                                    • 15869
                                    Remove all power. Meter in diode mode. Black (yes black) meter probe on PPVBAT_G3H_CONN (because this line is also mating with the ISL9239). Red meter probe to ground. What is the measurement?
                                    How confident do you feel about the soldering of U7000? Perhaps consider to flux it and reflow this part to be sure there are no underside shorts.
                                    The fact that you lose PPBUS_G3H means there is a conflict raised when the battery is connected. SMBUS lines are a common factor and you could be shunting those lines. Maybe both batteries have a defective BMS board but you have mentioned they work in other macbooks? Which battery pack are you testing? What is the part #? 100% confirmed to be compatible with this macbook?
                                    An I2C / SMBUS analyzer would help to reveal the traffic on the SMBUS SDA/SCL lines.
                                    • leonemax81
                                      • Nov 2015
                                      • 57
                                      • italia
                                      PPVBAT_G3H_CONN diode mode measures 0.623V, I have already tested two batteries that work on other macbooks, U7000 replaced twice without success, I have an oscilloscope can it help?
                                      • leonemax81
                                        • Nov 2015
                                        • 57
                                        • italia
                                        I don't think the PPVBAT_G3H_CONN line is the culprit, because even if I don't put the battery screw but just connect the black battery cable to the J6951 connector without inserting the screw the MacBook doesn't turn on.
                                        • Bowline
                                          by Bowline
                                          06-11-2025, 10:13 AM
                                        • PITERPENY
                                          Macbook A1707 820-00928 battery replacement
                                          by PITERPENY
                                          brought in a working MacBook for battery replacement (swelled up). After replacing the battery it stopped turning on. tried connecting the old battery without changes. consumption with the battery connected and without the battery is the same 5v\0.200a on all 4 ports. replacing 9239 did not help
                                          04-20-2025, 03:22 PM
                                        • silver60618
                                          Macbook Pro A1990 - Battery not detected after connector torn off
                                          by silver60618
                                          Hi Gang, Im working on Macbook Pro A1990, the battery connector was torn off during friend trying to replace battery. I soldered on the connector back, and created traces. The battery does charge (according to amp meter), and does power on battery only. But the signal detect line maybe done incorrectly, and the macbook shows "X" over battery icon, and "Service Recommended" on new battery
                                          Can somebody point me to which of these connector pins is responsible for battery detect/data line? Pin 4 on schematic had a nub on the trace, im not sure if that is important,...
                                          11-12-2025, 06:36 PM
                                        • BMCappelletti
                                          Macbook Air M1 2020 A2337 - running on reserve battery (without battery)
                                          by BMCappelletti
                                          Hi everyone.
                                          Quick backgrounhd story: Macbook came to me stuck on 5V. According to repair.wiki I could have an issue on L7800. Indeed it was not passing signal through. And I did have an issue on PP5V_BSTLQ_VOUT_SPMU line. I found a cracked cap (C7800) and replaced both failing components.
                                          Now it negotiates 20V and the computer starts, but I receive the message "you are now running on reserve battery power", as shown on the attached picture. It happens with or without a battery connected. So I am discarding a battery issue, for now (it may be bad, but I will only know for...
                                          12-11-2025, 06:03 AM
                                        • manymonsteras
                                          Macbook Pro - A2251 - No power when battery is connected
                                          by manymonsteras
                                          I am hoping to get some advice. I have a 2020 13" Macbook Pro - A2251 that wouldn't turn on. I have done lots of electronics repair in the past but never on Macbooks. I have had this laptop sitting around and I finally decided to take a look at it and see if I could spring some life into it.
                                          First, it wouldn't boot up at all. I did a DFU restore and managed to get it to power on. Did a full restore but the battery was dead and wouldn't charge. I put in a new battery in it but now it won't boot up when the new battery is connected. I ordered a second new battery just in case,...
                                          11-20-2025, 09:42 PM
