Razer Blade RZ09-01953 no power
  • Themi
    • May 2020
    • 79
    • Scotland
    Re: Razer Blade RZ09-01953 no power
    Thanks Spider.
    Originally posted by techtiger
    if you are sure of the chaging IC is ISL95520HRZ then test pin 1 2 30 31 32 ACIN is pin 1 (+19V) & GATE PASS is pin 30(+20-25V) your fist 2 FETS are N-CHANNEL what are the Reading of the 2 fets S G D ? dont remove components if you are not sure for father damage !
    techtiger here are the values for pins on ISL95520HRZ
    1 - 3.195
    2 - nothing as far as I can see, not OL or 0v just nothing, numbers on my MM bounce, I note it traces back to a resistor adjacent, the same behaviour here also
    30 - 4.63
    31 - 4.25 - 4.52
    32 - 4.25 - 4.52
    • Techtiger
      • Oct 2014
      • 1601
      • france
      [QUOTE=Themi;980333]When mosfets were attached to board these were the values:
      mosfet closest to DCIN
      D - 19.52v
      S - 4.3v
      G - 4.25 - 4.52v
      mosfet furthest from DCIN
      D - 4.25 - 4.52v
      S - 4.5v
      G - 4.25 - 4.52v
      Removed both mosfets from board and found mosfet furthest from DCIN is faulty after testing with diode mode on multi meter.]
      what was the reading diode mode SOURCE DRAIN GATE ?
      • Themi
        • May 2020
        • 79
        • Scotland
        [QUOTE=techtiger;980341]
        D - 19.52v
        S - 4.3v
        G - 4.25 - 4.52v
        D - 4.25 - 4.52v
        S - 4.5v
        G - 4.25 - 4.52v
        I will get these readings tomorrow after replacing faulty mosfet and replacing the other.
        Do I need to conduct the diode test (-) to ground and (+) to source, drain and gate?
        While mosfets are de-soldered, is it worth conducting any other tests directly to the pads?
        • Techtiger
          • Oct 2014
          • 1601
          • france
          Thanks Spider.
          1 - 3.195
          30 - 4.63
          31 - 4.25 - 4.52
          32 - 4.25 - 4.52
          PIN 1 must be 19V from Dc jack PIN 2 ACOK should be 3.3V depends on the plateform 31 32 should be+19V CLR PIN 30 +20V
          pin 1 is connected with a brown cap what is the voltage on the other side this cap is connected VIA or direct to DCIN try to do a continuity test with MM
          • Techtiger
            • Oct 2014
            • 1601
            • france
            [QUOTE=Themi;980344]
            for N-Channel Fets keeps the Probe to SOURCE Black Probe to DRAIN you should get a value above 500Ohms if you revise Probe no Value or high
            SOURCE to GATE no Value or high
            GATE to SOURCE no Value or high
            • Themi
              • May 2020
              • 79
              • Scotland
              #26
              Ok this is what I have so far.
              I cannot find continuity between pin 1 and a brown cap anywhere. Can you specify using one of my images in case I have missed it. I can only find continuity between PR136 (connected to pin 1) and DCIN (blue circles).
              Voltages from charge IC. Blue circle shows continuity probe point to second blue circle in below image.
              Voltages from area near DCIN. Continuity test from previous image to here ok. Note I have found a blown capacitor at PC260 near DCIN. Resistance across this blown cap is 60K.
              PC260 (blown)
              Resistance tests at IC
              • Techtiger
                • Oct 2014
                • 1601
                • france
                #27
                ok then it's connected with the Blue circle resistor one side +19V other side 3V may be it's faulty or leaking remove it & check with MM , check the Ohms pin 1 of PU5, remove the
                blown capacitor PC260 no
                • Themi
                  • May 2020
                  • 79
                  • Scotland
                  #28
                  Updates
                  Just want to say thanks to everyone who chimed in an helped me. Really appreciate it.
                  I managed to get everything back up and running.
                  I received the two mosfets and a replacement 100nF smd cap to replace the blow decoupling one near the DCIN.
                  I soldered then new stuff on and checked voltages. Everything came back, had my 5v, 3.3v and both mosfets were reading 19.5v at the sources. All the fuses were reading 19.5v also.
                  Tested the machine and everything was ok. Let it run on heaven benchmark for 30 min with no problems.
