Razer Blade 2016 6700k 1060 RZ09-01952 suspected backlight power rail issue.
  • shellybelly
    • Aug 2023
    • united states
    Back Story
    I just recently purchased a RZ09-01652 Razer Blade 14 Touch v4(2016) as a project. I suspect the original motherboard had overheated and caused board damage to the vrm's for the CPU and GPU as now that motherboard works however will lockup on you often due to hardware clock issues.
    So after some research and looking at options for replacement motherboards I got a replacement RZ09-01952 razer blade 14 motherboard which has the 1060 vs the 970m that was in my original motherboard. I have contacted the seller about the motherboard being bad however I doubt they will be able to or willing to find another for me. The new motherboard was an open box motherboard straight from razer and does not have any repairs done to it at all.
    Other information: I have 3 boards for this laptop an extra board came with the laptop however that has so repairs already done to it and it looks like one of the repair traces has broken. So I do have parts boards.
    I will attempt to get some photos of the boards on here later tonight. If any more information or tests need to happen let me know I have a decent however 1970's era set of diagnostics tools not limited to logic analyzers(someone would have to show me how to use mine but i still have it no the less)
    The Problem
    Now that the back story on how I got here is out of the way. The problem:
    The board seems to be having a power rail issue and is not giving the proper power output to the backlight on the internal display. I plug in AC power to the laptop and the display will pop on dimly be it however it still turns on however it will fade out after a few seconds and die again. Without AC power no back light. I have checked all connections to and from the display and found no pinch points. I know the backlight works as the original board had no issues with the backlight/display. Other than the backlight issue the board functions perfectly an even boots into windows fine.
    My Questions
    Where are the test points on the motherboard for the rails and what are the excepted voltages?
    What could be causing the fading issue? Could it be from the in rush current from AC power input or is it something else?
    Does anyone know of line diagrams or schematics for these boards or where I can find them?
  • mon2
    • 14689
    Re: Razer Blade 2016 6700k 1060 RZ09-01952 suspected backlight power rail issue.
    Are you using the original and recommended power adapter?
    What is the power rating of the power adapter being used with this laptop?
    Is it a known good power adapter that works with another laptop of the same model?
    The backlight voltage may be generated on the logic board or inside the LCD panel. Aside from the above, locate the lcd connector on the logic board and count the number of pins and/or share a clear pic of this connector. The inductor uses a common pinout for the LCD screens so we can review others to get a start.
    Do you have access to a known good LCD? Does another LCD function on this logic board ?
    • shellybelly
      • Aug 2023
      • united states
      The LCD is known good. The OEM power adapter is good. I will get the rest of the information needed when I get home
      • theplop
        Razer blade 2022, 14" PI480 wont boot to OS, freezes
        by theplop
        Razer blade 2022, 14" PI480, Ryzen 6900HX, 16gb ram
        I picked up a Razer blade 14" (2022) from a friend who said it "overheated" and he replaced one of the fans. He gave up on it as windows wouldn't work/re-install. He gave it to me, and i've been working on getting linux on it. Installing Mint i was able to get about 1/4 through the installer before it froze. Now i can't even get the installer to boot. I am met with a kernel panic.... sometimes. Sometimes it just hangs on the boot sequence.
        I've run memtest quite a few times, and more often then not...
        03-20-2025, 06:42 PM
      • 0xx
        2022 Razer Blade 14 (RZ09-0427) won’t boot after Windows update, only the green LED blinks - overheated or BIOS?
        by 0xx
        Hi folks,
        My son clicked “Update and Shutdown” on a Razer Blade 14 (2022, RZ09-0427), closed the lid, disconnected the charger, and put the laptop in his backpack. The next day, it wouldn’t boot: only the green LED blinked, no fans, no keyboard backlight, no display. The chassis does get warm, so the CPU/GPU seems to get power.
        What I’ve tried so far: disconnecting the main battery, CMOS reset with power drain (30s), using a different power adapter, and connecting to the monitor - same result.
        I assumed that Windows Update was interrupted due to closing...
        09-14-2025, 03:46 PM
      • Awdev
        Razer Blade 15 (2019) RZ09-03006E92 need BIOS Image
        by Awdev
        S/N is BY2011A72401766
        Full name: RZ09-03006E92-R3U1 Razer Blade 15” (2019) | RZ09-03006
        MB Model is: DA530-MB
        Dump is below, Laptop can do EC Reset but cannot boot. Suspect its BIOS or EC....
        10-18-2025, 02:13 AM
      • Trodrigue
        razer blade stealth 13 2019
        by Trodrigue
        Hi everyone, I'm posting this message for help. I was given a Razer Blade motherboard because many people around me know that I like to tinker or make things with computer salvage.
        The problem with this board is that the person ripped out the keyboard port from the board.
        But in short, it's not a problem in itself because I'm planning to build a console with this motherboard.
        The problem is turning on the card without the keyboard.
        So I'm looking for another way to turn it on, either by
        using the pins or by using the ITE chip ref: IT8320VG-256 1920-DX0 EA07ZB....
        10-02-2025, 10:17 AM
        Gigabyte AERO 14W-1060-BK7 Notebook Specification for Upgrade or Repair
        This specification for the Gigabyte AERO 14W-1060-BK7 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 14W-1060-BK7 boardview and 14W-1060-BK7 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
        09-06-2024, 05:46 AM