                  Thanks again all
                  • dellxps15
                    • Feb 2014
                    • 1588
                    • italy
                    #29
                    congratz for the repair man
                    • Themi
                      • May 2020
                      • 79
                      • Scotland
                      #30
                      Thanks man
                      • setha222
                        • Jan 2021
                        hey Themi, i have the exact issue u had can u direct me to were u got the new mosfet from.mine say ''' ''
                        3R030
                        PEm
                        1602 B2
                        8455
                        • tlough75
                          • Apr 2017
                          • 33
                          • US
                          #32
                          Themi, where did you get your 3R030 MOSFETs from?
                          • testpoint
                            • Feb 2021
                            • 9
                            PSMN3R0-30, from ebay or others
                            • rediii
                              h???, spurrrn
                              • Mar 2018
                              • 487
                              • somewhere in europe
                              #34
                              thanks for this wonderful thread, saved my razer, too <3
                              • zcinciev
                                • Apr 2015
                                • 3
                                • Macedonia
                                #35
                                Hi guys.
                                I saw this post and maybe someone can help out.
                                I have a razer laptop with Board Betty R6_MB. I had fixed this board some time ago there was a blown fuse on DC in. It worked good but the client came back with no power issue again so i had to replace Mosfet PQ46. At the moment when all plugged in it i have 3v and 5v , bios voltage etc all like it should have ald the keyboard lights up but no voltages on cpu etc... I have a short by measuring diode mode on PL8 on the positive side towards PCP20. I removed also PQ32 and PQ35 cause it was also very low resistance but couldn't find short but it's showing exactly same as before and the laptop was working. No schematics and would appreciate any ideas.
                                • Sephir0th
                                  • Oct 2020
                                  • 1282
                                  Could be Just BIOS issue. Share Pics of the components you're talking about and where are them located. Also it Would be nice to have the voltages and Resistances of each coil to GND listed
                                  FairRepair on YouTube
                                  • mon2
                                    • Dec 2019
                                    • 14086
                                    Board Betty
                                    Wait! Isn't that a woman's name ?
                                    https://www.youtube.com/watch?v=pz1rjq5emKY
                                    Are there any other markings on the logic board? Have access to at least one Razer logic board schematic.
                                    • badcapso
                                      • Jan 2020
                                      Hey guys. This model is loaded with cold solder joints. Just FYI.
                                      • bogosort
                                        • May 2022
                                        • 78
                                        Sorry for gravedigging,
                                        I have the same laptop but instead of having voltage on the first two mosfets, I only get 20V on the drain of the first one.
                                        I get a short to ground on the drain of the second mosfet.
                                        Any idea?
                                        • mon2
                                          • Dec 2019
                                          • 14086
                                          Flux and remove the 2nd mosfet. Then measure the resistance to ground again. No power to the logic board during these tests.
                                          Also review the above sticky by @Piernov on charger circuits.
                                          • shellybelly
                                            Razer Blade 2016 6700k 1060 RZ09-01952 suspected backlight power rail issue.
                                            by shellybelly
                                            Back Story
                                            I just recently purchased a RZ09-01652 Razer Blade 14 Touch v4(2016) as a project. I suspect the original motherboard had overheated and caused board damage to the vrm's for the CPU and GPU as now that motherboard works however will lockup on you often due to hardware clock issues.
                                            So after some research and looking at options for replacement motherboards I got a replacement RZ09-01952 razer blade 14 motherboard which has the 1060 vs the 970m that was in my original motherboard. I have contacted the seller about the motherboard being bad however I doubt they will be...
                                            08-27-2023, 10:40 PM
                                          • PantherDave
                                            by PantherDave
                                            Hi all!
                                            05-29-2024, 02:01 PM
                                          • GLISIT
                                            by GLISIT
                                            01-16-2025, 02:29 PM
                                          • chickenhawk88
                                            RAZER BLADE 15 2021 MODEL, No power, shorted rails.
                                            by chickenhawk88
                                            The laptop I am working on is RAZER BLADE 15 , RZ09-0369, the motherboard is DA560 VER 4.0. The original fault was it powered up with keyboard rgb on and no video on screen/hdmi. I found corrosion on memory module that leaked onto the memory socket. I cleaned the memory socket and was able to boot normal with other memory socket with good memory. I really should have stopped at this point as everything was working except for the one bad memory slot.
                                            I wanted to find out what was wrong with the other memory slot. I replaced a 330uf cap, a buck converter on back of board and when i...
                                            05-15-2024, 06:37 PM
